This alarm clock was failing quite regularly for me, so I have simplified it even more (than my other simplification post above) using a node called lullaby that is a light dimmer / brightener node. See the code…
The only additions in YAML that you need are an input datetime for the time input, and and input boolean which sets the alarm to come on at weekends too:
input_datetime:
alarmclock_time:
has_date: false
has_time: true
alarm_clock_weekend:
name: Alarm Clock Weekend?
initial: off
[{"id":"7342fdca.164ea4","type":"tab","label":"Alarm Clock","disabled":false,"info":""},{"id":"62de93c4.49444c","type":"comment","z":"7342fdca.164ea4","name":"TRIGGER ALARM CLOCK","info":"","x":150,"y":40,"wires":[]},{"id":"c4c471e7.851ff","type":"comment","z":"7342fdca.164ea4","name":"Snooze","info":"","x":90,"y":440,"wires":[]},{"id":"d2bad75.095dd28","type":"trigger-state","z":"7342fdca.164ea4","name":"alarm time","server":"cfa79f02.db9d4","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityid":"input_datetime.alarmclock_time","entityidfiltertype":"exact","debugenabled":false,"constraints":[],"constraintsmustmatch":"all","outputs":2,"customoutputs":[],"outputinitially":true,"state_type":"str","x":130,"y":100,"wires":[["4719f95.75ab108"],[]]},{"id":"4719f95.75ab108","type":"function","z":"7342fdca.164ea4","name":"set time - offset","func":"varAlarmTime = msg.payload;\nmsg.payload = {};\nmsg.payload.ontime = varAlarmTime\nmsg.payload.offtime = varAlarmTime\nmsg.payload.onoffset = -10\nreturn msg;","outputs":1,"noerr":0,"x":340,"y":100,"wires":[["d96d39ad.ed5278"]]},{"id":"17905c3e.7d4484","type":"api-current-state","z":"7342fdca.164ea4","name":"alarm set?","server":"cfa79f02.db9d4","version":1,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_boolean.house_option_alarmclock","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":870,"y":100,"wires":[["b4516dd2.ce5ee","89749a12.b85598"],[]]},{"id":"2293775.967dc88","type":"function","z":"7342fdca.164ea4","name":"set day","func":"varAlarmDay = msg.payload;\nmsg.payload = {};\nmsg.payload.sat = varAlarmDay\nmsg.payload.sun = varAlarmDay\n\nreturn msg;","outputs":1,"noerr":0,"x":320,"y":200,"wires":[["d96d39ad.ed5278"]]},{"id":"cc6a712c.05a1d","type":"trigger-state","z":"7342fdca.164ea4","name":"alarm day","server":"cfa79f02.db9d4","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityid":"input_boolean.alarm_clock_weekend","entityidfiltertype":"exact","debugenabled":false,"constraints":[],"constraintsmustmatch":"all","outputs":2,"customoutputs":[],"outputinitially":true,"state_type":"str","x":120,"y":160,"wires":[["c3e410a8.84a9e"],[]]},{"id":"c3e410a8.84a9e","type":"change","z":"7342fdca.164ea4","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"on","fromt":"str","to":"true","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"off","fromt":"str","to":"false","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":340,"y":160,"wires":[["2293775.967dc88"]]},{"id":"d96d39ad.ed5278","type":"schedex","z":"7342fdca.164ea4","name":"alarm radio","suspended":false,"lat":"","lon":"","ontime":"07:00","ontopic":"","onpayload":"on","onoffset":0,"onrandomoffset":0,"offtime":"07:01","offtopic":"","offpayload":"","offoffset":"","offrandomoffset":0,"mon":true,"tue":true,"wed":true,"thu":true,"fri":true,"sat":false,"sun":false,"x":590,"y":100,"wires":[["17905c3e.7d4484"]]},{"id":"b4516dd2.ce5ee","type":"afya-lullaby","z":"7342fdca.164ea4","name":"","dimmingTime":"360","startValue":"0","stopValue":"100","step":1,"x":870,"y":560,"wires":[["ddf724f4.cf0078"]]},{"id":"c10baed7.f6061","type":"api-call-service","z":"7342fdca.164ea4","name":"Increase