hi to all, i installed music assistant and linked to my PLEX profile but it doesn’t work.
my HA run on a VM in my Truenas.
thanks
thanks
Pretty sure anyone trying to help is going to need more info than that.
What exactly isn’t working?
i’m not able to listen anything.
this is the screen with the playlist but when i click on play butto it doesn’t start, despite i have associated several player
Have you selected a player down in the corner? Click the speaker and select which media player it should play back on…
Also, you might try giving it some volume.
yes i did it but nothing. the problem is that doesn’t start
Have you added a player provider?
yes, look the image in the reply above
So what device are you playing to now?
Home Assistant Media Player with Alexa Media Player
I think we need logs.
2024-11-18 12:37:58.175 INFO (MainThread) [music_assistant] Starting Music Assistant Server (010845dc57aa4f37910690e668a2317d) version 2.3.3 - HA add-on: True - Safe mode: False
2024-11-18 12:37:58.182 INFO (MainThread) [music_assistant.cache] Initializing cache controller...
2024-11-18 12:37:58.918 INFO (MainThread) [music_assistant.music] Using a sync interval of 180 minutes.
2024-11-18 12:37:59.378 INFO (MainThread) [music_assistant.streams] Detected ffmpeg version 6.1.1 with libsoxr support
2024-11-18 12:37:59.378 INFO (MainThread) [music_assistant.streams] Starting server on 0.0.0.0:8097 - base url: http://192.168.1.53:8097
2024-11-18 12:37:59.383 INFO (MainThread) [music_assistant.webserver] Starting server on 172.30.32.1:8095 - base url: http://172.30.32.1:8095
2024-11-18 12:38:00.492 INFO (MainThread) [music_assistant] Loaded metadata provider fanart.tv
2024-11-18 12:38:00.493 INFO (MainThread) [music_assistant] Loaded metadata provider The Audio DB
2024-11-18 12:38:00.494 INFO (MainThread) [music_assistant] Loaded music provider Music Assistant
2024-11-18 12:38:00.494 INFO (MainThread) [music_assistant] Loaded metadata provider MusicBrainz
2024-11-18 12:38:00.495 INFO (MainThread) [music_assistant] Loaded player provider Playergroup
2024-11-18 12:38:00.515 INFO (MainThread) [music_assistant] Loaded player provider UPnP/DLNA Player provider
2024-11-18 12:38:00.527 INFO (MainThread) [music_assistant] Loaded player provider Slimproto (Squeezebox players)
2024-11-18 12:38:00.531 INFO (MainThread) [music_assistant] Loaded plugin provider Home Assistant
2024-11-18 12:38:00.605 INFO (MainThread) [music_assistant] Loaded player provider Home Assistant MediaPlayers
2024-11-18 12:38:00.624 INFO (MainThread) [music_assistant.players] Player registered: media_player.filodiffusione/Filodiffusione
2024-11-18 12:38:00.626 INFO (MainThread) [music_assistant.players] Player registered: media_player.this_device_2/This Device
2024-11-18 12:38:01.002 INFO (MainThread) [music_assistant.music] Sync task for Music Assistant completed
2024-11-18 12:38:01.639 INFO (MainThread) [music_assistant] Loaded music provider Plex Media Server Library
2024-11-18 12:38:22.858 WARNING (MainThread) [music_assistant.music] Sync task for Plex Media Server Library completed with errors
2024-11-18 15:37:59.450 INFO (MainThread) [music_assistant.music] Sync task for Music Assistant completed
2024-11-18 15:38:19.342 WARNING (MainThread) [music_assistant.music] Sync task for Plex Media Server Library completed with errors
2024-11-18 18:37:59.316 INFO (MainThread) [music_assistant.music] Sync task for Music Assistant completed
2024-11-18 18:38:19.268 WARNING (MainThread) [music_assistant.music] Sync task for Plex Media Server Library completed with errors
2024-11-18 20:22:02.416 INFO (MainThread) [music_assistant.hass] Connection to HA lost. Connection will be automatically retried later.
