Hello all
I am eager to play with Music Assistant wich is a great idea, but I am running in some difficulties.
My setup is HA latest version running on a synology virtual machine. My audio player is Moode on a raspberry 4
I am not clear wich path I should give in the configuration in order to access my local music files. Their path on the synology is /volume1/music/main , but when I enter this path in the configuration I get “Directory does not exist or not accessible”. Any clue for the correct path setting ?
Qobuz and Tunein work for me, but I experiment a big lag ( often many seconds) between a click on the music assistant panel and the subsequent effect on the audio stream and/or the actualisation of the display. For instance, when I click play on a song it takes time to load in the playbar, when I pause in the playbar it takes a few seconds for the play symbol to be replaced by the triangular pause button etc.
Is anybody else experimenting this lag, or could it be inherent to my setup (perhaps an incompatibility with Moode ?)