light","server":"cfa79f02.db9d4","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.masterbedmorning, light.tall_black_lamp, light.ensuite_1","data":"{\"brightness_pct\":\"{{ payload.value }}\"}","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":1270,"y":560,"wires":[[]]},{"id":"23788a93.5b26f6","type":"api-call-service","z":"7342fdca.164ea4","name":"Turn Off Bedroom Lights","server":"cfa79f02.db9d4","version":1,"debugenabled":false,"service_domain":"light","service":"turn_off","entityId":"light.masterbedmorning, light.tall_black_lamp, light.ensuite_1","data":"","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":650,"y":480,"wires":[[]]},{"id":"628be703.cdb0b8","type":"trigger","z":"7342fdca.164ea4","op1":"kill","op2":"on","op1type":"str","op2type":"str","duration":"1","extend":false,"units":"min","reset":"","bytopic":"all","name":"","x":610,"y":560,"wires":[["b4516dd2.ce5ee"]]},{"id":"1932faa7.a7ec45","type":"change","z":"7342fdca.164ea4","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"kill","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":620,"y":640,"wires":[["b4516dd2.ce5ee","ddf724f4.cf0078"]]},{"id":"ddf724f4.cf0078","type":"traffic","z":"7342fdca.164ea4","name":"","property_allow":"payload","filter_allow":"run","ignore_case_allow":false,"negate_allow":false,"send_allow":false,"property_stop":"payload","filter_stop":"kill","ignore_case_stop":false,"negate_stop":false,"send_stop":false,"default_start":false,"differ":false,"x":1090,"y":560,"wires":[["c10baed7.f6061"]]},{"id":"89749a12.b85598","type":"change","z":"7342fdca.164ea4","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"run","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1100,"y":100,"wires":[["ddf724f4.cf0078"]]},{"id":"8faebb6b.8753a8","type":"afya-lullaby","z":"7342fdca.164ea4","name":"","dimmingTime":"60","startValue":"0","stopValue":"50","step":1,"x":860,"y":700,"wires":[["a594cb87.065ae8"]]},{"id":"a594cb87.065ae8","type":"api-call-service","z":"7342fdca.164ea4","name":"Increase light","server":"cfa79f02.db9d4","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.masterbedside1","data":"{\"brightness_pct\":\"{{ payload.value }}\"}","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":1270,"y":700,"wires":[[]]},{"id":"fd4ce25e.cd939","type":"inject","z":"7342fdca.164ea4","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"*/1 0 * * *","once":false,"onceDelay":0.1,"x":130,"y":240,"wires":[["d2bad75.095dd28","cc6a712c.05a1d"]]},{"id":"cfe5e54a.ba8238","type":"server-events","z":"7342fdca.164ea4","name":"Events","server":"cfa79f02.db9d4","event_type":"deconz_event","x":90,"y":600,"wires":[["babf2e8c.35d65"]]},{"id":"babf2e8c.35d65","type":"switch","z":"7342fdca.164ea4","name":"Master