2024-11-18 20:22:07.435 WARNING (MainThread) [music_assistant] Error loading provider(instance) Home Assistant: 502, message='Invalid response status', url='ws://supervisor/core/api/websocket' (will be retried later)
2024-11-18 20:24:07.467 INFO (MainThread) [music_assistant] Loaded plugin provider Home Assistant
2024-11-18 20:24:07.506 INFO (MainThread) [music_assistant] Loaded player provider Home Assistant MediaPlayers
2024-11-18 21:37:59.477 INFO (MainThread) [music_assistant.music] Sync task for Music Assistant completed
2024-11-18 21:38:19.407 WARNING (MainThread) [music_assistant.music] Sync task for Plex Media Server Library completed with errors
2024-11-18 21:44:11.913 INFO (MainThread) [music_assistant.hass] Connection to HA lost. Connection will be automatically retried later.
2024-11-18 21:44:16.951 WARNING (MainThread) [music_assistant] Error loading provider(instance) Home Assistant: 502, message='Invalid response status', url='ws://supervisor/core/api/websocket' (will be retried later)
2024-11-18 21:46:16.975 INFO (MainThread) [music_assistant] Loaded plugin provider Home Assistant
2024-11-18 21:46:17.016 INFO (MainThread) [music_assistant] Loaded player provider Home Assistant MediaPlayers
2024-11-18 22:35:05.944 INFO (MainThread) [music_assistant.hass] Connection to HA lost. Connection will be automatically retried later.
2024-11-18 22:35:10.960 WARNING (MainThread) [music_assistant] Error loading provider(instance) Home Assistant: 502, message='Invalid response status', url='ws://supervisor/core/api/websocket' (will be retried later)
2024-11-18 22:37:10.983 INFO (MainThread) [music_assistant] Loaded plugin provider Home Assistant
2024-11-18 22:37:11.046 INFO (MainThread) [music_assistant] Loaded player provider Home Assistant MediaPlayers
2024-11-19 00:37:59.365 INFO (MainThread) [music_assistant.music] Sync task for Music Assistant completed
2024-11-19 00:38:19.316 WARNING (MainThread) [music_assistant.music] Sync task for Plex Media Server Library completed with errors
2024-11-19 03:37:59.396 INFO (MainThread) [music_assistant.music] Sync task for Music Assistant completed
2024-11-19 03:38:20.827 WARNING (MainThread) [music_assistant.music] Sync task for Plex Media Server Library completed with errors
2024-11-19 04:30:35.541 INFO (MainThread) [music_assistant.players] Player registered: uuid:7a3b1b0c-6d4d-11ef-b1dc-1b949fcd835e/Tv del soggiorno
2024-11-19 06:37:59.315 INFO (MainThread) [music_assistant.music] Sync task for Music Assistant completed
2024-11-19 06:38:19.300 WARNING (MainThread) [music_assistant.music] Sync task for Plex Media Server Library completed with errors
2024-11-19 09:37:59.411 INFO (MainThread) [music_assistant.music] Sync task for Music Assistant completed
2024-11-19 09:38:19.472 WARNING (MainThread) [music_assistant.music] Sync task for Plex Media Server Library completed with errors
2024-11-19 12:37:59.414 INFO (MainThread) [music_assistant.music] Sync task for Music Assistant completed
2024-11-19 12:38:19.453 WARNING (MainThread) [music_assistant.music] Sync task for Plex Media Server Library completed with errors
2024-11-19 15:37:59.487 INFO (MainThread) [music_assistant.music] Sync task for Music Assistant completed
2024-11-19 15:38:19.439 WARNING (MainThread) [music_assistant.music] Sync task for Plex Media Server Library completed with errors
2024-11-19 18:37:59.465 INFO (MainThread) [music_assistant.music] Sync task for Music Assistant completed
2024-11-19 18:38:19.490 WARNING (MainThread) [music_assistant.music] Sync task for Plex Media Server Library completed with errors
2024-11-19 19:48:58.548 INFO (MainThread) [music_assistant.hass] Connection to HA lost. Connection will be automatically retried later.
2024-11-19 19:49:03.570 WARNING (MainThread) [music_assistant] Error loading provider(instance) Home Assistant: 502, message='Invalid response status', url='ws://supervisor/core/api/websocket' (will be retried later)
2024-11-19 19:51:03.600 WARNING (MainThread) [music_assistant] Error loading provider(instance) Home Assistant: 502, message='Invalid response status', url='ws://supervisor/core/api/websocket' (will be retried later)
2024-11-19 19:53:03.626 INFO (MainThread) [music_assistant] Loaded plugin provider Home Assistant
2024-11-19 19:53:03.663 INFO (MainThread) [music_assistant] Loaded player provider Home Assistant MediaPlayers
2024-11-19 20:26:35.809 INFO (MainThread) [music_assistant.hass] Connection to HA lost. Connection will be automatically retried later.
