My Corona Virus card
So I created a nice little card for the corona virus sensor.
As I didn’t want to keep modifying it to set max, and the excellent bar-card by @Gluwc can’t use the “confirmed” directly, I got a hint from him about @iantrich excellent config template card and together with @thomasloven auto-entities it works nicely.
The result looks like this:
The config looks like this:
type: 'custom:config-template-card'
variables:
  - 'states[''sensor.worldwide_coronavirus_confirmed''].state'
  - 'states[''sensor.denmark_coronavirus_confirmed''].state'
entities:
  - sensor.worldwide_coronavirus_confirmed
  - sensor.denmark_coronavirus_confirmed
card:
  entities:
    - cards:
        - card:
            card_style:
              opacity: 0.7;
            max: '${vars[0]}'
            min: 0
            padding: 2px
            title_position: inside
            type: 'custom:bar-card'
          filter:
            include:
              - entity_id: '*worldwide_coronavirus*'
          sort: entity_id
          type: 'custom:auto-entities'
        - card:
            card_style:
              opacity: 0.7;
            max: '${vars[1]}'
            min: 0
            padding: 2px
            width: 100%
          filter:
            include:
              - entity_id: '*denmark_coronavirus*'
          sort: entity_id
      type: 'custom:hui-vertical-stack-card'
  show_header_toggle: false
  style: |
    ha-card {
      background-image: url('/local/images/corona.png');
      background-size: contain;
      background-position: center;
      background-repeat: no-repeat;
  title: Corona
  type: entities
So it’s a bit intricate.
The first card makes variables, and I take the ‘confirmed’ sensor and use it as a max for the bar graphs, so it will scale automatically.
Then it uses auto-entities to create the four sensors (sorted after entity_id name) and from that it creates each bar (each of them using the variable from the config template card.
I then made two, one for worldwide, and one for little old Denmark :slight_smile:
I glommed your card and added a few bits for me. Mini-graph card and a couple of iframes.
Good idea with the graph…
Do you mind posting your code?
Looks good guys. I’ve just done something similar.
Is there a way to have the coronavirus map centre in on a specific region or tab when it load up?
cards:
  - aspect_ratio: 150%
    type: iframe
    url: >-
      https://www.arcgis.com/apps/opsdashboard/index.html#/85320e2ea5424dfaaa75ae62e5c06e61
  - card:
      entities:
        - cards:
            - align_icon: right
              align_state: right
              entities:
                - sensor.us_coronavirus_confirmed
              font_size: 75
              group: true
              hours_to_show: 84
              icon: 'mdi:bug-outline'
              line_color: orange
              line_width: 2
              show:
                animate: true
                extrema: false
                fill: true
                icon: false
                labels: false
                legend: false
                points: true
                state: true
              state_adaptive_color: true
              type: 'custom:mini-graph-card'
              unit: US infected
              style: |
                ha-card {
                  background-image: url('/local/coronavirustrans.png');
                  background-size: cover;
                  'background-position: center;
                  'background-color: #cccccc; /* Used if the image is unavailable */
                  'height: 100; /* You must set a specified height */
                  background-size: cover; /* Resize the background image to cover the entire container */
            - card:
                card_style:
                  opacity: 0.8;
                max: '${vars[0]}'
                min: 0
                padding: 2px
              filter:
                include:
                  - entity_id: '*us_coronavirus*'
              sort: entity_id
      theme: darkcyan3
      type: entities
    entities:
  - aspect_ratio: 70%
    type: iframe
    url: >-
      https://www.cdc.gov/coronavirus/2019-ncov/cases-in-us.html#reporting-cases
path: cov19
title: Cov-19
You’ll also need card-mod for the background image to work.
darkcyan3:
# Main colors that can be changed
  primary-color: "#00bcd4"                   # light blue 42%
  disabled-text-color: "#2b2b2b"             # light gray  (me)
  divider-color: "rgba(255, 255, 255, 0.12)"
  paper-card-background-color: "#9e9e9e"     # Lt gray  (me)
  paper-grey-200: "#191919"                  # very dark gray 10%
  paper-item-icon-color: "#d3d3d3"           # light gray 83%
  paper-listbox-background-color: "#202020"  # dark gray 13%
  paper-listbox-color: "#FFFFFF"             # white
  primary-background-color: "#eeeeee"        # dark gray 19%
  primary-text-color: "#cfcfcf"              # light gray 81%
  secondary-background-color: "#eeeeee"      # dark gray 17%
  secondary-text-color: "#04a7bc"            # blue 38%
  sidebar-icon-color: "#4e4e4e"              # light gray 80% (me)
  light-primary-color: "#0066ff"             # blue, profile button, slider on
  #sidebar-background-color: "#0000ff"       # medium blue (me), bottom half
# Colors based on variables, see above
  label-badge-background-color: "var(--secondary-background-color)"
  label-badge-text-color: "var(--text-primary-color)"
  paper-card-header-color: "#var(--paper-item-icon-color)"
  paper-grey-50: "var(--primary-text-color)"
  paper-item-icon-active-color: "var(--primary-color)"
  paper-item-icon_-_color: "var(--primary-text-color)"
  paper-slider-active-color: "var(--primary-color)"
  paper-slider-knob-color: "var(--primary-color)"
  paper-slider-knob-start-color: "var(--primary-color)"
  paper-slider-pin-color: "var(--primary-color)"
  paper-slider-secondary-color: "var(--light-primary-color)"
  paper-toggle-button-checked-ink-color: "var(--dark-primary-color)"
  paper-toggle-button-checked-button-color: "var(--primary-color)"
  paper-toggle-button-checked-bar-color: "var(--light-primary-color)"
  paper-toggle-button-unchecked-bar-color: "var(--primary-text-color)"
  ha-card-border-radius: 20px
  ha-card-background: "#505050"
coronavirustrans
Since deaths+recovered+current=confirmed, maybe we can have a unique bar per country.