Snooze","property":"payload.event.id","propertyType":"msg","rules":[{"t":"eq","v":"master_snooze","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":260,"y":600,"wires":[["10f7ae9.aa07d51","f8a5b539.09ee68"]]},{"id":"10f7ae9.aa07d51","type":"switch","z":"7342fdca.164ea4","name":"Press","property":"payload.event.event","propertyType":"msg","rules":[{"t":"eq","v":"1002","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":430,"y":560,"wires":[["628be703.cdb0b8","23788a93.5b26f6"]]},{"id":"f8a5b539.09ee68","type":"switch","z":"7342fdca.164ea4","name":"Hold","property":"payload.event.event","propertyType":"msg","rules":[{"t":"eq","v":"1001","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":430,"y":640,"wires":[["1932faa7.a7ec45","6f1e9a3b.809c24"]]},{"id":"6f1e9a3b.809c24","type":"change","z":"7342fdca.164ea4","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"on","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":620,"y":700,"wires":[["8faebb6b.8753a8","abfaaada.3a0528"]]},{"id":"e2a6787d.77df98","type":"inject","z":"7342fdca.164ea4","name":"","topic":"","payload":"on","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":110,"y":340,"wires":[["17905c3e.7d4484"]]},{"id":"abfaaada.3a0528","type":"api-call-service","z":"7342fdca.164ea4","name":"Security Disarm","server":"cfa79f02.db9d4","version":1,"debugenabled":false,"service_domain":"alarm_control_panel","service":"alarm_disarm","entityId":"alarm_control_panel.ha_alarm","data":"{\"code\":7780}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1280,"y":760,"wires":[[]]},{"id":"3a245d.e7e64ba4","type":"server-events","z":"7342fdca.164ea4","name":"Events","server":"cfa79f02.db9d4","event_type":"deconz_event","x":90,"y":820,"wires":[["2fa919e6.026df6"]]},{"id":"2fa919e6.026df6","type":"switch","z":"7342fdca.164ea4","name":"Master Snooze","property":"payload.event.id","propertyType":"msg","rules":[{"t":"eq","v":"dimmer_bedside","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":260,"y":820,"wires":[["2209dbc1.cb41f4"]]},{"id":"2209dbc1.cb41f4","type":"switch","z":"7342fdca.164ea4","name":"Press","property":"payload.event.event","propertyType":"msg","rules":[{"t":"eq","v":"3001","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":430,"y":820,"wires":[["a16c66dd.0b8048"]]},{"id":"a16c66dd.0b8048","type":"change","z":"7342fdca.164ea4","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"kill","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":620,"y":820,"wires":[["b4516dd2.ce5ee","8faebb6b.8753a8","23788a93.5b26f6"]]},{"id":"8730158a.2f7388","type":"comment","z":"7342fdca.164ea4","name":"TRIGGER ALARM CLOCK","info":"","x":110,"y":920,"wires":[]},{"id":"3266332a.f334ac","type":"comment","z":"7342fdca.164ea4","name":"START ALARM CLOCK SEQUENCE","info":"","x":210,"y":1200,"wires":[]},{"id":"5209e7cf.6d2da8","type":"comment","z":"7342fdca.164ea4","name":"Set Initial Flow Variables","info":"","x":550,"y":1220,"wires":[]},{"id":"df803f80.00373","type":"comment","z":"7342fdca.164ea4","name":"LOOP LOGIC ","info":"","x":150,"y":1480,"wires":[]},{"id":"2bf9094d.b53506","type":"comment","z":"7342fdca.164ea4","name":"Snooze Button Actions","info":"","x":880,"y":1740,"wires":[]},{"id":"9592e0c4.41c6a","type":"comment","z":"7342fdca.164ea4","name":"Finish Alarm Sequence","info":"","x":1040,"y":1640,"wires":[]},{"id":"e8adb6ad.a352a8","type":"comment","z":"7342fdca.164ea4","name":"Snooze Timer","info":"","x":850,"y":1860,"wires":[]},{"id":"70d5801c.64fc2","type":"change","z":"7342fdca.164ea4","name":"Stop","rules":[{"t":"set","p":"payload","pt":"msg","to":"snooze","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":410,"y":1660,"wires":[["1bca15b9.8cf09a"]]},{"id":"69d887e3.d82258","type":"link