Eeeeeediot
(Eeeeeediot)
October 10, 2017, 4:25pm
1
Hi folks,
I managed to make my first automation yesterday with the help of a few very nice people on this forum. I am hopeing someone can help me improve it today.
Firstly, the automation
alias: 'Living Room Radiator (1 hour)'
- platform: state
entity_id: automation.living_room_radiator_1_hour
to: 'on'
- delay: '0:00:01'
- service: switch.turn_on
entity_id: switch.switch_3
- delay: '1:00:00'
- service: switch.turn_off
- delay: '0:00:01'
- service: automation.turn_off
Frontend
Is there anyway to allow me to select the number of hours to switch on the radiator for? If so, how would i implement it into my automation or config yaml file.
Thank you
danialFACT
(Danial Meyer)
October 10, 2017, 5:03pm
2
Unfortunately I don’t remember which post I saw it on, but what you are looking for is called an input slider.
Depending on the value you assign to the steps/notches of the slider, you can define the number of minutes (in your case) to goody will be on or off.
sjee
October 10, 2017, 5:44pm
3
This is what you’re looking for;
Eeeeeediot
(Eeeeeediot)
October 10, 2017, 9:36pm
4
Yeah i figured it was that but the problem is i dont have the know how to implement that in my automation.
I basically want a toggle to turn on/off the radiator and then a toggle(slider i spose) to run an automation to tirn off after a set number of hours.
Dinoaus
(John Dean)
October 10, 2017, 10:04pm
5
You could create a script, with a delay like
script1:
sequence:
entity_id: switch.tank_pump
- delay: '{{ states.input_number.hours.state | int }}:00:00'
I gave you the code in your other thread. as posted in previous replies, you create an input_number (HA v0.55 or higher). then in your automation, you put the value of the input_number in the delay. like so:
input_number:
radiator_hours:
icon: mdi:clock
min: 0
max: 12
step: 1
Then in the automation:
- delay: '{{ states.input_number.radiator_hours.state | int }}:00:00'
whenever the automation is triggered, it will wait however long the input_number is set for.
EDIT: Here’s the post I originally suggested this in.
Eeeeeediot
(Eeeeeediot)
October 13, 2017, 2:23pm
7
Thank you! Yeah I hadnt realised, i managed to get it to work all thanks to you!
