**Describe the bug**
I am using the Docker container in combination with Music âŚAssistant (ghcr.io/music-assistant/server:2.3.3), Squeezelite connect to Music Assistant (I can see it it the list of players) but as soon as I send it a track the log starts to show that messages:
I cannot understand what I am doing wrong, does anyone sees it?
[10:44:44.618179] process:532 unhandled vers
[11:11:37.622748] send_packet:114 failed writing to socket: Broken pipe
[11:11:37.622815] send_packet:114 failed writing to socket: Broken pipe
[11:11:37.622852] send_packet:114 failed writing to socket: Broken pipe
[11:11:37.724511] process:532 unhandled vers
[11:13:10.823807] send_packet:114 failed writing to socket: Broken pipe
[11:13:10.823874] send_packet:114 failed writing to socket: Broken pipe
[11:13:10.823911] send_packet:114 failed writing to socket: Broken pipe
[11:13:10.926264] process:532 unhandled vers
**Expected behavior**
I expect that the track starts to be played on the audio card I chose.
**Docker-compose.yaml file**
This is the compose file part:
audio-player:
image: "giof71/squeezelite:debian-full-squeezelite-current-2024-09-23"
container_name: "audio-player"
networks:
- "mia-servmng"
dns:
- 172.19.0.1
environment:
- "SQUEEZELITE_NAME=audio-player"
- "SQUEEZELITE_SERVER_PORT=music-assistant:3483"
- "DISPLAY_PRESETS=Y"
- "SQUEEZELITE_AUDIO_DEVICE=hw:CARD=PCH,DEV=0"
- "SQUEEZELITE_MAC_ADDRESS=ab:cd:ef:12:34:56"
- "DISABLE_MAC_ADDRESS_GENERATION=true"
- "TZ=Europe/Rome"
volumes:
- "/usr/share/zoneinfo:/usr/share/zoneinfo"
- "/etc/timezone:/etc/timezone:ro"
- "/etc/localtime:/etc/localtime:ro"
devices:
- "/dev/snd:/dev/snd"
**Screenshots**
If applicable, add screenshots to help explain your problem.
**Operating system(please complete the following information):**
Docker
**Additional context**
This is the complete log:
$docker logs -f audio-player
Setting default value for SQUEEZELITE_MODE: [ALSA]
Setting default value for STARTUP_DELAY_SEC: [0]
About to sleep for 0 second(s)
Ready to start.
Using ALSA mode
=== BEGIN Available audio devices ===
Output devices:
null - Discard all samples (playback) or generate zero samples (capture)
default - Default Audio Device
sysdefault - Default Audio Device
hw:CARD=Device,DEV=0 - USB PnP Audio Device, USB Audio - Direct hardware device without any conversions
plughw:CARD=Device,DEV=0 - USB PnP Audio Device, USB Audio - Hardware device with all software conversions
default:CARD=Device - USB PnP Audio Device, USB Audio - Default Audio Device
sysdefault:CARD=Device - USB PnP Audio Device, USB Audio - Default Audio Device
front:CARD=Device,DEV=0 - USB PnP Audio Device, USB Audio - Front output / input
dsnoop:CARD=Device,DEV=0 - USB PnP Audio Device, USB Audio - Direct sample snooping device
hw:CARD=PCH,DEV=0 - HDA Intel PCH, ALC221 Analog - Direct hardware device without any conversions
hw:CARD=PCH,DEV=3 - HDA Intel PCH, HDMI 0 - Direct hardware device without any conversions