in","z":"7342fdca.164ea4","name":"","links":["84277412.105e18","6f31c450.2bbaac"],"x":315,"y":1660,"wires":[["70d5801c.64fc2"]]},{"id":"8b7d1725.54bb68","type":"function","z":"7342fdca.164ea4","name":"Reset to Volume","func":"flow.set(\"volume\",0.2);\nnewmsg = {\"payload\":\"true\"}\nreturn newmsg;","outputs":1,"noerr":0,"x":860,"y":1780,"wires":[["4f07dccb.6d7a94"]]},{"id":"202c8f85.f2afd","type":"delay","z":"7342fdca.164ea4","name":"","pauseType":"delay","timeout":"2","timeoutUnits":"minutes","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":840,"y":1920,"wires":[["799dbb50.466654","f34105e4.e144b8"]]},{"id":"c96a2ec4.ae5d5","type":"change","z":"7342fdca.164ea4","name":"Start","rules":[{"t":"set","p":"payload","pt":"msg","to":"start","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":410,"y":1480,"wires":[["1bca15b9.8cf09a"]]},{"id":"1c7e29eb.557a46","type":"switch","z":"7342fdca.164ea4","name":"Is it Time?","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Waking Up","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":170,"y":1260,"wires":[["c96a2ec4.ae5d5","6e5fab.f3f5b054","bb23825e.05857"]]},{"id":"6e5fab.f3f5b054","type":"function","z":"7342fdca.164ea4","name":"Initialize Volume to 0","func":"flow.set(\"volume\", 0);\n\nnewmsg = {\"payload\":\"true\"}\nreturn newmsg;","outputs":1,"noerr":0,"x":540,"y":1260,"wires":[[]]},{"id":"cf542fa6.b95ba","type":"switch","z":"7342fdca.164ea4","name":"Is Loop Done?","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"done","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":1360,"y":1640,"wires":[["84277412.105e18"]]},{"id":"43b95f19.c2d81","type":"inject","z":"7342fdca.164ea4","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"onceDelay":0.1,"x":170,"y":1320,"wires":[["6e5fab.f3f5b054"]]},{"id":"84277412.105e18","type":"link out","z":"7342fdca.164ea4","name":"FINISH ALARM SEQUENCE!","links":["69d887e3.d82258","45deb28f.3cb32c"],"x":1195,"y":1640,"wires":[]},{"id":"1bca15b9.8cf09a","type":"traffic","z":"7342fdca.164ea4","name":"Turn Up Volume","property_allow":"payload","filter_allow":"start","ignore_case_allow":true,"negate_allow":false,"send_allow":false,"property_stop":"payload","filter_stop":"snooze","ignore_case_stop":false,"negate_stop":false,"send_stop":false,"default_start":false,"differ":false,"x":640,"y":1580,"wires":[["ba649753.1c77e8"]]},{"id":"8c5e52f.48d0fb","type":"inject","z":"7342fdca.164ea4","name":"Volume ---->","topic":"","payload":"volume","payloadType":"flow","repeat":"5","crontab":"","once":false,"onceDelay":0.1,"x":180,"y":1580,"wires":[["1bca15b9.8cf09a"]]},{"id":"ba649753.1c77e8","type":"function","z":"7342fdca.164ea4","name":"Set Volume","func":"newmsg = {};\nvar volume = flow.get(\"volume\");\n\nnewmsg.payload = { data: { \"volume_level\":volume} }\n\nreturn newmsg;","outputs":1,"noerr":0,"x":850,"y":1580,"wires":[["8cc15c7d.342d9"]]},{"id":"8cc15c7d.342d9","type":"api-call-service","z":"7342fdca.164ea4","name":"Bedroom Speaker","server":"cfa79f02.db9d4","version":1,"debugenabled":false,"service_domain":"media_player","service":"volume_set","entityId":"media_player.bedroom_speaker","data":"","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":1110,"y":1580,"wires":[["b893351c.b53748"]]},{"id":"b893351c.b53748","type":"function","z":"7342fdca.164ea4","name":"Increment Volume","func":"var volume = flow.get('volume')||0.0;\n\nif (volume < 0.25) {\n