Hi everyone,
I use a DIY reverse-osmosis water purifier at home. Its original controller handled the basics, but I wanted to see more than a few numbers on the front panel—and bring that information into Home Assistant.
I’ve now installed an ESP32-based controller built around yuunt’s open-source Youth Edition V2.3 board. I assembled the board and developed the firmware for my setup. It has a local web interface for configuration and monitoring, and publishes data to Home Assistant through a local MQTT broker.
AI-generated product visualization based on photos of my first working prototype. The enclosure and installation are still being refined.
Depending on the sensors fitted, it can report:
- Operating state, such as standby or water production
- Feed and product water TDS
- Water temperature
- Product and waste water flow
I also made three companion dashboard cards: a full water-circuit view, a compact status card, and a water-quality history card using Home Assistant’s recorded data.
Preview of the full Home Assistant card with example data, rather than live readings from my purifier.
The Home Assistant integration is currently read-only. It displays what the controller reports; it doesn’t start the pump or operate the valves. Configuration and control remain in the controller’s own web interface.
This is the first working version, already running in my purifier. The printed enclosure, mounting and cable routing still need improvement, and I’m continuing to test the system during everyday use.
I’ve put the compatibility checks, parts, wiring, firmware installation and enclosure files together on my blog:
Full build guide on GutsyMaker →
The dashboard cards are open source:
water-purifier-card on GitHub →
The controller firmware is available as a compiled download for this specific board; its source code is not currently public.
If you monitor an RO system in Home Assistant, I’d be interested to hear which readings you find most useful in everyday use.
