Unfortunately I do not have any guess about the ssl error right now… Maybe after PyNaCl install is will go away. If not let me know and I’ll try to investigate further.
That worked. I actually found your second bit of advice on a freenas forum late last night and used it. The SSL errors are still occurring but reading the message make me think it’s receiving http request on the SSL port.
Any other ideas how to upgrade or overcome SSL issue. I’m still unable to manage my Ecobee Switches (homekit controller needed) and it’s failing on registration due to SSL issue.
Sorry no. From my understanding it’s not possible to upgrade the “base” BSD that is used when creating jails and the jail can not run a newer “base” version than the host. I’ve discovered this seems to be an ongoing issue for FreeNAS, it’s always been this way and likely always will. (I mean FreeNAS is usually behind the actual FreeBSD from which it’s based on. For example we are waiting for an update to FreeNAS 11.X but FreeBSD is actually on 12.X - In other words new FreeNAS is not even released yet and it’s already outdated in BSD terms)
You do have a few options but they not likely to be what you had in mind.
Personally I have no plans of switching to Hassio but I did follow @Koen’s link to give it a try. I was able to successfully get Hassio running using a VM in about 20 min.
This has been working perfectly for me for some months, with fairly infrequent updates. I think my last update to 0.102.3 has broken the mobile integration which now uses mobile_app: in the configuration.yaml.
With this added, I get the following error when checking the configuration:
Component error: mobile_app - Requirements for mobile_app not found: ['PyNaCl==1.3.0'].
Hi Troy. I spoke too soon. I was using the auto zwave component integration and my Zwave USB stick was showing up as a node in the Zwave configuration, so I assumed all was well. However, I finally got around to trying to add a Zwave device and it just wont pair. So, I decided to remove the auto integration as you suggested and add it to the config file manually. Now the USB stick doesn’t show up and the zwave configuration options in the UI aren’t available. I tried to generate a network key using the command from inside the jail but I get an “illegal byte sequence” error, so I can’t generate a code, but not sure it’s needed. It seems the manual addition of the zwave stick isn’t working. Any idea what could be wrong?
Sorry, I think that’s my fault. I copied this from old configuration.
I had python3.6 but it should be python3.7. Try this (I will also fixed this in my previous post)
Are you 100% certain you are actually in the jail. This is the exact error shown when I try to run the command on the FreeNAS host. For additional clarity, I have this time included the first command to ensure we’re operating inside the jail. Please try the following.
You don’t have to have a z-wave key but I think It’s strongly preferred that you do. The z-wave key is required to secure you z-wave network and it is likely required by any kind security device. Also you need to follow the docs when adding devices to your controller.
EDIT Reading through the docs myself (It’s been awhile) I see this has been added
Secure devices require additional bandwidth, and too many secure devices can slow down your Z-Wave network. We recommend only using secure inclusion for devices that require it, such as locks.
Thanks Troy - that enable me to generate the key (zwave_key: 0x37, 0xD5, etc placed in secrets.yaml), but the integration still isn’t working. The Zwave USB isn’t showing up as a node on the Zwave config page
Thanks Troy - it’s definitely there. I get the same output as your pic. I find that I can add the USB stick using the auto-integration menu and entering the usb destination as /dev/cuaU0. If I remove this integration and do it manually in the config file, it doesn’t get integrated.
When I wrote this guide the official docs were outdated, did not uses a virtualenv and ran HA as root. Recent updates to those docs have brought them more in line with this guide.
The main differences between my guide and what’s included in the official docs are personal choices and really have no effect on the end result of running Home Assistant.
Hi Troy,
I ran your Node-RED script to install into a new jailplugin. I also un-commented the panel iframe entry in your example config file to get the Nod-red icon to show up in the sidebar in HA. This gets me to my node-red instance, but node red isn’t seeing any of my HA entities as it isn’t integrated with HA. Pretty much every post on this subject seems to be about using the hass.io add-on. Any tips on how to get this working?
Hi @axg20202
Node-RED is just a generic plugin for FreeNAS (I guess not everyone uses HA) so there is nothing for HA configured by default. Honestly learning Node-RED is still on my ToDo list.
EDIT
I found it! After NR is installed I followed this video to configure with HA