volume = volume + 0.01;\n flow.set(\"volume\", volume);\n \n newmsg = {\"payload\":\"looping\"}\n return newmsg;\n}\nelse {\n newmsg = {\"payload\":\"done\"};\n return newmsg;\n}","outputs":1,"noerr":0,"x":1370,"y":1580,"wires":[["cf542fa6.b95ba"]]},{"id":"3eb39e16.852742","type":"comment","z":"7342fdca.164ea4","name":"SNOOZE!","info":"","x":140,"y":1720,"wires":[]},{"id":"ed721df3.7a99d","type":"comment","z":"7342fdca.164ea4","name":"VOLUME","info":"","x":620,"y":1540,"wires":[]},{"id":"78b1812d.fa222","type":"comment","z":"7342fdca.164ea4","name":"Turn on Radio","info":"","x":610,"y":1340,"wires":[]},{"id":"bb23825e.05857","type":"api-call-service","z":"7342fdca.164ea4","name":"Volume","server":"cfa79f02.db9d4","version":1,"debugenabled":false,"service_domain":"media_player","service":"volume_set","entityId":"media_player.bedroom_speaker","data":"{\"volume_level\":0}","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":600,"y":1380,"wires":[["917a0aa6.3f5658"]]},{"id":"917a0aa6.3f5658","type":"change","z":"7342fdca.164ea4","name":"Delete","rules":[{"t":"delete","p":"payload","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":810,"y":1380,"wires":[["c7b3dd86.23299"]]},{"id":"4f07dccb.6d7a94","type":"api-call-service","z":"7342fdca.164ea4","name":"Pause Radio","server":"cfa79f02.db9d4","version":1,"debugenabled":false,"service_domain":"media_player","service":"media_play_pause","entityId":"media_player.bedroom_speaker","data":"","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":1170,"y":1780,"wires":[["b4854ef6.80d96"]]},{"id":"799dbb50.466654","type":"change","z":"7342fdca.164ea4","name":"Delete","rules":[{"t":"delete","p":"payload","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1110,"y":1920,"wires":[["b6023d01.7a816"]]},{"id":"b6023d01.7a816","type":"api-call-service","z":"7342fdca.164ea4","name":"Play","server":"cfa79f02.db9d4","version":1,"debugenabled":false,"service_domain":"media_player","service":"media_play","entityId":"media_player.bedroom_speaker","data":"","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":1270,"y":1920,"wires":[[]]},{"id":"b4854ef6.80d96","type":"change","z":"7342fdca.164ea4","name":"Delete","rules":[{"t":"delete","p":"payload","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1310,"y":1780,"wires":[["d442d3ad.b6ff9"]]},{"id":"d442d3ad.b6ff9","type":"api-call-service","z":"7342fdca.164ea4","name":"Volume","server":"cfa79f02.db9d4","version":1,"debugenabled":false,"service_domain":"media_player","service":"volume_set","entityId":"media_player.bedroom_speaker","data":"{\"volume_level\":0.1}","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":1480,"y":1780,"wires":[[]]},{"id":"44f77a49.1cb704","type":"comment","z":"7342fdca.164ea4","name":"Snooze Button","info":"","x":160,"y":1900,"wires":[]},{"id":"1f5b1320.be8a4d","type":"change","z":"7342fdca.164ea4","name":"Delete","rules":[{"t":"delete","p":"payload","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1190,"y":1380,"wires":[["1a1da284.49ae5d"]]},{"id":"1a1da284.49ae5d","type":"api-call-service","z":"7342fdca.164ea4","name":"Volume","server":"cfa79f02.db9d4","version":1,"debugenabled":false,"service_domain":"media_player","service":"volume_set","entityId":"media_player.bedroom_speaker","data":"{\"volume_level\":0}","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":1340,"y":1380,"wires":[[]]},{"id":"c7b