Music Assistant 2.0: Your Music, Your Players
Does it load in the regular browser?
Not is Safari, no. I also just tried Opera as that is the only other browser in the Apple store that would let me download and install on this old 12.5.7 ios version and it also would not open up Music Assistant page. The only other page in Home Assistant that also does not load correctly is my Custom fireremote-cards. They all show ā€œCustom element doesnā€™t exist: fireremote-card.ā€ with a big red ! in front of that message. So it seems to be the same issue in a Web browser as it is in the old app version of Home assistant that is installed on the old iPad mini 2.
Anyone managed to make service auth callback work behind a rev proxy? Latest beta allows setting a base url in the frontend settings but still when you try to authenticate with Spotify it will use the server IP address and port as a callback URL.
EDIT this is working with latest beta, more info here: Auth callback will not redirect to webserver URL in new beta Ā· Issue #3487 Ā· music-assistant/support Ā· GitHub
Is there anyone whoā€™s running succesfully MA with Squeezelite to play audio from the Rpi4 built in audio output?
It was working fine long ago (with MA beta, before 2.0 release), then I upgraded to MA 2.0 and it broke the audio output.
Now I bought a new Rpi4, reinstalled MA from start andā€¦same issue, itā€™s not working.
The audio output is completely broken (almost like it was buffering the audio and only producing a fragmented clipping sound every 5-6 seconds while a song is playing in MA.
I donā€™t see any error messages in the log, just completely broken audio from the output. thanks
You donā€™t provide enough detail about how you are trying to do this. Look here for options I Want To Stream To - Music Assistant
Easiest option is to grab a RPi and put picoreplayer on it.
I have a few questions about tagging and how stuff is displayed in MA.
I have had MA installed for some time (months) so I donā€™t think any of them could be due to any throttling of DB lookups.
I also believe all my tagging is accurate :wink:
Here are two questions to get startedā€¦
  1. Not all my artists get a thumbnail.
    Some examples - I thought maybe ABBA was a problem being all upper case and that maybe the apostrophe in Dexyā€™s might be causing a problem, but can find no reason for Sex Pistols.
    (There are many more examples)
  1. Is it correct that artists on ā€˜various artistsā€™ albums donā€™t appear as artists in their own right under ā€˜Artistsā€™? The tracks do have the correct Artist tag (where Iā€™ve checked).
    For example none of these artists have albums and do not appear in the list of artists despite the number of artists being reported is 711 on bothā€¦
ā€¦the Home page:
ā€¦and the Artists page:
On your second question you donā€™t have the album artist filter on do you? All artists will appear in the artists view regardless as to whether they are an album artist or not if you have that option disabled.
On your first question best to ask in Discord or GH as it might take a bit of back and forth to resolve.
Thanks, yes I did have album artist filter on. Iā€™d completely forgotten about that setting. Weirdly the ā€˜filteredā€™ list is not reporting the full 711 artists today.
Iā€™ll go over to GH for the Artist thumbnail question - I canā€™t deal with Discord I never understood how it became the go-to place for any kind of support. It seems to me to be just a glorified WhatsApp and no one in their right mind would have chosen that for the purposes Discord is used for.
But thatā€™s just my opinion. Iā€™m obviously wrong :laughing:
Hi there, thanks for MA, using it since two weeks, great !
I read, that podcast support is on the roadmap, any news about
that ?
Thanks, stefan
Itā€™s available in the beta Music Providers - Music Assistant
I wonder if itā€™s possible or planned to integrate https://airable.fm as plugin for radio. Itā€™s the follower of Frontier Nuvolasā€™ discontinued service.
Feature requests need to be raised in the discussions area of the GH support repo
Hello Community,
Iā€™ve already done a lot of research and tried things out, but unfortunately I havenā€™t been able to use music assistant externally. I like the module, but I like listening to stations from the radio browser when Iā€™m on the go (in the car). The Music Assistant is great for this because you can sort the stations.
Is there any way to use Music Assistant outside of the local network?
Thanks in advance!
Not without a lot of effort. It is not supported officially.
I have noticed that whenever I play to most airplay-enabled systems here at home like Kodi or my receiver, the first few seconds of any song that I play or skip to are cut off. Is that expected ā€” or is it supposed to run perfectly and I have something wrong with my receiver?
Iā€™ve noticed the same fwiw. Using Sonos and HomePods over Airplay
Im tying to get a similar setup running: Sonos One / Amp / Arc, HomePod 1, HomePod Mini.
I have MA up and running with Apple Music and MA Sonos integration.
Now I would like to geht it all running with AirPlay, but I then do not get any sound from the sonos anymore.
AirtPlay Mode in the Sonos Devices are activated.
Unifi network Mdns and IGMP-Snooping are activated.
Any hints on getting AirPlay Mode running?
Since the stable install I get no music listed from Youtube Music, I reinstalled the addon completely and setup YT music from scratch, still no music being listed.
anyone else have issues?
Can someone point me in the direction of setup for music assistant? I thought I had everything set up but I canā€™t get anything to play through any media devices such as my laptop through HASS.Agent or on my tv with Kodi. The devices/entities show up in HA, but I cannot play music. The voice assistant does play music (go figure) so I have no idea what else Iā€™m doing wrong. I canā€™t find anything discerning in the documentation that is helpful for my use case.
