I’m also using AEON Labs ZW090 Z-Stick Gen5 EU, and can confirm that it works perfect. Lock/unlock as well as adding usercodes to the Danapad. The Danapad doesn’t show up yet, but they’ve promised to add support for Danapad as well.
I couldn’t get the service call to work in HA though, so I had to set usercodes via z-wave admin UI.
I never did the “get_usercode” step, so that’s not necessary to get the lock working.
When adding the lock I took it from where I originally mounted it and did the inclusion near the z-wave USB dongle. After successful inclusion I installed the lock at the final location, did an auto-calibration, and finally a “Heal node” (+ inclusion mode on the lock to wake it up).
Super happy with the lock after having used it extensively for several hours
It definately suits my need for my AirBnB cottage.
What do you mean with “The Danapad doesn’t show up yet, but they’ve promised to add support for Danapad as well”?
Who promised to add support for Danapad?
Can you see who unlocked the lock in homeassistant with the Danapad?
I thought it would show up in HA as a separate device, but that’s not the case.
Atm you need to send user codes to Danalock via the z-wave UI in HA directly, and the codes work from Danapad. I guess that means OZW has support for user codes.
Hopefully there will be a proper UI for it in HA as well as a way to use it in automations.
I think Danalock syncs the user codes with Danapad. At least it looks like there’s a sync when I manage the Danapad in the Danalock app.
I can’t see who unlocked the lock (besides HA) in HA.
I am quite new to this HA and Z-wave setup. But I have spend a lot time the last couple of weeks.
I can see you got it to work, which gave me hope
I have tried so many things, but to be honest, I am doing it blindfold, as I don’t know what and how exactly to do it. I have managed to get a node called “Poly-control Danalock V3 BTZE Locked” in my Z-wave node management and some data.
But no matter what I do i cannot lock or unlock the Doorlock?
Are you able and willing to help me get it to work or direct me to a guide?
bit hit and miss for me too. I got a brand new Danalock v3, updated the firmware to the latest 0.16.0, managed to connect to HA over zwave fine, and even managed to set usercodes in HA.
However, when I had to reset everything, reinstall HA, factory reset the Danalock v3, had “remove node” in HA prior to any actions, removed the Danalock v3 from the app, basically started completed again, it will no longer show the “usercode” sensor so I can’t actually set/get any user codes anymore.
It does still lock and unlock in HA absolutely fine, but usercodes is missing.
I’ve repeated the “factory reset” of everything numerous times too.
Incidentally, the Call service “lock.get_usercode” with service data method still doesn’t add it back in.
Yes I have also realized that. I have done some investigation about the same problem.
Found what the lock is capable of https://products.z-wavealliance.org/products/2556/configs
Danalock Support was not helping att all.
The DanaLock is good only if you are planing to use it with bluetoot and not in any automations
