Music Assistant container on Docker under Windows 11 not working
I am trying to get Music Assistant to run in a container on Docker on a Windows 11 NUC server.
It worked perfectly when running Music Assistant under Docker on a Debian OS but I really need a lot Windows to run some programs.
For now I am just using a very simple Docker Compose:
version: ‘3’
services:
music-assistant:
network_mode: host
privileged: true
volumes:
- ‘/data’
image: ‘Package server · GitHub
Log file from Docker
2024-06-23 18:35:53 2024-06-23 16:35:53.418 INFO (MainThread) [music_assistant] Starting Music Assistant Server (4c2bad83d034483fbd3b3cb0bf596c6c) version 2.0.7 - HA add-on: False - Safe mode: False
2024-06-23 18:35:53 2024-06-23 16:35:53.422 INFO (MainThread) [music_assistant.cache] Initializing cache controller...
2024-06-23 18:35:53 2024-06-23 16:35:53.945 INFO (MainThread) [music_assistant.music] Using a sync interval of 180 minutes.
2024-06-23 18:35:54 2024-06-23 16:35:54.028 INFO (MainThread) [music_assistant.streams] Detected ffmpeg version 6.0.1 with libsoxr support
2024-06-23 18:35:54 2024-06-23 16:35:54.028 INFO (MainThread) [music_assistant.streams] Starting server on  0.0.0.0:8097 - base url: http://192.168.65.3:8097
2024-06-23 18:35:54 2024-06-23 16:35:54.032 INFO (MainThread) [music_assistant.webserver] Starting server on  0.0.0.0:8095 - base url: http://192.168.65.3:8095
2024-06-23 18:35:54 2024-06-23 16:35:54.107 INFO (MainThread) [music_assistant] Loaded music provider Music Assistant
2024-06-23 18:35:54 2024-06-23 16:35:54.107 INFO (MainThread) [music_assistant] Loaded metadata provider TheAudioDB Metadata provider
2024-06-23 18:35:54 2024-06-23 16:35:54.108 INFO (MainThread) [music_assistant] Loaded metadata provider fanart.tv Metadata provider
2024-06-23 18:35:54 2024-06-23 16:35:54.108 INFO (MainThread) [music_assistant] Loaded metadata provider MusicBrainz Metadata provider
2024-06-23 18:35:54 2024-06-23 16:35:54.264 INFO (MainThread) [music_assistant.music] Sync task for Music Assistant completed
2024-06-23 21:35:52 2024-06-23 19:35:52.360 INFO (MainThread) [music_assistant.music] Sync task for Music Assistant completed
2024-06-24 00:35:50 2024-06-23 22:35:50.431 INFO (MainThread) [music_assistant.music] Sync task for Music Assistant completed
2024-06-24 03:35:48 2024-06-24 01:35:48.580 INFO (MainThread) [music_assistant.music] Sync task for Music Assistant completed
2024-06-24 06:35:44 2024-06-24 04:35:44.930 INFO (MainThread) [music_assistant.music] Sync task for Music Assistant completed
2024-06-24 09:35:42 2024-06-24 07:35:42.903 INFO (MainThread) [music_assistant.music] Sync task for Music Assistant completed
2024-06-24 12:35:41 2024-06-24 10:35:41.026 INFO (MainThread) [music_assistant.music] Sync task for Music Assistant completed
2024-06-24 15:35:38 2024-06-24 13:35:38.899 INFO (MainThread) [music_assistant.music] Sync task for Music Assistant completed
Its supposed to initiate and run on: http://10.0.0.61:8095/ but not available
What am I doing wrong?
