I had a hard time finding a solution for my problem I had so I decided to share it, for who ever may ever need it.
I have shutters/covers/rolladen (german) / rolluiken (dutch)/… When I press the up button, they go up and when I press it again they stop moving. Same for going down.
My biggest problem is that all my wall switches (light and shutters) only send a 24v signal to my electric system that then triggers a teleruptor/relay that then activates the 230v switch.
With an ESP32 and a relay board I can simulate this signal and I can control my lights and shutters.
Thanks to ESPhome I could make time based covers after some thinking and reading.
How I setup my GPIO switch control:
switch:
- platform: gpio
name: "Keuken achter omhoog"
pin:
number: 32
inverted: yes
- platform: gpio
name: "Keuken achter omloog"
pin:
number: 33
inverted: yes
- platform: gpio
name: "Living achter omhoog"
pin:
number: 25
inverted: yes
Then I added 2 template binary sensors that I use to control the covers.
binary_sensor:
name: "Keuken gesloten"
With the binary sensors I can choose which stop action has to be called. Because if they are going down and the stop action is both up and down (omhoog en omlaag) the shutter will always go up again. That’s why when I do the open action it triggers one sensor to on and the other to off…
cover:
- platform: time_based
has_built_in_endstop: true
open_action:
- switch.turn_on: keukenomhoog
- binary_sensor.template.publish:
state: ON
state: OFF
open_duration: 35s
close_action:
- switch.turn_on: keukenomlaag
state: ON
state: OFF
close_duration: 33s
stop_action:
- if:
condition:
- binary_sensor.is_on: keukenopen
then:
- if:
condition:
- binary_sensor.is_on: keukengesloten
then:
Maybe there is a proper/better way to solve this, maybe there ain’t.
It’s just to help out some one else if ever needed
Just to have more examples out there, I’d like to share what my settings look like:
switch:
- platform: gpio
pin:
number: GPIO12
inverted: True
on_turn_on:
- delay: 500ms
- switch.turn_off: blind_down
interlock: [blind_up, blind_stop]
internal: True
- platform: gpio
pin:
number: GPIO14
inverted: True
on_turn_on:
- delay: 500ms
- switch.turn_off: blind_up
interlock: [blind_down, blind_stop]
internal: True
- platform: gpio
pin:
number: GPIO13
inverted: True
on_turn_on:
- delay: 500ms
- switch.turn_off: blind_stop
interlock: [blind_down, blind_up]
internal: True
cover:
device_class: shutter
open_duration:
seconds: 48
close_duration:
seconds: 48
open_action:
then:
- switch.turn_on: blind_up
stop_action:
then:
- switch.turn_on: blind_stop
close_action:
then:
- switch.turn_on: blind_down
Does somebody have a YAML for the bk7231n based MOES WS-Y-EUTC-WH-MS ?
This is also a cover controller, but it has 3 touch buttons on the front ( up, stop , down)
I already flashed it with cloudcutter/libretiny but the availabe YAML is configured as if it’s a lightswitch with 2 relays.
how to incorporate this module using the cover platform, and also interlocks so you don’t fry the motor ?
I did something that you can use:
esphome:
bk72xx:
board: generic-bk7231n-qfn32-tuya
logger:
web_server:
captive_portal:
mdns:
api:
password: ""
ota:
password: ""
wifi:
use_address: ${ip}
ssid: !secret wifi_ssid
ap:
button:
- platform: restart
debug:
update_interval: 30s
text_sensor:
- platform: debug
reset_reason:
- platform: libretiny
version:
- platform: uptime
# Note: you may try to comment that line if the Wi-Fi connection is not stable...
#power_save_mode: high
- platform: wifi_signal
update_interval: 1min
# status_led:
# id: led_status
# pin: GPIO2
switch:
- platform: gpio
pin: GPIO11
- platform: gpio
pin: GPIO14
restore_mode: ALWAYS_OFF
- platform: gpio
pin: GPIO08
- platform: gpio
pin: GPIO23
- platform: gpio
pin: GPIO06
interlock: [down_relay]
- platform: gpio
pin: GPIO09
interlock: [up_relay]
binary_sensor:
- platform: gpio
pin:
number: GPIO24
inverted: true
on_press:
then:
- if:
condition:
lambda: 'return id(shutter_${device_name}).position != COVER_OPEN;'
then:
- cover.open: shutter_${device_name}
- switch.turn_on: led_up_red
- platform: gpio
pin:
number: GPIO10
inverted: true
on_press:
- cover.stop: shutter_${device_name}
- switch.turn_on: led_stop_red
on_release:
- switch.turn_off: led_stop_red
- platform: gpio
pin:
number: GPIO07
inverted: true
on_press:
then:
- if:
condition:
lambda: 'return id(shutter_${device_name}).position != COVER_CLOSED;'
then:
- cover.close: shutter_${device_name}
- switch.turn_on: led_down_red
number:
name: ${upper_device_name} open duration time
optimistic: True
initial_value: ${open_duration_time_number_init_value}
min_value: 0
max_value: 100
step: 1
set_action:
lambda: !lambda |-
auto value = x;
id(open_duration_time).publish_state(value);
on_value:
then:
lambda: !lambda |-
auto duration_in_seconds = static_cast<uint32_t>(id(open_duration_time).state) * 1000;
id(shutter_${device_name}).set_open_duration(duration_in_seconds);
disabled_by_default: False
mode: AUTO
update_interval: 60s
name: ${upper_device_name} close duration time
optimistic: True
initial_value: ${close_duration_time_number_init_value}
min_value: 0
max_value: 100
step: 1
on_value:
then:
lambda: !lambda |-
id(shutter_${device_name}).set_close_duration(duration_in_seconds);
mode: AUTO
cover:
open_action:
- switch.turn_on: up_relay
open_duration: ${open_duration_time}
close_action:
- switch.turn_on: down_relay
close_duration: ${close_duration_time}
stop_action:
- switch.turn_off: up_relay
- switch.turn_off: led_up_red
- switch.turn_off: down_relay
- switch.turn_off: led_down_red
and you need to use it with this:
substitutions:
ip: YOUR_DESIRED_IP_ADDRESS
device_name: master_bedroom
upper_device_name: Master Bedroom
open_duration_time: 18s
close_duration_time: 18s
open_duration_time_number_init_value: "18"
close_duration_time_number_init_value: "18"
<<: !include shutter_moes_common.yaml
I am still having problems to control the open and close duration from home assistant.
