My F@st3890 upnp modem stopped working
‘’'Suddenly it stopped working
Logger: homeassistant.config_entries
Source: helpers/entity_component.py:181
First occurred: 21.31.15 (2 occurrences)
Last logged: 21.31.15
Error unloading entry Sagemcom F@st3890V3 for binary_sensor
Error unloading entry Sagemcom F@st3890V3 for sensor
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 443, in async_unload
    result = await component.async_unload_entry(hass, self)  # type: ignore
  File "/usr/src/homeassistant/homeassistant/components/binary_sensor/__init__.py", line 154, in async_unload_entry
    return await component.async_unload_entry(entry)
  File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 181, in async_unload_entry
    raise ValueError("Config entry was never loaded!")
ValueError: Config entry was never loaded!
and more
Source: components/upnp/device.py:65
First occurred: 21.32.09 (1 occurrences)
Last logged: 21.32.09
Error setting up entry Sagemcom F@st3890V3 for upnp
  File "/usr/local/lib/python3.9/site-packages/async_upnp_client/aiohttp.py", line 110, in async_do_http_request
    async with self._session.request(
  File "/usr/local/lib/python3.9/site-packages/aiohttp/client.py", line 1117, in __aenter__
    self._resp = await self._coro
  File "/usr/local/lib/python3.9/site-packages/aiohttp/client.py", line 520, in _request
    conn = await self._connector.connect(
  File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 535, in connect
    proto = await self._create_connection(req, traces, timeout)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 892, in _create_connection
    _, proto = await self._create_direct_connection(req, traces, timeout)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 1020, in _create_direct_connection
    transp, proto = await self._wrap_create_connection(
  File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 969, in _wrap_create_connection
    return await self._loop.create_connection(*args, **kwargs)  # type: ignore  # noqa
  File "/usr/local/lib/python3.9/asyncio/base_events.py", line 1041, in create_connection
    sock = await self._connect_sock(
  File "/usr/local/lib/python3.9/asyncio/base_events.py", line 955, in _connect_sock
    await self.sock_connect(sock, address)
  File "/usr/local/lib/python3.9/asyncio/selector_events.py", line 502, in sock_connect
    return await fut
asyncio.exceptions.CancelledError
  File "/usr/local/lib/python3.9/site-packages/async_upnp_client/aiohttp.py", line 115, in async_do_http_request
    resp_body = await response.text()
  File "/usr/local/lib/python3.9/site-packages/async_timeout/__init__.py", line 55, in __aexit__
    self._do_exit(exc_type)
  File "/usr/local/lib/python3.9/site-packages/async_timeout/__init__.py", line 92, in _do_exit
    raise asyncio.TimeoutError
asyncio.exceptions.TimeoutError
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 304, in async_setup
    result = await component.async_setup_entry(hass, self)  # type: ignore
  File "/usr/src/homeassistant/homeassistant/components/upnp/__init__.py", line 122, in async_setup_entry
    device = await Device.async_create_device(hass, location)
  File "/usr/src/homeassistant/homeassistant/components/upnp/device.py", line 65, in async_create_device
    upnp_device = await factory.async_create_device(ssdp_location)
  File "/usr/local/lib/python3.9/site-packages/async_upnp_client/client_factory.py", line 68, in async_create_device
    root = await self._async_get_url_xml(description_url)
  File "/usr/local/lib/python3.9/site-packages/async_upnp_client/client_factory.py", line 345, in _async_get_url_xml
    status_code, _, response_body = await self.requester.async_http_request(
  File "/usr/local/lib/python3.9/site-packages/async_upnp_client/client.py", line 78, in async_http_request
    ) = await self.async_do_http_request(method, url, headers=headers, body=body)
  File "/usr/local/lib/python3.9/site-packages/async_upnp_client/aiohttp.py", line 117, in async_do_http_request
    raise UpnpConnectionTimeoutError from err
async_upnp_client.exceptions.UpnpConnectionTimeoutError```
