I have different rooms in my house. All these rooms have a Sonos setup. Now I want to create different players on my mobile. This also works fine. But… the added playlists (Deezer in this case) are only displayed in 1 player. Even when the player containing the playlists is turned off, they will not be displayed in the other players. The yaml code used is the same. The only thing that differs are the entities (the Sonos speakers). Does anyone have an idea how I can make the playlists visible in all players?
Deezer is integrated in Music assistant. In music assistant is Sonos integrated al speaker in multiple rooms. But, the playlist will only show in one speaker.
I think there must be a way to devide the music streams to multiple rooms/speakers but cant find where or how…
Okay, then Music Assistant needs to be registered as several devices, one per partition you want to make.
I do not know if it is possible to register the Deezer setup multiple times.
I have not set up Deezer in MA, so I can not give you the details, but Deezer require a device per stream, so you therefore need to have MA look like multiple devices.
If Deezer is set up as an integration, then it might be possible to add that integration several times.
