I’ve used an mqtt triggered automation to download an image from my zoneminder server using the downloader
component. The component is required to have a download_dir
set but now the action MUST ALSO have a subdir set or it silently fails.
I have had a few zoneminder triggers over the last day that come up without an image and I finally sat down to dig into it. I found that the subdir
which the docs say is optional actually is required as of 2021.2.2.
Here’s the pull request in 2021.2.2: https://github.com/home-assistant/core/pull/46061
I just wanted to mention it because if others are using this component and wondering why they’re not getting their downloads, this might help them to figure it out.
