Music Assistant 2.0: Your Music, Your Players
I assume you are using the local file system provider. Review the docs for image support. See the link above
Edit to add this is MA server version 2.3.5.
Edit 2: This seems to happen only with the Chromecast Audio and not the Google Nest Mini. Iā€™m going to restart the CA and see if this still happens.
Edit 3: After a restart, same thing. This time I got 4 warning-like sounds from the CA and then one song played with nothing added to the queue. Next thing Iā€™ll try is removing the player from MA and re-adding it.
Iā€™ve been using MA successfully for about 2 weeks. I had about a dozen working Filesystem playlists. Today when I start a playlist on our Chromecast Audio, the Chromecast plays two piano-sounding tones weā€™ve never heard before, then plays one song from the playlist and stops. The queue is empty. Selecting a playlist and then Add to Queue adds nothing to the queue.
I turned on debug logging and captured the log when I restarted the add-on and then tried to play a playlist. Hereā€™s the relevant snippet (with background metadata searches removed:
2025-01-06 10:40:41.044 DEBUG (MainThread) [music_assistant.player_queues] Fetching tracks to play for playlist Jumping Jack
2025-01-06 10:40:41.064 DEBUG (MainThread) [music_assistant.audio] Getting streamdetails for filesystem_smb--R6rMpJEq://track/Beastie Boys/Solid Gold Hits/Beastie Boys - Sabotage.mp3
2025-01-06 10:40:41.118 DEBUG (MainThread) [music_assistant.audio] retrieved streamdetails for filesystem_smb--R6rMpJEq://track/Beastie Boys/Solid Gold Hits/Beastie Boys - Sabotage.mp3 in 54 milliseconds
2025-01-06 10:40:41.221 DEBUG (MainThread) [music_assistant.players] Handling command play_media for player Basement speaker
2025-01-06 10:40:41.221 INFO (ThreadPoolExecutor-0_2) [pychromecast] Quitting current app
2025-01-06 10:40:41.222 INFO (ThreadPoolExecutor-0_2) [pychromecast.controllers] Receiver:Stopping current app 'CC1AD845'
2025-01-06 10:40:41.229 DEBUG (zeroconf-ServiceBrowser-_googlecast._tcp-314) [music_assistant.chromecast] Chromecast removed: o - h
2025-01-06 10:40:41.241 DEBUG (ThreadPoolExecutor-0_2) [music_assistant.chromecast] Launching App C35B0678.
2025-01-06 10:40:41.241 INFO (ThreadPoolExecutor-0_2) [pychromecast.controllers] Receiver:Launching app C35B0678
2025-01-06 10:40:41.624 INFO (Thread-519) [pychromecast.controllers] Receiver:Launching app C35B0678 failed, retrying once
2025-01-06 10:40:41.625 INFO (Thread-519) [pychromecast.controllers] Receiver:Launching app C35B0678
2025-01-06 10:40:42.028 INFO (ThreadPoolExecutor-0_1) [pychromecast.controllers] Receiver:Launching app CC1AD845
2025-01-06 10:40:43.534 DEBUG (zeroconf-ServiceBrowser-_googlecast._tcp-314) [music_assistant.chromecast] Discovered new or updated chromecast CastInfo(services={MDNSServiceInfo(name='Chromecast-Audio-610020ab0b7eecc886dfe1b6b5d50ebe._googlecast._tcp.local.')}, uuid=UUID('610020ab-0b7e-ecc8-86df-e1b6b5d50ebe'), model_name='Chromecast Audio', friendly_name='Basement speaker', host='192.168.99.186', port=8009, cast_type='audio', manufacturer='Google Inc.')
2025-01-06 10:40:43.729 DEBUG (MainThread) [music_assistant.streams] Start serving audio stream for QueueItem Beastie Boys - Sabotage (filesystem_smb--R6rMpJEq://track/Beastie Boys/Solid Gold Hits/Beastie Boys - Sabotage.mp3) to Basement speaker
2025-01-06 10:40:43.738 DEBUG (MainThread) [music_assistant.audio.media_stream] start media stream for: filesystem_smb--R6rMpJEq://track/Beastie Boys/Solid Gold Hits/Beastie Boys - Sabotage.mp3
After that, the queue was empty and the music stopped after one song. I tried this with multiple fliesystem playlists and the 500 Random Tracks playlist and got the same results.
