Music Assistant DJ Announcer Blueprint for Home Assistant – Automated DJ-Style Music Playback
Bring the party home with this fun DJ Announcer blueprint! It plays your favorite playlists on any speaker or room, adding cool DJ-style voice intros between tracks. Shuffle your music, pick randomly from several of your playlists, and get lively announcements with track names and artists—perfect for events or just vibing at home.
Requirements:
Music Assistant configured properly and playlists configured
Airplay speakers have latency with TTS announcements.
  • One or more media_player entities (speakers, smart speakers, etc.) configured in Home Assistant.
  • Playlists managed by Music Assistant (or compatible playlists that work with the music_assistant.play_media service).
  • Access to a Text-To-Speech (TTS) engine in Home Assistant (default is tts.home_assistant_cloud, but any configured TTS can be used).
  • Recommended: Smart speakers or devices supporting media playback and TTS announcements.
  • Optional: Custom room aliases defined in the blueprint to easily select speakers by name.
Make sure your media players support playlist shuffling and playback control for the best experience.
Instructions to Use the DJ Announcer Blueprint
  1. Import the Blueprint
    Import the blueprint YAML into Home Assistant via Configuration > Blueprints > Import Blueprint or by clicking the import badge link provided in the post.
  2. Create Automation or Script Instance
    Once imported, create a new automation or script using the DJ Announcer blueprint as the base.
  3. Configure Inputs
  • Choose the Room alias (e.g., Living Room, Kitchen) or directly specify a Speaker(media_player entity).
  • Select from the available Playlists or paste a Music Assistant playlist URI.
  • Optionally select the TTS engine (defaults to Home Assistant Cloud TTS if left blank).
  • Adjust the Cue breath (chime_wait_sec) if your speaker needs a short delay after introductory phrases before starting music (default 2 seconds).
  1. Run the Automation/Script
    Trigger the automation/script to start the DJ session. This will:
  • Shuffle the selected playlist.
  • Play it on the chosen media player.
  • Announce the playlist and each track with DJ-style voice intros using TTS.
  • Continue announcing until playback stops.
  1. Requirements
  • Ensure at least one compatible media_player is configured in Home Assistant.
  • Have Music Assistant integration managing your playlists.
  • Confirm TTS integration is set up and functional for voice announcements.
  1. Troubleshooting
  • If no player or room name is recognized, a persistent notification will alert you to choose a valid speaker or alias.
  • If the primary playlist fails, a fallback playlist will be selected and a notification raised.
  • Check media player compatibility with playlist playback and TTS announcements.
blueprint:
  name: DJ Announcer (Music Assistant)
  description: >
    Play a playlist on any speaker, with DJ-style TTS intros between tracks.
    Select speakers/rooms/playlists via aliases, entities or URIs.
  domain: script
fields:
  room:
    description: Choose a room alias to resolve the target player, or leave blank if providing explicit speaker.
    selector:
      select:
        options:
          - Patio
          - Living Room
          - Office
          - Bedroom
          - Hall
          - Master Bathroom
          - Kitchen
        custom_value: true
  speaker:
    name: Speaker (entity override)
    description: Optional explicit media_player.* to use instead of alias.
    selector:
      entity:
        domain: media_player
  playlist:
    description: Pick a playlist from the pool, or paste a Music Assistant playlist URI.
    selector:
      select:
        options:
          - 90s Hits Essentials
          - BBQ Classics
          - Yacht Rock Essentials
          - 70s Hits Essentials
        custom_value: true
  tts_engine:
    description: Optional TTS engine entity_id, blank for tts.home_assistant_cloud.
    selector:
      entity:
        domain: tts
  chime_wait_sec:
    name: Cue breath (seconds)
    description: Breath after Jetsons cue (default 2s).
