In trying to use a Mushroom template card, it does not have the option of “tap_action” . Did the card change? I’ve used it before and the option was there. Or, how do I get it to show up? Thanks.```
After choosing the card you see the card config. Scroll down to the bottom, which fields are available?
Alternatively, you can switch to code editor and add
tap_action: action: your-desired-action