3dd86.23299","type":"cast-to-client","z":"7342fdca.164ea4","name":"","url":"http://bbcmedia.ic.llnwd.net/stream/bbcmedia_radio1_mf_p","contentType":"audio/basic","message":"","language":"en","ip":"192.168.1.14","port":"8009","volume":"","x":1010,"y":1380,"wires":[["1f5b1320.be8a4d"]]},{"id":"a4b45af2.8fe1c8","type":"server-events","z":"7342fdca.164ea4","name":"Events","server":"cfa79f02.db9d4","event_type":"deconz_event","x":130,"y":1960,"wires":[["d0df6f67.e0d4"]]},{"id":"d0df6f67.e0d4","type":"switch","z":"7342fdca.164ea4","name":"Master Snooze","property":"payload.event.id","propertyType":"msg","rules":[{"t":"eq","v":"master_snooze","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":300,"y":1960,"wires":[["9acc15dd.b36878","336b159c.c16b4a"]]},{"id":"9acc15dd.b36878","type":"switch","z":"7342fdca.164ea4","name":"press","property":"payload.event.event","propertyType":"msg","rules":[{"t":"eq","v":"1002","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":470,"y":1920,"wires":[["5829f591.2e0e3c","6f31c450.2bbaac"]]},{"id":"98ae7ba5.e199e8","type":"function","z":"7342fdca.164ea4","name":"set time - actual","func":"varAlarmTime = msg.payload;\nmsg.payload = {};\nmsg.payload.ontime = varAlarmTime\nmsg.payload.offtime = varAlarmTime\nreturn msg;","outputs":1,"noerr":0,"x":340,"y":1000,"wires":[["d65a45a8.99fb38"]]},{"id":"d65a45a8.99fb38","type":"schedex","z":"7342fdca.164ea4","name":"alarm radio","suspended":false,"lat":"","lon":"","ontime":"07:00","ontopic":"","onpayload":"on","onoffset":0,"onrandomoffset":0,"offtime":"07:01","offtopic":"","offpayload":"","offoffset":"","offrandomoffset":0,"mon":true,"tue":true,"wed":true,"thu":true,"fri":true,"sat":false,"sun":false,"x":510,"y":1000,"wires":[["9cde0fa4.b74fb"]]},{"id":"9cde0fa4.b74fb","type":"api-current-state","z":"7342fdca.164ea4","name":"alarm set?","server":"cfa79f02.db9d4","version":1,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_boolean.house_option_alarmclock","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":790,"y":1000,"wires":[["5fdf753.68ced8c"],[]]},{"id":"3014c8f5.f13a68","type":"trigger-state","z":"7342fdca.164ea4","name":"alarm time","server":"cfa79f02.db9d4","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityid":"input_datetime.alarmclock_time","entityidfiltertype":"exact","debugenabled":false,"constraints":[],"constraintsmustmatch":"all","outputs":2,"customoutputs":[],"outputinitially":true,"state_type":"str","x":130,"y":1000,"wires":[["98ae7ba5.e199e8"],[]]},{"id":"5fdf753.68ced8c","type":"change","z":"7342fdca.164ea4","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"on","fromt":"str","to":"Waking Up","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1020,"y":1000,"wires":[["1c7e29eb.557a46"]]},{"id":"46fd8ee6.e259d","type":"function","z":"7342fdca.164ea4","name":"set day","func":"varAlarmDay = msg.payload;\nmsg.payload = {};\nmsg.payload.sat = varAlarmDay\nmsg.payload.sun = varAlarmDay\n\nreturn msg;","outputs":1,"noerr":0,"x":320,"y":1060,"wires":[["d65a45a8.99fb38"]]},{"id":"ea7b6d53.0bef7","type":"trigger-state","z":"7342fdca.164ea4","name":"alarm