Music assistant, player local snapcast client UI
Hello All,
I am using HA 2024.9.2 and Music Assistant 2024.9.1, both in a docker container.
Everything works fine but I would like to implement some players around the home.
I am thinking about using snapcast client on a couple of RPI and considering the other users of the house will never take their phone access MA and play on the target device I would like to add touchscreen to the player connected to RPI.
Now, I would like to hear some opinions which is the best way to implement it.
  1. chromium automatically starting to Music assistant web page. Is there a way to make the local snapcast client connecting with MA the default target device to play music?
  2. snapcast client with local Mopidy iris web interface and chromium as above. Isn’t this solution doing two times the same thing, meaning two interfaces MA remote and mopidy iris local accessing to the same music library?
  3. just make another volumio as already done and manage it when needed from MA.
I dont’t stricly need multiroom, it will be used seldom by the other users at home.
Looking forward for suggestions and comments.
