I have the exact same problem that only 1 of the 2 “M5Stack Atom Echo” that I programmed as a bluetooth proxy, won’t update. I can’t find anything in the log for an error. How do i solve this?
I don’t know where to look for the error message. In the logs I have looked in the log area ESPHome Device Builder and Home Assistant Core. I see nothing which I can connect to my Bluetooth proxy.
When you click on the ESP device that’s acting as the Bluetooth Proxy, do you have a disabled ‘Configuration’ entity that’s labeled ‘Firmware’? When that’s disabled you won’t receive any notifications for ESPHome updates for that device.
Now I really feel like a rookie.
Where do I adopt it? You can see in the original post where I can see this device and I can not find any adopt button there.
The parameter “Home Assistant Dashboard Configuration” was disabled so I enabled it and and restarted the add-on. I still do not see the Bluetooth proxy in the compiler dashboard.
Is it easier just to create it from scratch again?
