Hello all
Music assistant looks awesome. However may i suggest that in the player section be added the possibility to play the content of music assistant via the default audio player of the pc
This would be very useful
Hello all
You can do that already.
The built in VLC media player addon together with
can make your HA server use the built-in audio and is compatible with MAss.
Thank you for your comment and suggestion.
I will try this…However I use Jellyfin which is better than vlc IMHO.
I have 3 HTPCs 1 pc and a phone which will feed me my media. Each one has a different sound environment
2 different AMPS, 1 amazon echo and one speaker set up for PC
Hi no joy with your solution.
As mentioned, VLC not suitable for me as all my playlists are built within Jellyfin and cannot be exported to vlc.
My Jellyfin library is loaded in MA however not able to play within MA
Run a squeezelite client on the pc
Thank you for responding and for your suggestion.
I just finished rebuilding my proxmox server and re-installed HA as a VM.
I decided to not use MA and prefer to continue with Jellyfin client.
I will wait for MA to become more mature and hopefully by then I will be able to accomplish my goals
Once again Thank you for your and all th MA team for your help
Happy Holydays to all and may the new year bring good tiding to one and all. Be well