    default: 2
    selector:
      number:
        min: 0
        max: 6
        step: 0.5
variables:
  _room_in: "{{ (room | default('') | string) | trim | lower }}"
  _speaker_in: "{{ (speaker | default('') | string) | trim }}"
  _tts_in: "{{ (tts_engine | default('tts.home_assistant_cloud') | string) | trim }}"
  _playlist_in: "{{ (playlist | default('') | string) | trim }}"
  _chime_wait: "{{ (chime_wait_sec | default(2.0)) | float(2) }}"
  _aliases:
    patio: media_player.patio_nabu
    living room: media_player.homepod_ma
    office: media_player.office_homepod_mini
    bedroom: media_player.bedroom_homepod_mini_ma
    hall: media_player.hall_homepod_mini_ma
    master bathroom: media_player.master_bathroom_homepod_mini_ma
    kitchen: media_player.kitchen_nabu
  _playlist_name_map:
    90s Hits Essentials: library://playlist/42
    BBQ Classics: library://playlist/84
    Yacht Rock Essentials: library://playlist/83
    70s Hits Essentials: library://playlist/85
    library://playlist/42: 90s Hits Essentials
    library://playlist/84: BBQ Classics
    library://playlist/83: Yacht Rock Essentials
    library://playlist/85: 70s Hits Essentials
  _playlist_pool_default:
    - library://playlist/42
    - library://playlist/84
    - library://playlist/83
    - library://playlist/85
  _player: >-
    {% set s = _speaker_in %}
    {% if s %}{{ s }}
    {% elif _aliases.get(_room_in) %}{{ _aliases.get(_room_in) }}
    {% else %}{% endif %}
  _tts: |-
    {% if '.' in _tts_in %}
      {{ _tts_in }}
    {% else %}
    {% endif %}
  _playlist_uri: |-
    {% set p = _playlist_in %}
    {% if p.startswith('library://playlist/') %}
      {{ p }}
    {% elif _playlist_name_map.get(p) %}
      {{ _playlist_name_map.get(p) }}
    {% else %}
      {{ (_playlist_pool_default | random) | string }}
    {% endif %}
  _picked_playlist_speak: |-
    {% set uri = _playlist_uri %}
    {% if uri.startswith('library://playlist/') %}
      {{ _playlist_name_map.get(uri, 'your playlist') }}
    {% else %}
      {{ uri }}
    {% endif %}
  _intro_openers:
    - Alright, the lights are warm and the faders are live
    - Hey there music lovers, welcome to the mix
    - Good vibes coming your way
    - Time to turn up the energy
    - Let’s get this party started
    - Welcome back to the sound zone
    - Ready to dive into some great music
    - The beats are calling and we’re answering
  _intro_connectors:
    - Spinning up
    - Starting with
    - Diving into
    - Kicking off with
    - Opening up
    - Beginning our journey through
  _track_intros:
    - First up
    - Starting strong with
    - Opening with
    - Leading off with
    - Kicking things off with
    - Here’s our opener
  _transition_phrases:
    - Up next on
    - Coming up from
    - Here’s another gem from
    - Keep the energy flowing with
    - Don’t touch that dial, we’ve got
    - Staying in the groove with
    - Next up from
    - Continuing the vibe with
    - Here comes
    - Rolling into
  _artist_connectors:
    - by
    - from
    - courtesy of
    - brought to you by
  _outro_phrases:
    - That’s the end of
    - We’ve reached the final notes of
    - Thanks for vibing with
    - That’s a wrap on
    - Hope you enjoyed the journey through
    - Until next time, that was
  _outro_closers:
    - See you next time
    - Keep the music playing
    - Thanks for listening
    - Catch you on the flip side
    - Stay tuned for more great music
    - Keep those good vibes going
sequence:
  - choose:
      - conditions:
          - condition: template
            value_template: "{{ not _player }}"
        sequence:
          - service: persistent_notification.create
              title: DJ Announcer Error
              message: >-
                Could not resolve a player. Provide a speaker entity or a known room alias (Patio, Living Room, Office, Bedroom, Hall, Master Bathroom, Kitchen).
              notification_id: dj_announcer_error
          - stop: Missing/invalid player
  - service: logbook.log
      name: DJ Announcer
      message: >
        Chosen playlist: {{ _playlist_uri }} (speaks as: {{ _picked_playlist_speak }})
  - service: media_player.shuffle_set
      entity_id: "{{ _player }}"
      shuffle: true
  - service: music_assistant.play_media
      media_type: playlist
      media_id: "{{ _playlist_uri }}"
      enqueue: replace
  - wait_template: "{{ states(_player) in ['playing','buffering'] }}"
    timeout: "00:01:00"
  - choose:
      - conditions:
            value_template: "{{ states(_player) not in ['playing','buffering'] }}"
        sequence:
              media_id: "{{ (_playlist_pool_default | random) }}"
              enqueue: replace
              title: Music DJ Warning
              message: Primary playlist failed. Fallback chosen.
              notification_id: music_dj_fallback
  - wait_template: "{{ (state_attr(_player,'media_title') | default('',true) | trim) != '' }}"
    timeout: "00:00:06"
    continue_on_timeout: true
  - variables:
      _raw_title: "{{ state_attr(_player,'media_title') | default('this one', true) }}"
      _raw_artist: >-
        {% set a = state_attr(_player,'media_artist') | default('', true) %}
        {% if not a %}
          {% set al = state_attr(_player,'media_artist_list') | default([], true) %}
          {% set a = (al | list | join(', ')) %}
        {% endif %}
        {% set a = a | replace('VEVO','') | replace('- Topic','') | replace(' - Topic','') | trim %}
        {{ a }}
      _speak_title: "{{ _raw_title }}"
      _speak_artist: >-
        {% set t = (_raw_title | lower) %}
        {% set a = (_raw_artist | lower) %}
        {% if a and a not in t and a != t %}{{ _raw_artist }}{% endif %}
  - wait_template: "{{ as_timestamp(now()) - as_timestamp(states[_player].last_changed) > _chime_wait }}"
    timeout: "00:00:10"
  - choose:
      - conditions:
            value_template: >
              and (state_attr(_player,'media_title') | default('', true) | trim) != '' }}
        sequence:
          - service: tts.speak
              entity_id: "{{ _tts }}"
              media_player_entity_id: "{{ _player }}"
              cache: false
              message: >-
                {{ _intro_openers | random }}, {{ _intro_connectors | random }}
                {{ _picked_playlist_speak }}, and {{ _track_intros | random }}
                it's {{ _speak_title }}{% if _speak_artist %} by {{ _speak_artist }}{% endif %}.