hw:CARD=PCH,DEV=7 - HDA Intel PCH, HDMI 1 - Direct hardware device without any conversions
hw:CARD=PCH,DEV=8 - HDA Intel PCH, HDMI 2 - Direct hardware device without any conversions
plughw:CARD=PCH,DEV=0 - HDA Intel PCH, ALC221 Analog - Hardware device with all software conversions
plughw:CARD=PCH,DEV=3 - HDA Intel PCH, HDMI 0 - Hardware device with all software conversions
plughw:CARD=PCH,DEV=7 - HDA Intel PCH, HDMI 1 - Hardware device with all software conversions
plughw:CARD=PCH,DEV=8 - HDA Intel PCH, HDMI 2 - Hardware device with all software conversions
default:CARD=PCH - HDA Intel PCH, ALC221 Analog - Default Audio Device
sysdefault:CARD=PCH - HDA Intel PCH, ALC221 Analog - Default Audio Device
front:CARD=PCH,DEV=0 - HDA Intel PCH, ALC221 Analog - Front output / input
surround21:CARD=PCH,DEV=0 - HDA Intel PCH, ALC221 Analog - 2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=PCH,DEV=0 - HDA Intel PCH, ALC221 Analog - 4.0 Surround output to Front and Rear speakers
surround41:CARD=PCH,DEV=0 - HDA Intel PCH, ALC221 Analog - 4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=PCH,DEV=0 - HDA Intel PCH, ALC221 Analog - 5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=PCH,DEV=0 - HDA Intel PCH, ALC221 Analog - 5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=PCH,DEV=0 - HDA Intel PCH, ALC221 Analog - 7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
hdmi:CARD=PCH,DEV=0 - HDA Intel PCH, HDMI 0 - HDMI Audio Output
hdmi:CARD=PCH,DEV=1 - HDA Intel PCH, HDMI 1 - HDMI Audio Output
hdmi:CARD=PCH,DEV=2 - HDA Intel PCH, HDMI 2 - HDMI Audio Output
dmix:CARD=PCH,DEV=0 - HDA Intel PCH, ALC221 Analog - Direct sample mixing device
dmix:CARD=PCH,DEV=3 - HDA Intel PCH, HDMI 0 - Direct sample mixing device
dmix:CARD=PCH,DEV=7 - HDA Intel PCH, HDMI 1 - Direct sample mixing device
dmix:CARD=PCH,DEV=8 - HDA Intel PCH, HDMI 2 - Direct sample mixing device
dsnoop:CARD=PCH,DEV=0 - HDA Intel PCH, ALC221 Analog - Direct sample snooping device
=== END-- Available audio devices ===
=== BEGIN Loading presets ===
Loading built-in Presets...
Loading preset [no-dsd.exclude-codecs]=[dsd]
Loading preset [goldilocks.upsampling]=[v::4:28:95:105:45]
Loading preset [extremus.upsampling]=[v::3.05:28:99.7:100:45]
Loading preset [goldilocks_96k.rates]=[96000:200]
Loading preset [goldilocks_96k.upsampling]=[v::4:28:95:105:45]
Loading preset [goldilocks_2x_only.rates]=[88200,96000:200]
Loading preset [goldilocks_2x_only.upsampling]=[v::4:28:95:105:45]
Loading preset [goldilocks_4x_only.rates]=[176400,192000:200]
Loading preset [goldilocks_4x_only.upsampling]=[v::4:28:95:105:45]
Loading preset [goldilocks_8x_only.rates]=[352800,384000:200]
Loading preset [goldilocks_8x_only.upsampling]=[v::4:28:95:105:45]
Loading preset [rates_96k.rates]=[96000:200]
Loading preset [rates_up_to_96k.rates]=[44100-96000:200]
Loading preset [rates_up_to_192k.rates]=[44100-192000:200]
Loading preset [rates_up_to_384k.rates]=[44100-384000:200]
Loading preset [rates_up_to_768k.rates]=[44100-768000:200]
