Music Assistant and NAS
I have a FritzBox 7530 with an HD connected as NAS device. Is it possible to make Music Assistant see this HD and the media included?
If yes, how?
the Fritz!Box Mediaserver should be connected via the …
My Synology NAS is shared out to 5 devices on the “workgroup” network Except it is ti named “SOPHIE” not workgroup. Anyway there is no issue mapping to my Synology Nas shared folders on any device except for my Homeassistant Music Assistant. My HA is running on a windows10 machine with virtualbox. I moved from Pi3 and found the PC instance fantastic. I have used all of the correct config syntax and tried just about every variation suggested on line so far. The virtual box window has indicated “Return code 255” Has anyone had this and resolved it
