esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: !secret ssid
fast_connect: true
# Enable logging
logger:
substitutions:
alpha: 90%
intensity: 5%
default_transition_length: 0s
frequency: 1000 Hz
# Enable Home Assistant API
api:
ota:
light:
- platform: monochromatic
output: candle_1_pwm
default_transition_length: ${default_transition_length}
effects:
- flicker:
alpha: ${alpha}
intensity: ${intensity}
output: candle_2_pwm
effects:
- flicker:
alpha: ${alpha}
output: candle_3_pwm
effects:
- flicker:
alpha: ${alpha}
output: candle_4_pwm
effects:
- flicker:
alpha: ${alpha}
output: candle_5_pwm
effects:
- flicker:
alpha: ${alpha}
output: candle_6_pwm
effects:
- flicker:
alpha: ${alpha}
output:
- platform: esp8266_pwm
pin: D1
frequency: $frequency
pin: D2
pin: D3
pin: D5
pin: D6
pin: D7
For more infomation, see my Github page: https://github.com/3ative/Smart-Candles
