My device burst after using a yaml code. I am not here to argue but get some help
My current yaml which works:
esphome:
  friendly_name: "tinxy-4n-myroom"
  on_boot:
    - priority: 200.0
      then:
        - output.turn_on: gen_pwm_test
        - output.set_level:
            level: 50%
  includes:
    - uart_read_line_sensor.h
output:
  - platform: esp8266_pwm
    pin: GPIO14
    frequency: 1000 Hz
    type: float
    write_action:
    - uart.write: ""
esp8266:
  board: esp01_1m
# Enable logging
logger:
  baud_rate: 0
  level: verbose
# Enable Home Assistant API
api:
ota:
  platform: esphome
wifi:
  manual_ip:
    static_ip: 192.168.86.144
    gateway: 192.168.86.1
    subnet: 255.255.255.0
  ssid: !secret wifi_ssid
  power_save_mode: none
  fast_connect: true
# status_led:
#   pin:
#     number: GPIO12
#     inverted: yes
uart:
  tx_pin: 1
  rx_pin: 3
  baud_rate: 115200
text_sensor:
  - platform: custom
    lambda: |-
      auto my_custom_sensor = new UartReadLineSensor(id(uart_bus));
      App.register_component(my_custom_sensor);
      return {my_custom_sensor};
    text_sensors:
      name: "UART Feedback"
      on_value:
        then:
          - lambda: |-
              ESP_LOGD("main", "The current value is %s", x.c_str());
              if (id(uart_readline).state == "41") {
                id(relay4_wall_switch).publish_state(true);
                id(relay4).turn_on();
              } if(id(uart_readline).state == "40") {
                id(relay4_wall_switch).publish_state(false);
                id(relay4).turn_off();
              if (id(uart_readline).state == "31") {
                id(relay3_wall_switch).publish_state(true);
                id(relay3).turn_on();
              } if(id(uart_readline).state== "30") {
                id(relay3_wall_switch).publish_state(false);
                id(relay3).turn_off();
              if (id(uart_readline).state == "21") {
                id(relay2_wall_switch).publish_state(true);
                id(relay2).turn_on();
              } if(id(uart_readline).state== "20") {
                id(relay2_wall_switch).publish_state(false);
                id(relay2).turn_off();
              if (id(uart_readline).state == "11") {
                id(relay1_wall_switch).publish_state(true);
                auto call = id(fan_1).turn_on();
                call.perform();
              } if(id(uart_readline).state== "10") {
                id(relay1_wall_switch).publish_state(false);
                auto call = id(fan_1).turn_off();
                call.perform();
              } if (id(uart_readline).state == "13") {
                auto call = id(fan_1).turn_on().set_speed(1);
                call.perform();
              } if (id(uart_readline).state == "14") {
                auto call = id(fan_1).turn_on().set_speed(2);
                call.perform();
              } if (id(uart_readline).state == "15") {
                auto call = id(fan_1).turn_on().set_speed(3);
                call.perform();
binary_sensor:
    name: "Relay4 Wall Switch"
    name: "Relay3 Wall Switch"
    name: "Relay2 Wall Switch"
    name: "Relay1 Wall Switch"
switch:
  - platform: gpio
    pin: GPIO12
    optimistic: true
    restore_mode: RESTORE_DEFAULT_OFF
    turn_on_action:
      - uart.write: '#2100#'
    turn_off_action:
      - uart.write: '#2000#'
    optimistic: true
    turn_on_action:
      - uart.write: '#3100#'
    turn_off_action:
      - uart.write: '#3000#'
    optimistic: true
    turn_on_action:
      - uart.write: '#4100#'
    turn_off_action:
      - uart.write: '#4000#'
fan:
  - platform: speed
    output: fanoutput
    speed_count: 3
    on_turn_on:
      - uart.write: !lambda |-
          static std::string myUartStringsOn[4] = {"#1100#", "#1033#", "#1066#", "#1100#"};
          if(id(fan_1).speed == 0)
            id(fan_1).speed = 1;
          std::string chosenString = myUartStringsOn[id(fan_1).speed];
          std::vector<uint8_t> vec(chosenString.begin(), chosenString.end());
          return vec;
    on_turn_off:
      - uart.write: '#1000#'
    on_speed_set:
    - if:
        condition:
          lambda: return (id(fan_1).state);
        then:
              return vec;
number:
    optimistic: true
    restore_value: true
    initial_value: "60"
    min_value: 5
    max_value: 100
    step: 1
    set_action:
      then:
            int multiplexer = 625 + static_cast<int>((x - 5) * 25);
            String uartValue = "(";
            if (multiplexer < 1000) {
              uartValue += "0";
            uartValue += String(multiplexer, DEC) + ")";
            std::vector<unsigned char> uartBytes(uartValue.begin(), uartValue.end());
            return uartBytes;
Uart reading library
#include "esphome.h"
class UartReadLineSensor : public Component, public UARTDevice, public TextSensor {
 public:
  UartReadLineSensor(UARTComponent *parent) : UARTDevice(parent) {}
  void setup() override {
    // nothing to do here
  int readline(int readch, char *buffer, int len)
    static int pos = 0;
    int rpos;
    if (readch > 0) {
      switch (readch) {
        case ';': // Return on CR
          rpos = pos;
          pos = 0;  // Reset position index ready for next time
          return rpos;
        default:
          if (pos < len-1) {
            buffer[pos++] = readch;
            buffer[pos] = 0;
    // No end of line has been found, so return -1.
    return -1;
  void loop() override {
    const int max_line_length = 20;
    static char buffer[max_line_length];
    while (available()) {
      if(readline(read(), buffer, max_line_length) > 0) {
        publish_state(buffer);
I used this code below which made the device to burst and made the device to stop working.
  // Synchronize ESPHome with actual fan state based on switch feedback
              if (id(uart_readline).state == "10" && id(fan_1).state) {
                call.perform();
                ESP_LOGD("sync", "Fan state corrected to OFF due to switch state '10'.");
              } else if (id(uart_readline).state == "11" && !id(fan_1).state) {
                call.perform();
                ESP_LOGD("sync", "Fan state corrected to ON due to switch state '11'.");
More images - Imgur: The magic of the Internet
I have a feeling this happened because both UART code logic and this code is trying to update the virtual switch in HA dashboard at the same time, and it caused it. I am not sure. All I know is I updated this code and turned off the switch, I heard the first spark. The second time I turned on the switch heard spark again and lost the device.
I am NOT here to argue or prove myself right or say esphome did it. I am here trying to find the right yaml code to make it work with my device. I gave this piece of information to help find the right yaml code and reuse the old code which made the device stop working.
More information on discord thread where I was getting help trying to sync HA virtual switch with the physical wall switch – Discord
I am trying to make my fan switch work like a one way switch. Only my fan switch doesn’t work like a one way switch and it works like a two-way switch. All my other 3 relay switches work like an on-way switch. I am just trying to make my fan switch make it work like a one-way switch, which is what I am trying to do. Any input, advice, suggestion is highly appreciated. Thank you!
That looks like a capacitor failure on the mains voltage side. They can fail like that for a few reasons, one being electrical over-stress from the mains - but it’s highly unlikely that it failed due to anything that your code. Just bin the unit and try again.