You mean a stacked bar graph, right? The bar-card does not currently support it.
Exactly what I meant. Thanks.
Not much experience with adding cards. Where would I add that code? Into raw configuration or into another file and call it from raw? Thanks in advance, awesome card.
Hi @roco17
Welcome aboard, I hope I can lend you a hand here…
Not sure if it’s my version or the other, but anyways.
First off you need to add the integration of the corona sensors.
Then you need to add the custom cards from eg. HACS.
Then you add a ‘Manual card’ and basicly just paste this into it.
I tweaked it a little as the CDC page didn’t add much and they rarely update my state. I will post it if wanted.
Yes, please share code.
Wow! That’s looks like a desktop from “Pandemic”, and I guess now it is! Surreal! I really love the the clean lines/space/layout and color palette! I would not have predicted the combo would look so fresh, it pops! Kuddos! Please share :slightly_smiling_face:
Hey another Bama HA user! Where did you find the state by county map?
Terry
Glad y’all (for authenticity) find it useful. Let me know if you need help getting it going. This is a copy of the whole tab from the raw config editor. Just paste 'er in.
Cards needed: mini-graph, bar-card, hui-vertical-stack-card, auto-entities, config-template-card, card-mod
Cheers.
  - background: center / cover no-repeat url("/local/covid19-background.jpg") fixed
    badges: []
    cards:
      - cards:
          - entities:
              - align_header: center
                align_icon: left
                align_state: right
                bar_spacing: 2
                entities:
                  - color: orange
                    entity: sensor.corona_virus_alabama_confirmed
                    unit: "\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_Alabama infected"
                  - color: red
                    entity: sensor.corona_virus_alabama_deaths
                    unit: "\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_Alabama Deaths"
                font_size: 75
                font_size_header: 1
                group: false
                height: 100
                hours_to_show: 84
                icon_adaptive_color: true
                labels_secondary: true
                line_width: 2
                name_adaptive_color: false
                show:
                  animate: true
                  extrema: false
                  fill: true
                  graph: line
                  icon: false
                  labels: false
                  legend: true
                  points: true
                  state: true
                style: |
                  ha-card {
                    background: #202020;
                    background-image: url('/local/alabama-map.png');
                    background-position: 53% 50%;
                    background-repeat: no-repeat no-repeat;
                    background-size: 20%;
                    color: white;
                    font-family: Arial;
                    font-weight: 900;
                    border: 3px ridge  #404040 ;
            style: |
              ha-card {
                background: black;
                font-weight: bolder;
                color: white;
            tap_action:
              action: navigate
              navigation_path: 'https://data.montgomeryadvertiser.com/coronavirus/'
            type: entities
          - aspect_ratio: 124%
            theme: darkcyan3
            type: iframe
            url: >-
        type: vertical-stack
      - cards:
          - card:
              entities:
                - cards:
                    - align_icon: right
                      align_state: right
                      bar_spacing: 2
                      entities:
                      font_size: 75
                      group: false
                      hours_to_show: 84
                      line_color: orange
                      line_width: 2
                      show:
                        animate: true
                        extrema: false
                        fill: true
                        graph: line
                        icon: false
                        labels: false
                        legend: false
                        points: true
                        state: true
                      state_adaptive_color: false
                      style: |
                        ha-card {
                          font-family: Arial;
                          font-weight: 900;
                          color: white;
                          border: 3px ridge #404040;
                      unit: "\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_US infected"
                    - card:
                        align: null
                        card_style:
                          line-height: 33px
                          text-indent: 3px
                        color: '#008b8b'
                        max: '${vars[0]}'
                        min: 0
                        padding: 5px
                        unit_of_measurement: ''
                      filter:
                        include:
                      sort: entity_id
              style: |
                ha-card {
                  padding: 0px;
                  background: black;
                  font-weight: bold;
                  color: white;
              theme: darkcyan3
              type: entities
            entities:
            variables:
              - 'states[''sensor.us_coronavirus_confirmed''].state'
          - card:
              entities:
                - cards:
                    - align_icon: right
                      align_state: right
                      bar_spacing: 2
                      entities:
                      font_size: 75
                      group: false
                      hours_to_show: 84
                      line_color: orange
                      line_width: 2
                      show:
                        animate: true
                        extrema: false
                        fill: true
                        graph: line
                        icon: false
                        labels: false
                        legend: false
                        points: true
                        state: true
                      style: |
                        ha-card {
                          font-family: Arial;
                          font-weight: 900;
                          color: white;
                      unit: "\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_World infected"
                    - card:
                        align: null
                        card_style:
                          line-height: 33px
                          text-indent: 3px
                        color: '#008b8b'
                        max: '${vars[0]}'
                        min: 0
                        padding: 5px
                      filter:
                        include:
                      sort: entity_id
                      style: |
                        ha-card {
                          line-height: 2.5;
                          color: white;
              style: |
                ha-card {
                  padding: 0px;
                  background: black;
                  font-weight: bold;
                  color: white;
              theme: darkcyan3
              type: entities
            entities:
            variables:
    panel: false
    path: cov19
    title: Cov-19
covid19-background
It doesn’t seem to scale the bar-graph correctly, just full bars, and I don’t see the variables defined anywhere in your code?
Oh, yeah. I stripped some stuff out troubleshooting an issue and forgot to re-add :slight_smile:
Fixed above