day","server":"cfa79f02.db9d4","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityid":"input_boolean.alarm_clock_weekend","entityidfiltertype":"exact","debugenabled":false,"constraints":[],"constraintsmustmatch":"all","outputs":2,"customoutputs":[],"outputinitially":true,"state_type":"str","x":120,"y":1060,"wires":[["5d90b5e2.ce6f9c"],[]]},{"id":"5d90b5e2.ce6f9c","type":"change","z":"7342fdca.164ea4","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"on","fromt":"str","to":"true","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"off","fromt":"str","to":"false","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":140,"y":1120,"wires":[["46fd8ee6.e259d"]]},{"id":"a301b42a.316d38","type":"comment","z":"7342fdca.164ea4","name":"Bedside Dimmer Kill switch","info":"","x":200,"y":2040,"wires":[]},{"id":"336b159c.c16b4a","type":"switch","z":"7342fdca.164ea4","name":"Hold","property":"payload.event.event","propertyType":"msg","rules":[{"t":"eq","v":"1001","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":470,"y":2000,"wires":[["fbb7b321.ef158","6f31c450.2bbaac"]]},{"id":"5829f591.2e0e3c","type":"change","z":"7342fdca.164ea4","name":"snooze","rules":[{"t":"set","p":"payload","pt":"msg","to":"snooze","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":620,"y":1920,"wires":[["202c8f85.f2afd","8b7d1725.54bb68"]]},{"id":"fbb7b321.ef158","type":"change","z":"7342fdca.164ea4","name":"snooze","rules":[{"t":"set","p":"payload","pt":"msg","to":"snooze","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":620,"y":2000,"wires":[["a95e3262.5cafb"]]},{"id":"63eacb81.85ceb4","type":"api-call-service","z":"7342fdca.164ea4","name":"Stop","server":"cfa79f02.db9d4","version":1,"debugenabled":false,"service_domain":"media_player","service":"media_stop","entityId":"media_player.bedroom_speaker","data":"","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":1270,"y":2000,"wires":[[]]},{"id":"a95e3262.5cafb","type":"change","z":"7342fdca.164ea4","name":"Delete","rules":[{"t":"delete","p":"payload","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1110,"y":2000,"wires":[["63eacb81.85ceb4"]]},{"id":"e1a2a456.4aced8","type":"inject","z":"7342fdca.164ea4","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"*/1 0 * * *","once":false,"onceDelay":0.1,"x":390,"y":1120,"wires":[["3014c8f5.f13a68","ea7b6d53.0bef7"]]},{"id":"6f31c450.2bbaac","type":"link out","z":"7342fdca.164ea4","name":"FINISH ALARM SEQUENCE!","links":["69d887e3.d82258","45deb28f.3cb32c"],"x":555,"y":1960,"wires":[]},{"id":"6e1a83c1.a52e8c","type":"link in","z":"7342fdca.164ea4","name":"","links":["f34105e4.e144b8"],"x":295,"y":1480,"wires":[["c96a2ec4.ae5d5"]]},{"id":"f34105e4.e144b8","type":"link out","z":"7342fdca.164ea4","name":"FINISH ALARM SEQUENCE!","links":["45deb28f.3cb32c","6e1a83c1.a52e8c"],"x":975,"y":1900,"wires":[]},{"id":"3054a35a.ee832c","type":"comment","z":"7342fdca.164ea4","name":"TRIGGER ALARM CLOCK","info":"","x":330,"y":920,"wires":[]},{"id":"e87c3456.eb6a98","type":"comment","z":"7342fdca.164ea4","name":"TRIGGER ALARM CLOCK","info":"","x":550,"y":920,"wires":[]},{"id":"19e6ad84.82c692","type":"comment","z":"7342fdca.164ea4","name":"TRIGGER ALARM CLOCK","info":"","x":770,"y":920,"wires":[]},{"id":"89a3d6f0.e8cbf8","type":"comment","z":"7342fdca.164ea4","name":"TRIGGER ALARM CLOCK","info":"","x":990,"y":920,"wires":[]},{"id":"82bfb426.724ee8","type":"comment","z":"7342fdca.164ea4","name":"TRIGGER ALARM CLOCK","info":"","x":1210,"y":920,"wires":[]},{"id":"cfa79f02.db9d4","type":"server","z":"","name":"Home Assistant","legacy":false,"hassio":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":false}]