2024-11-19 20:26:40.830 WARNING (MainThread) [music_assistant] Error loading provider(instance) Home Assistant: 502, message='Invalid response status', url='ws://supervisor/core/api/websocket' (will be retried later)
2024-11-19 20:28:40.849 INFO (MainThread) [music_assistant] Loaded plugin provider Home Assistant
2024-11-19 20:28:40.877 INFO (MainThread) [music_assistant] Loaded player provider Home Assistant MediaPlayers
2024-11-19 21:28:36.025 ERROR (MainThread) [music_assistant.webserver] Error handling message: config/providers/save: Re-Authentication required
2024-11-19 21:28:55.608 INFO (MainThread) [music_assistant.spotify] Successfully logged in to Spotify as Matteo Baricordi
2024-11-19 21:28:55.608 INFO (MainThread) [music_assistant] Loaded music provider Spotify
2024-11-19 21:29:17.316 INFO (MainThread) [music_assistant] Loaded music provider RadioBrowser
2024-11-19 21:29:17.350 INFO (MainThread) [music_assistant.music] Sync task for RadioBrowser completed
2024-11-19 21:29:53.522 INFO (MainThread) [music_assistant.music] Sync task for Spotify: Matteo Baricordi completed
2024-11-19 21:37:59.466 INFO (MainThread) [music_assistant.music] Sync task for Music Assistant completed
2024-11-19 21:38:19.708 WARNING (MainThread) [music_assistant.music] Sync task for Plex Media Server Library completed with errors
2024-11-19 21:38:30.040 INFO (MainThread) [music_assistant.music] Sync task for RadioBrowser completed
2024-11-19 21:38:36.051 INFO (MainThread) [music_assistant.music] Sync task for Spotify: Matteo Baricordi completed
2024-11-20 00:37:59.344 INFO (MainThread) [music_assistant.music] Sync task for Music Assistant completed
2024-11-20 00:38:19.464 WARNING (MainThread) [music_assistant.music] Sync task for Plex Media Server Library completed with errors
2024-11-20 00:38:19.684 INFO (MainThread) [music_assistant.spotify] Attempt 1/5 failed: Token expired
2024-11-20 00:38:19.685 INFO (MainThread) [music_assistant.spotify] Retrying in 0.05 seconds...
2024-11-20 00:38:29.904 INFO (MainThread) [music_assistant.music] Sync task for RadioBrowser completed
2024-11-20 00:38:35.787 INFO (MainThread) [music_assistant.music] Sync task for Spotify: Matteo Baricordi completed
2024-11-20 03:38:00.551 INFO (MainThread) [music_assistant.music] Sync task for Music Assistant completed
2024-11-20 03:38:19.805 WARNING (MainThread) [music_assistant.music] Sync task for Plex Media Server Library completed with errors
2024-11-20 03:38:30.144 INFO (MainThread) [music_assistant.music] Sync task for RadioBrowser completed
2024-11-20 03:38:36.565 INFO (MainThread) [music_assistant.music] Sync task for Spotify: Matteo Baricordi completed
2024-11-20 06:37:59.351 INFO (MainThread) [music_assistant.music] Sync task for Music Assistant completed
2024-11-20 06:38:20.072 WARNING (MainThread) [music_assistant.music] Sync task for Plex Media Server Library completed with errors
2024-11-20 06:38:30.434 INFO (MainThread) [music_assistant.music] Sync task for RadioBrowser completed
2024-11-20 06:38:36.382 INFO (MainThread) [music_assistant.music] Sync task for Spotify: Matteo Baricordi completed
2024-11-20 07:15:25.051 WARNING (MainThread) [music_assistant.webserver] Disconnected: Received non-Text message.
Music Assistant doesn’t work with Alexa.
and therefore how can i play music from my device like tablet or pc from the dashboard?
Perhaps you should look at the Music Assistant Documentation for the supported players.
Edit: While the documentation seems to go out of the way not to mention the words Amazon, Echo, or Alexa, this discussion gives you details Support for Alexa Media Player · music-assistant · Discussion #431
i read it but i’m not able to understand the right process/way to listen from my device like my laptop and so on…
Have a look here I Want To Stream To - Music Assistant
