Hello…
My esphome group of devices is growing and after having 2 d1 mini based air quality sensors now, i experience that those do stop working after some time and do not respond anymore until i power cycle them.
How can i troubleshoot them when i cannot get the logs off them when they did fail?
Would like to sort that issue out asap…
P.s.
Esphome is updated, code for devices follows in a minute
esphome:
friendly_name: IAQmonitor2
platform: ESP8266
board: d1_mini
# Disable logging over UART (required)
logger:
baud_rate: 0
# Enable Home Assistant API
api:
encryption:
Key="
ota:
password: "2a17beda57d69"
wifi:
networks:
- ssid: given
manual_ip:
# Set this to the IP of the ESP
static_ip: 192.168.given
# Set this to the IP address of the router. Often ends with .1
gateway: 192.168.given
# The subnet of the network. 255.255.255.0 works for most home networks.
subnet: 255.255.255.0
- ssid:
manual_ip:
ap:
ssid: "Iaqmonitor2 Fallback Hotspot"
password: ""
captive_portal:
# Enable Web server.
web_server:
port: 80
time:
- platform: homeassistant
# Text sensors with general information.
text_sensor:
# Expose ESPHome version as sensor.
- platform: version
# Expose WiFi information as sensors.
- platform: wifi_info
ip_address:
mac_address:
ssid:
# Sensors with general information.
# Uptime sensor.
- platform: uptime
filters:
- lambda: return x / 60.0;
unit_of_measurement: minutes
# WiFi Signal sensor.
- platform: wifi_signal
name: AirQuali2 WiFi Signal
update_interval: 60s
- platform: pmsx003
type: PMSX003
uart_id: uart_1
pm_1_0:
name: "Fein Partikel <1.0µm: "
pm_2_5:
name: "Fein Partikel <2.5µm: "
pm_10_0:
name: "Fein Partikel <10.0µm: "
- platform: scd30
co2:
accuracy_decimals: 1
temperature:
accuracy_decimals: 2
humidity:
temperature_offset: 1.5 °C
address: 0x61
i2c_id: bus_a
update_interval: 5s
i2c:
- id: bus_a
sda: D1
scl: D2
scan: true
# - id: bus_b
# sda: D7
# scl: D8
# scan: true
uart:
- rx_pin: D6
tx_pin: D5
baud_rate: 9600
font:
- file: "monofont.ttf"
display:
- platform: ssd1306_i2c
address: 0x3C
i2c_id: bus_a
model: "SSD1306 64x48"
pages:
- id: page1
lambda: |-
it.printf(0, 0, id(opensans), "CO2: %.0fppm", id(co2).state);
it.printf(0, 10, id(opensans), "PM10 : %.0f", id(pm10).state);
it.printf(0, 20, id(opensans), "PM25 : %.0f", id(pm25).state);
it.printf(0, 30, id(opensans), "PM100: %.0f", id(pm100).state);
- id: page2
lambda: |-
it.printf(0, 20, id(opensans), "Hmdty: %.0f", id(humidity).state);
it.printf(0, 30, id(opensans), "Temp: %.0fC", id(temp).state);
interval:
- interval: 5s
then:
- display.page.show_next: oled
- component.update: oled
- interval: 120s
then:
- switch.turn_on: pms_set
- delay: 20s
- switch.turn_off: pms_set
switch:
- platform: gpio
pin:
number: D3
name: "Start measuring"
number:
name: "CO2 calibration value"
optimistic: true
min_value: 350
max_value: 4500
step: 1
icon: "mdi:molecule-co2"
entity_category: "config"
button:
name: "SCD30 Force manual calibration"
on_press:
then:
- scd30.force_recalibration_with_reference:
value: !lambda 'return id(co2_cal).state;'