  - variables:
      _last_title: "{{ state_attr(_player, 'media_title') | default('', true) }}"
  - repeat:
      while:
          value_template: >
      sequence:
        - wait_template: >
            {{ state_attr(_player,'media_title') | default('', true) != _last_title }}
          timeout: "00:30:00"
        - variables:
            _last_title: "{{ state_attr(_player, 'media_title') | default(_last_title, true) }}"
            _raw_title: "{{ _last_title | default('this one', true) }}"
            _raw_artist: >-
              {% if not a %}
              {% endif %}
              {{ a }}
            _speak_artist: >-
        - choose:
            - conditions:
                  value_template: |
              sequence:
                    cache: false
                    message: >-
                      {{ _transition_phrases | random }} {{ _picked_playlist_speak }}:{% if _speak_title %} {{ _speak_title }}{% if _speak_artist %} {{ _artist_connectors | random }} {{ _speak_artist }}{% endif %} {% else %} another great track{% endif %}.
  - wait_template: "{{ states(_player) in ['idle', 'off'] }}"
    timeout: "01:00:00"
    continue_on_timeout: false
      cache: false
      message: >-
        {{ _outro_phrases | random }} {{ _picked_playlist_speak }}. {{ _outro_closers | random }}
I recently added the option to only announce between songs using announce_interval which defaults to every track. If there is interest I can post the updated section.
Can’t find the options in UI. Is this one supposed to be edited in yaml?
I’m not sure of your question, when you import it and save it it will be n your scripts. Click heb3 dots and go to more info and you can chose the options.
I see an issue and that is that my playlist numbers are hard coded and you will need to take control and edit the playlist to match yours. It’s totally not that hard. But you can manually drop your own playlist without having to take control.
These are the lines you need to edit to have the dropdown and your playlist played, just add or delete depending on how many playlist you want. you get the playlist info in Music Assistant un provider details at the bottom of the playlist
    options:
      - BBQ Classics
      - Summer Breeze Yacht Rock
      - The Music Makers • 60's, 70's and 80's Best Collection
_playlist_name_map:
90s Hits Essentials: library://playlist/26
BBQ Classics: library://playlist/17
Summer Breeze Yacht Rock: library://playlist/19
Yacht Rock Essentials: library://playlist/18
70s Hits Essentials: library://playlist/23
The Music Makers • 60’s, 70’s and 80’s Best Collection: library://playlist/20
- library://playlist/26
- library://playlist/17
- library://playlist/19
- library://playlist/18
- library://playlist/23
- library://playlist/20
Tried the blueprint, and ran into something really odd. In my case, it plays a song to around 5 seconds before the end, the DJ chimes in, then it plays the last 5 seconds of the NEXT song in the playlist, then the DJ, then it starts the song after that, starting from around the 5-8 second mark.
Okay, figured it out. Just wondering, would it be possible for the blueprint to tell the player to pause, play the text message, and then unpause so that the song isn’t as badly overlapped? I know it’s not really how DJ’s do it, but the issue is you can’t have the text message and the music playing at the same time (as it should be to do the DJ effect correctly).
I haven’t used this blueprint yet, but I think it is possible to have tts and music at the same time, at least with some media_players. E.g. I have two Sonos with music from music assistant playing together as a group. I use Chime TTS to play a TTS to only one of the speakers. It reduces volume on only that speaker, plays the TTS while the music continues, and the volume returns to normal. I think there is also a setting in Chime TTS to pause instead of dip the volume. Just sharing in case it can be adapted to work here too.
Yeah, having the DJ come in on one speaker while the music plays on another would be awesome. I’d have the DJ come out of my Voice while the music plays on the big speaker.
Almost got it. I know I need to edit the play list entries. That is not an issue. I am having problems finding out where I get the ‘library’ information from.
How do you know 90s Hits Essentials is actually library://playlists/26 ?
Greg
That’s what my playlist is. You will need to create your own playlist in Music Assistant then get the name and URI
Is there a short example of this function on YouTube? I couldn’t find anything.
Okay, this is sort of working, I get the TTS but only a short few seconds of music from my Playlist.
Edit, after a few attempts, what’s actually happening is I get 5 seconds of music, the TTS cuts in to introduce the song but the playback never resumes, then the TTS cuts in again to say that’s the end of the playlist
