This summer (2022) I created an ESP32 device to help my family use the fridge but there is a bug that is still not fixed and I don’t know how to fix.
I’ve created a Github repository here:
and a video here
The video shows the problem. It looks like the SPI communication is not stable. When the magnetic sensor transitions from off-on state (the door is closed) a kind of “interference” corrupts the SPI communication with the Max7219.
Actually I’ve tested the following things that are not the source of the problem.
- 8 channel bi-directional logic level converter, unused lines are tied to GND
- Adding capacitors to avoid power going down
- Deep review of the code and the surrounding components
I need your help to understand what could be happening and how to fix it.
Thank you in advance!