Loading preset [rates_2x_only.rates]=[88200,96000:200]
Loading preset [rates_4x_only.rates]=[176400,192000:200]
Loading preset [rates_8x_only.rates]=[352800,384000:200]
Loading preset [rates_16x_only.rates]=[705600,768000:200]
Loading preset [archimago-goldilocks.upsampling]=[v::4:28:95:105:45]
Loading preset [archimago-extremus.upsampling]=[v::3.05:28:99.7:100:45]
Loading preset [goldilocks_up_to_96k.rates]=[44100-96000:200]
Loading preset [goldilocks_up_to_96k.upsampling]=[v::4:28:95:105:45]
Loading preset [goldilocks_up_to_192k.rates]=[44100-192000:200]
Loading preset [goldilocks_up_to_192k.upsampling]=[v::4:28:95:105:45]
Loading preset [goldilocks_up_to_384k.rates]=[44100-384000:200]
Loading preset [goldilocks_up_to_384k.upsampling]=[v::4:28:95:105:45]
Loading preset [goldilocks_up_to_768k.rates]=[44100-768000:200]
Loading preset [goldilocks_up_to_768k.upsampling]=[v::4:28:95:105:45]
Loading preset [dac.device]=["hw:CARD=DAC"]
Loading preset [x20.device]=["hw:CARD=x20"]
Loading preset [aune-s6-sw.device]=["hw:CARD=DAC"]
Loading preset [aune-s6.device]=["hw:CARD=DAC"]
Loading preset [aune-s6.mixer-device]=["hw:CARD=DAC"]
Loading preset [aune-s6.volume-control]=["S6 USB DAC Output"]
Loading preset [aune-x1s.device]=["hw:CARD=DAC"]
Loading preset [fiio-e18.device]=["hw:CARD=DACE18"]
Loading preset [gustard-u12-sw.device]=["hw:CARD=x20"]
Loading preset [gustard-u12.device]=["hw:CARD=x20"]
Loading preset [gustard-u12.mixer-device]=["hw:CARD=x20"]
Loading preset [gustard-u12.volume-control]=["xCORE USB Audio 2.0 Output"]
Loading preset [gustard-x12-sw.device]=["hw:CARD=x20"]
Loading preset [gustard-x12.device]=["hw:CARD=x20"]
Loading preset [gustard-x12.mixer-device]=["hw:CARD=x20"]
Loading preset [gustard-x12.volume-control]=["xCORE USB Audio 2.0 Output"]
Loading preset [gustard-x12-goldilocks.device]=["hw:CARD=x20"]
Loading preset [gustard-x12-goldilocks.mixer-device]=["hw:CARD=x20"]
Loading preset [gustard-x12-goldilocks.volume-control]=["xCORE USB Audio 2.0 Output"]
Loading preset [gustard-x12-goldilocks.rates]=[44100-384000:200]
Loading preset [gustard-x12-goldilocks.upsampling]=[v::4:28:95:105:45]
Loading preset [gustard-x16.device]=["hw:CARD=G20"]
Loading preset [hifiberry-dac-plus.device]=["hw:CARD=sndrpihifiberry"]
Loading preset [ifi-zen-dac.device]=["hw:CARD=Audio"]
Loading preset [peachtree-dacit.device]=["hw:CARD=DAC"]
Loading preset [pi-headphones.device]=["hw:CARD=Headphones"]
Loading preset [topping-d10-sw.device]=["hw:CARD=D10"]
Loading preset [topping-d10.device]=["hw:CARD=D10"]
Loading preset [topping-d10.mixer-device]=["hw:CARD=D10"]
Loading preset [topping-d10.volume-control]=["D10 "]
Loading preset [topping-d10s-sw.device]=["hw:CARD=D10s"]
Loading preset [topping-d10s.device]=["hw:CARD=D10s"]
Loading preset [topping-d10s.mixer-device]=["hw:CARD=D10s"]
Loading preset [topping-d10s.volume-control]=["D10s "]
Loading preset [topping-d10-balanced-sw.device]=["hw:CARD=Balanced"]