This looks similar to Playback stops after playing one song (Chromecast) Ā· Issue #2887 Ā· music-assistant/support Ā· GitHub. Is it possible this bug has resurfaced? If so, should I re-open that bug or start a new one?
As this has happened without an update to MA I wouldnā€™t raise an issue at this point. You can ask on discord or a Q&A on GitHub. If you use GH we can transfer it to an issue if needed. But do more fault finding and thinking about what might have changed on your network. Edit: to clarify my last point it looks like the player is getting lost
How do I add the players in music assistant? I do not see any menu point allowing this
In the settings. If you read the docs it is all in there.
This comes up with a 404 page not found error. The link is broken.
Thanks for the reply. As it turns out, restarting HA (again) made the Chromecast Audio start working (again) with MA. Who knows what was going wrong, but itā€™s back to where it was now.
Link Fixed
Itā€™s late at night so I havenā€™t done a great deal of troubleshooting beyond restarting HA and updating MAā€¦ but Iā€™m experiencing the same issue.
Local filesystem playlist files play one song (tested the same playlist from different songs) then stop playing with a return code of 0.
After a few hours of working fine last night, I woke up to the same problem. Playing anything to the Chromecast audio results in 2-4 ā€œwarning chimesā€ (Iā€™ve never heard these before so not sure how to describe them), then the normal chime and playback of 1 song starts. At the end of one song, MA shows the source as ā€œExternal source: default media receiverā€ with nothing in the queue.
Given the multiple pieces of equipment involved, Iā€™ve narrowed it down to either the Chromecast Audio or Music Assistant or Home Assistant or my RPi5 or the Unifi 24-port switch or the USG-4 or the cable modem or Jupiterā€™s ascendance into Orion, etc.
I feel like the strange warning tones at the beginning of playback might offer a clue as to whatā€™s going wrong, but I canā€™t seem to find information about that online. Nothing showing in the limited info I can see about the CCA in Google Home.
EDIT: I just discovered another data point: when I send a playlist to either the CCA or my Google Nest Mini, if I immediately hit the queue button I can see the whole playlist in the queue. Then a few seconds later the queue clears to zero songs. Playlists to the Sonos donā€™t experience this issue. To me this seems like the issue is more likely software. Iā€™m going to update HA Core and see if that magically helps.
As reported on github, this was due to MAā€™s server(s) being down. After restarting MA, itā€™s working fine again.
hello, i am loving where youā€™ve got to with MA, i just have one issue. i have one folder of a load of random songs from various singles and albums - my favourite playlist. i have tried my best to configure this as a compilation so i can create an actual playlist in MA, but so far failed. All the tags are done to make it look like a compilations, AlbumArtist is Various Artists, Artists are the actual artists, consistent Album and Year tags - comparing it to a compilation that is actually recognised by MA as a compilation, it looks identical.
The only thing i can assume is that the Musicbrainz metadata is what drives the compilation? and because its not real that doesnt work? is there any other way around this?
Cheers!
Have a look here and see if this helps at all. File System Provider - Music Assistant Itā€™s not exactly what you want do but will give you some tips.
Iā€™m struggling. I tried to get MA to find my chromecast players on my network. My plex sees the players but MA does not see ANY of them. My HA instance is currently on Hyper-V. I tried spinning up a separate instance on Proxmox. The HA/MA instances are on the same flat network as my chromecast devices. But no luck. MA will not see my chromecast devices. Any thoughts?
Something is blocking mdns discovery. Check router settings and any firewalls
Is your music assistant container connected as a bridge / with --net=host ? or is the music assistant container working with private network and port forwarding?
Is search functionality out of beta and in the core release?
If mDNS was broken on my network then Google cast features from my phone or the discovery of Chromecast devices in HA would not work. Everything is on the same vlan so it should effectively function as a layer 2 network.
@Rudd-O Iā€™m not sure how to check all of that. I can access the music assistant through the web gui on the local network at HAipaddress:8095. I just clicked on the Add-on button to install it from home assistant when I installed it. It did not give any container/bridge options.
If you are using HAOS it should just work.
Thatā€™s what I was thinking. But I donā€™t have anything bare-metal that I can install hasOS on and experiment with. Thatā€™s why I tried Hyper-V and Proxmox - because I have those available at the moment.
