I have collection of Sonos speakers with a few scripts to play music. After fighting
and losing to get the default Sonos integration to play specific Spotify playlists, I switched to Music Assistant. This has made it way easier to specify the music I want in Scripts.
The only snafu I’m hitting is changing the input on my Sonos port. I have a turntable attached and a script to switch Sonos to the Line-in source. This uses the default Sonos devices rather than the MA devices, as I can’t find a way to adjust this through MA.
Switching to line-in works fine, but switching back to MA/spotify playlists causes problems. The script below is able to correctly stop the players, adjust the volume, and enable shuffle mode. But if I try to set the source to a playlist on the MA devices, nothing happens (“nothing” as in no music plays but also no error message). If I run the script once, wait a few minutes, and then run it again, then the playlist starts correctly.
I’m guessing the issue is that I’m throwing commands to both the Sonos devices directly and the MA devices, because even the Sonos app seems to get confused about the source immediately after this script. The only time I call the Sonos speakers directly is to set the line-in source. Other than that, everything happens in MA. Is there a way to set MA to the Port’s line-in so that I can stop “talking” to the Sonos devices directly?
Script to enable line-in (this works fine every time):
- action: media_player.media_stop
metadata: {}
data: {}
floor_id: apartment
- action: media_player.volume_set
metadata: {}
volume_level: 0.3
floor_id: apartment
- action: media_player.play_media
metadata: {}
media_content_id: x-rincon-stream:RINCON_[serial number]
media_content_type: music
label_id: sonos
alias: Set source to turntable
description: ""
I’ve tried using the same media_content_id
with MA, but that just seems to use value as a search and plays the closest matching track from Spotify
And here is the script to switch to a Spotify playlist. Everything except the last step seems to work as expected; no music plays but no error is thrown if I’m immediately transitioning out of the line-in. (but it works correctly if I wait a few minutes after the line-in has been stopped):
metadata: {}
data: {}
floor_id: apartment
- action: media_player.shuffle_set
metadata: {}
shuffle: true
label_id: music_assistant
metadata: {}
volume_level: 0.2
- action: music_assistant.play_media
metadata: {}
media_id: spotify://playlist/37i9dQZF1DX4sWSpwq3LiO
alias: Play sleep music
description: ""
