Hi all!!!
I tried to create my own theme so I can tweak a bit the colors and learn how this whole lovelace thing works. So here is what I did:
I created a new folder in my themes folder called my-theme
Inside that folder I created a file called my_theme.yaml
I copied the code from the ios-dark-mode-blue-red
theme in the my_theme.yaml
I copied the image in the my-theme
folder
I made changes in the code referring to the background image location
I restarted HA
I selected my theme in a dashboard and I can’t see the background image. Is there anything else I have to change/fix to see the background image?
Here is my theme yaml code
# iOS Dark Mode Theme - blue-red
ios-dark-mode-blue-red:
# Global
background-image: "center / cover no-repeat fixed url('/hacsfiles/themes/my-theme/homekit-bg-blue-red.jpg')"
lovelace-background: var(--background-image)
primary-color: "#ff9f09" # from Apple systemOrange dark mode
light-primary-color: "#B6B6C1" # (icons on left menu) (light: systemGray5 from iOS dark mode, dark: XXX)
primary-background-color: "#2c2c2e" # systemGray5 dark mode
secondary-background-color: rgba(25, 25, 25, 0.9)
divider-color: rgba(152, 152, 157, 0.3) # from Apple systemGray dark mode
accent-color: rgba(255, 159, 9, 1)
# Text
primary-text-color: "#FFF"
secondary-text-color: "#d3d3d3"
text-primary-color: "#FFF"
disabled-text-color: "#555" # XXX: https://github.com/basnijholt/lovelace-ios-dark-mode-theme/issues/2
text-dark-color: "#FFF"
# Sidebar Menu
sidebar-background-color: var(--primary-background-color)
sidebar-icon-color: var(--light-primary-color)
sidebar-text-color: "#F1F1F1"
sidebar-selected-background-color: var(--primary-background-color)
sidebar-selected-icon-color: "#FFF" # (light: systemGray5 from iOS light mode, dark: XXX)
sidebar-selected-text-color: var(--sidebar-selected-icon-color)
# States and Badges
state-icon-color: "#FFF"
state-icon-active-color: rgba(255, 214, 10, 1) # or make light icons yellow when active: rgba(255, 214, 10, 1)
state-icon-unavailable-color: var(--disabled-text-color)
paper-item-icon-active-color: rgba(255, 214, 10, 1) # see https://github.com/basnijholt/lovelace-ios-dark-mode-theme/issues/30
# Sliders
paper-slider-knob-color: "#FFFFFF"
paper-slider-knob-start-color: var(--paper-slider-knob-color)
paper-slider-pin-color: var(--paper-slider-knob-color)
paper-slider-active-color: "#0984ff" # from Apple systemBlue dark mode
paper-slider-secondary-color: var(--paper-slider-knob-color)
paper-slider-container-color: rgba(255, 255, 255, 0.5)
paper-slider-font-color: "#000"
ha-slider-background: none !important
# Labels
label-badge-background-color: "#23232E"
label-badge-text-color: "#F1F1F1"
label-badge-red: rgba(255, 159, 9, 0.7) # from Apple systemOrange dark mode
# Cards
card-background-color: var(--secondary-background-color) # Unused entities table background
paper-listbox-background-color: var(--primary-background-color)
ha-card-border-radius: 20px
ha-card-background: rgba(10, 10, 10, 0.4)
paper-card-background-color: var(--ha-card-background)
ha-card-border-width: 0 # https://github.com/basnijholt/lovelace-ios-dark-mode-theme/issues/82#event-7732695357
# Toggles
paper-toggle-button-checked-button-color: "#484848"
paper-toggle-button-checked-bar-color: "#484848"
paper-toggle-button-unchecked-button-color: var(--paper-toggle-button-checked-button-color)
paper-toggle-button-unchecked-bar-color: var(--disabled-text-color)
# Table row
table-row-background-color: var(--primary-background-color)
table-row-alternative-background-color: var(--secondary-background-color)
# Switches
switch-checked-color: "#30d257" # XXX: remove when https://github.com/home-assistant/home-assistant-polymer/pull/4203 is in HA
switch-checked-track-color: "#30d158" # from Apple systemGreen dark mode
switch-checked-button-color: "#FFF"
# Other
paper-dialog-background-color: rgba(55, 55, 55, 0.8) # e.g., background of more-info
paper-item-icon-color: white # also should mini-media-player icon white (but doesn't work by itself)
more-info-header-background: rgba(25, 25, 25, 0.5)
lumo-body-text-color: var(--primary-text-color) # see https://github.com/basnijholt/lovelace-ios-dark-mode-theme/issues/42
app-header-background-color: rgba(30, 2, 61, 0.4)
markdown-code-background-color: "#464646"
code-editor-background-color: "#161616"
# Custom
mcg-title-letter-spacing: .15em
mini-media-player-base-color: white
mini-media-player-icon-color: white
# Added for https://github.com/basnijholt/lovelace-ios-dark-mode-theme/issues/72
# TODO: add description for lines below. Suggested in https://github.com/basnijholt/lovelace-ios-dark-mode-theme/issues/72
input-ink-color: var(--primary-text-color)
input-fill-color: transparent
input-disabled-fill-color: transparent
input-label-ink-color: var(--primary-text-color)
input-disabled-ink-color: var(--disabled-text-color)
input-dropdown-icon-color: var(--primary-text-color)
input-idle-line-color: var(--secondary-text-color)
input-hover-line-color: var(--secondary-text-color)
codemirror-property: var(--accent-color)
and here is my configuration.yaml
file
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
#Sonoff Sensors Compensate
template:
- sensor:
- name: "lounge_temp_offset"
unit_of_measurement: "°C"
state: "{{ states('sensor.sonoff_a480041241_temperature')|float -1 }}"
- sensor:
- name: "bedroom_temp_offset"
state: "{{ states('sensor.sonoff_a48003fc6b_temperature')|float +1 }}"
- sensor:
- name: "studio_temp_offset"
state: "{{ states('sensor.sonoff_a48004331f_temperature')|float +1 }}"
- sensor:
- name: "terrace_temp_offset"
state: "{{ states('sensor.sonoff_a480044815_temperature')|float -3 }}"
# Example of History Stats use
- platform: history_stats
name: Lamp ON today
entity_id: light.bookshelf
state: "on"
type: time
start: "{{ now().replace(hour=0, minute=0, second=0) }}"
end: "{{ now() }}"
# Time & date
- platform: time_date
display_options:
- "time"
- "date"
- "date_time"
- "date_time_utc"
- "date_time_iso"
- "time_date"
- "time_utc"
- "beat"
# Parts of the day - View the current part of the day
sensors:
greeting:
friendly_name: 'Part of the day'
value_template: >
{% set state = states('sensor.time') %}
{% if '22:00' <= state < '06:00' %}
Night
{% elif '06:00' <= state < '08:00' %}
Morning
{% elif '08:00' <= state < '20:00' %}
Day
{% else %}
Evening
{% endif %}
Can anyone help a noobie?
