Music assistant not showing players - SOLVED
I’m not sure if we can ask questions about MA on here yet as it’s only recently been bundled in.
I am running HA 2024.12.5 on Docker. I have four Bose Soundtouch speakers which show up correctly on HA in the devices and I can manage them (volume, settings, etc) from HA.
I am now using MA and have added loads of music but these speakers do not show up in the players section of MA so I can’t select them to play music.
In addition, the players are showing in MA ->Settings → HA media players → Generic settings
Is there somewhere else I need to add speakers to make them show up in MA?
Many thanks
Mike
As is typical, I have answered this myself!
I removed the players from MA ->Settings → HA media players → Generic settings
Saved
Added the speakers back
Saved
Now they show!
@mikeopensauce
If you have Bose SoundTouch gear, then you might check out the SoundTouchPlus Integration. It adds many custom services that allow you to get the most out of your SoundTouch gear.
I have 4 ST-10’s myself, as well as the ST-300 Soundbar with Bass module.
Hope it helps!
Hi. Do you know if there is an itegration for the Lifestyle range (LS 650) ?
@Lcdxr01
After looking at the manual, it seems the Bose LS 650 supports SoundTouch technology. You should be able to utilize the SoundTouchPlus Integration, as well as the SoundTouchPlus Card.
I should also note that Bose recently announced the End-Of-Life for SoundTouch Cloud services, which will affect functionality. That date is set for February 18, 2026.
Hope it helps!
