Music Assistant won't Uninstall
How do I remove Music Assistant MASS from the integrations?
Delete does not work. and hasn’t worked for many ha versions.
So far I’ve tried all the methods on github due to the problem starting with 2022.3
Is there a step by step advanced method for removing a stubborn integration from home assistant?
I have managed that by removing the code of MASS manually in
\config\.storage\core.config_entries
After that installed the beta addon, which replaces the old integration and it works again.
Be careful with editing this file, before you get even more troubles. :wink:
I’ve tried that twice, but I’m not sure it’s in the correct order.
I’ve deleted the entries then restarted… The entries just showed up again.
I’ve replaced the mass.zip files and restarted. The errors are still there.
What order should I restart HA? ? do both and then restart? Thanks.
I have the same problem and I cannot remove MA from the integration. The update button appears but nothing happens when I press it.
So it looks like after months of ignoring the fact I can’t remove music assistant MASS…
It did disappear.
I don’t see it anymore in the HACS as installed. Weird…
Can you guys help survey if it’s worth trying again?
How many people is it working for again?
If it’s worth the chance of it being stuck in HA not working?
AndiT, Are you trying to remove it because it does not work? Did it ever work?
I installed MA just out of curiosity. I was only interested in listening to mp3 files and I didn’t succeed. Then I couldn’t remove it from the integration. I’ve read almost everything posted in the forum about this problem and I still can’t do it. I still use rAudio on a separate rpi for mp3 and web radio and control it through dnla in HA.
Thanks me too. But I was able to play mp3 from the same drive as ha for awhile, then an update broke it.
Sounds like it’s not worth trying again for now. :frowning:
