I have two sonos speakers in my kitchen that cannot be used as a stereo pair. I created a Flow below that I thought would mute one upon muting the other.
When I mute the Sonos on one, nothing happens on the other. Any ideas?
[{"id":"53df64923b25f0df","type":"api-call-service","z":"d4f9ac9d.d5ff08","name":"Mute Overhead","server":"8efa78ba.f10338","version":3,"debugenabled":false,"service_domain":"media_player","service":"volume_set","entityId":"media_player.kitchen_overhead","data":"{ \"volume_level\" : 0.0 }","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":440,"y":700,"wires":[[]]},{"id":"5e843241937da4d7","type":"switch","z":"d4f9ac9d.d5ff08","name":"","property":"data.new_state.attributes.is_volume_muted","propertyType":"msg","rules":[{"t":"eq","v":"true","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":270,"y":720,"wires":[["53df64923b25f0df"]]},{"id":"7950937dc2bd11f2","type":"server-state-changed","z":"d4f9ac9d.d5ff08","name":"Kitchen Mute","server":"8efa78ba.f10338","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"media_player.kitchen_tv_speaker","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":100,"y":720,"wires":[["5e843241937da4d7"]]},{"id":"8efa78ba.f10338","type":"server","name":"Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30}]