Loading preset [topping-d10-balanced.device]=["hw:CARD=Balanced"]
Loading preset [topping-d10-balanced.mixer-device]=["hw:CARD=Balanced"]
Loading preset [topping-d10-balanced.volume-control]=["D10 Balanced"]
Loading preset [topping-dx5.device]=["hw:CARD=DX5"]
Loading preset [topping-dx5.device]=["hw:CARD=E30"]
Loading preset [yulong-d200-sw.device]=["hw:CARD=DAC"]
Loading preset [yulong-d200.device]=["hw:CARD=DAC"]
Loading preset [yulong-d200.mixer-device]=["hw:CARD=DAC"]
Loading preset [yulong-d200.volume-control]=["YULONG Audio 384k DSD DAC "]
Finished loading built-in presets
No additional preset file found
There are [73] available presets
PRESET [topping-d10s.volume-control]=["D10s "]
PRESET [gustard-x12-goldilocks.upsampling]=[v::4:28:95:105:45]
PRESET [gustard-u12.mixer-device]=["hw:CARD=x20"]
PRESET [goldilocks_2x_only.upsampling]=[v::4:28:95:105:45]
PRESET [rates_up_to_768k.rates]=[44100-768000:200]
PRESET [goldilocks_96k.rates]=[96000:200]
PRESET [topping-d10.device]=["hw:CARD=D10"]
PRESET [rates_2x_only.rates]=[88200,96000:200]
PRESET [goldilocks_up_to_768k.rates]=[44100-768000:200]
PRESET [goldilocks_8x_only.rates]=[352800,384000:200]
PRESET [goldilocks.upsampling]=[v::4:28:95:105:45]
PRESET [gustard-u12.volume-control]=["xCORE USB Audio 2.0 Output"]
PRESET [gustard-x12.mixer-device]=["hw:CARD=x20"]
PRESET [yulong-d200-sw.device]=["hw:CARD=DAC"]
PRESET [topping-d10.volume-control]=["D10 "]
PRESET [aune-s6.device]=["hw:CARD=DAC"]
PRESET [goldilocks_up_to_96k.rates]=[44100-96000:200]
PRESET [yulong-d200.mixer-device]=["hw:CARD=DAC"]
PRESET [rates_up_to_384k.rates]=[44100-384000:200]
PRESET [goldilocks_4x_only.upsampling]=[v::4:28:95:105:45]
PRESET [gustard-x12-goldilocks.mixer-device]=["hw:CARD=x20"]
PRESET [aune-s6.mixer-device]=["hw:CARD=DAC"]
PRESET [gustard-x12.volume-control]=["xCORE USB Audio 2.0 Output"]
PRESET [topping-d10s-sw.device]=["hw:CARD=D10s"]
PRESET [gustard-u12.device]=["hw:CARD=x20"]
PRESET [goldilocks_4x_only.rates]=[176400,192000:200]
PRESET [dac.device]=["hw:CARD=DAC"]
PRESET [goldilocks_2x_only.rates]=[88200,96000:200]
PRESET [x20.device]=["hw:CARD=x20"]
PRESET [aune-x1s.device]=["hw:CARD=DAC"]
PRESET [goldilocks_up_to_384k.rates]=[44100-384000:200]
PRESET [topping-d10-sw.device]=["hw:CARD=D10"]
PRESET [topping-d10s.mixer-device]=["hw:CARD=D10s"]
PRESET [topping-d10.mixer-device]=["hw:CARD=D10"]
PRESET [goldilocks_up_to_192k.rates]=[44100-192000:200]
PRESET [pi-headphones.device]=["hw:CARD=Headphones"]
PRESET [gustard-x12-goldilocks.device]=["hw:CARD=x20"]
PRESET [rates_8x_only.rates]=[352800,384000:200]
PRESET [yulong-d200.device]=["hw:CARD=DAC"]
PRESET [archimago-extremus.upsampling]=[v::3.05:28:99.7:100:45]
PRESET [hifiberry-dac-plus.device]=["hw:CARD=sndrpihifiberry"]
PRESET [goldilocks_up_to_192k.upsampling]=[v::4:28:95:105:45]
PRESET [rates_4x_only.rates]=[176400,192000:200]
PRESET [yulong-d200.volume-control]=["YULONG Audio 384k DSD DAC "]
PRESET [goldilocks_up_to_96k.upsampling]=[v::4:28:95:105:45]
PRESET [gustard-x12-sw.device]=["hw:CARD=x20"]
PRESET [rates_up_to_96k.rates]=[44100-96000:200]
PRESET [archimago-goldilocks.upsampling]=[v::4:28:95:105:45]
PRESET [rates_96k.rates]=[96000:200]
PRESET [rates_up_to_192k.rates]=[44100-192000:200]
PRESET [topping-d10-balanced.volume-control]=["D10 Balanced"]
PRESET [gustard-x16.device]=["hw:CARD=G20"]
PRESET [topping-d10-balanced-sw.device]=["hw:CARD=Balanced"]
PRESET [topping-d10-balanced.mixer-device]=["hw:CARD=Balanced"]
PRESET [rates_16x_only.rates]=[705600,768000:200]
PRESET [aune-s6.volume-control]=["S6 USB DAC Output"]
PRESET [gustard-u12-sw.device]=["hw:CARD=x20"]
PRESET [gustard-x12-goldilocks.rates]=[44100-384000:200]
PRESET [goldilocks_8x_only.upsampling]=[v::4:28:95:105:45]
PRESET [goldilocks_96k.upsampling]=[v::4:28:95:105:45]
PRESET [goldilocks_up_to_768k.upsampling]=[v::4:28:95:105:45]
PRESET [peachtree-dacit.device]=["hw:CARD=DAC"]
PRESET [extremus.upsampling]=[v::3.05:28:99.7:100:45]
PRESET [gustard-x12-goldilocks.volume-control]=["xCORE USB Audio 2.0 Output"]
PRESET [no-dsd.exclude-codecs]=[dsd]
PRESET [topping-d10-balanced.device]=["hw:CARD=Balanced"]
PRESET [topping-dx5.device]=["hw:CARD=E30"]
PRESET [gustard-x12.device]=["hw:CARD=x20"]
PRESET [fiio-e18.device]=["hw:CARD=DACE18"]
PRESET [goldilocks_up_to_384k.upsampling]=[v::4:28:95:105:45]
PRESET [ifi-zen-dac.device]=["hw:CARD=Audio"]
PRESET [aune-s6-sw.device]=["hw:CARD=DAC"]
PRESET [topping-d10s.device]=["hw:CARD=D10s"]
=== END-- Loading presets ===
Initializing command line: [/app/bin/squeezelite]
No presets have been specified
Variable SQUEEZELITE_SERVER_PORT has been specified: music-assistant:3483
Variable SQUEEZELITE_NAME has been specified: audio-player
Variable SQUEEZELITE_MODEL_NAME has not been specified
Variable SQUEEZELITE_TIMEOUT has not been specified, using default 2
Variable SQUEEZELITE_AUDIO_DEVICE has been specified: hw:CARD=PCH,DEV=0
Variable SQUEEZELITE_MIXER_DEVICE has not been specified
Variable SQUEEZELITE_DELAY has not been specified, using default 500
Variable SQUEEZELITE_PARAMS has not been specified
Variable SQUEEZELITE_VOLUME_CONTROL not specified
Variable SQUEEZELITE_LINEAR_VOLUME not specified
Variable SQUEEZELITE_CODECS has not been specified
Variable SQUEEZELITE_EXCLUDE_CODECS has not been specified
Variable SQUEEZELITE_RATES not specified
Variable SQUEEZELITE_PRIORITY has not been specified
Variable SQUEEZELITE_UPSAMPLING not specified
Variable SQUEEZELITE_READ_FORMATS_FROM_HEADER not specified
Variable SQUEEZELITE_BUFFER_SIZE not specified
Variable SQUEEZELITE_STREAM_AND_OUTPUT_BUFFER_SIZE (DEPRECATED) not specified
Variable SQUEEZELITE_UNMUTE not specified
Variable SQUEEZELITE_VISUALIZER not specified
Current user id is [0], requested USER_MODE=[]
Resulting actual_user_mode: [0]
User mode disabled
Variable SQUEEZELITE_MAC_ADDRESS specified: ab:cd:ef:12:34:56
Command Line: [/app/bin/squeezelite -s "music-assistant:3483" -n "audio-player" -C "2" -o "hw:CARD=PCH,DEV=0" -D "500" -m "ab:cd:ef:12:34:56"]
