Nice. I do a lot with presense too but, it just doesnt alwsys work right or it doesnt update fast enough for me. My other problem with doing presense alone is my daughter and I ride bikes alot, ride the golf cart or walk the dog, etc. I dont always and by choice carry my phone. Something small i can put in my pocket to shut the door or arm alarm was something else i liked about having an rf remote. To each his own though! The ability for everyone to make what works for them, thats the beauty of HA.
Has anyone used this code with the ratgdo door opener? The only entities i could us is cover.ratgdov25i_ee88b2_door which shows if closed or open. I also have the light.ratgdov25i_ee88b2_light entity which turns on when door opens then turns off 30sec later. Would i have to change a lot of dburnts code for it to work?
That entity alone is not enough. My code is based on an ESP32 with two door sensors: one indicates closed/not closed and the other open/not open.
Hi.
Is your integration still works?
Any chances you could share your ymal with me?
I do have esp32 and would like to operate my garage door with two sensors.
Thanks Andy.
Here you go…
esphome:
friendly_name: My Garage Door
on_boot:
priority: 100
then:
- binary_sensor.template.publish:
state: False
state: False
- if:
condition:
binary_sensor.is_on:
then:
light.turn_on:
effect: Slow Pulse
brightness: 100%
red: 100%
green: 0%
blue: 0%
esp8266:
board: d1_mini
restore_from_flash: True
logger:
api:
encryption:
key: "<redacted>"
ota:
- platform: esphome
password: "<redacted>"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Distance-Sensor Fallback Hotspot"
captive_portal:
binary_sensor:
device_class: presence
lambda:
if (id(parking_sensor).state < id(yellow_trigger_level).state) {
return true;
} else {
return false;
- platform: gpio
pin:
number: D5
mode: INPUT_PULLUP
inverted: True
disabled_by_default: True
internal: False
on_press:
- then:
state: False
state: False
- sensor.duty_time.reset: parking_light_duty_time
- light.turn_on:
effect: Scan Effect
# effect: Red Color Wipe
brightness: 50%
red: 100%
green: 0%
blue: 0%
on_release:
state: True
on_press:
then:
- light.turn_on:
effect: Blue Progress
brightness: 100%
- platform: gpio
pin:
number: D6
mode: INPUT_PULLUP
inverted: True
internal: False
on_press:
then:
- light.turn_off:
state: False
state: False
on_release:
- sensor.duty_time.start: parking_light_duty_time
state: True
on_press:
then:
- light.turn_on:
effect: Erase
- delay: 600ms
- light.turn_on:
effect: Yellow Progress
brightness: 100%
red: 0%
green: 0%
blue: 0%
cover:
- platform: feedback
device_class: garage
has_built_in_endstop: True
max_duration: 12s
open_action:
- switch.turn_on: relay
open_duration: 10s
open_endstop: open_contact_sensor
open_sensor: open_movement_sensor
close_action:
close_duration: 10s
close_endstop: closed_contact_sensor
close_sensor: close_movement_sensor
stop_action:
light:
- platform: neopixelbus
variant: WS2812
pin: D8
num_leds: 30
type: grb
name: "Parking Light Indicator"
restore_mode: ALWAYS_OFF
effects:
- pulse:
transition_length: 500ms
update_interval: 750ms
min_brightness: 0%
max_brightness: 100%
- pulse:
transition_length: 50ms
update_interval: 100ms
min_brightness: 0%
- addressable_scan:
move_interval: 15ms
scan_width: 5
- addressable_color_wipe:
colors:
- red: 0%
green: 0%
blue: 100%
num_leds: 30
add_led_interval: 300ms
reverse: False
colors:
- red: 100%
green: 100%
blue: 0%
num_leds: 30
reverse: True
colors:
- red: 0%
green: 0%
blue: 0%
num_leds: 30
add_led_interval: 15ms
reverse: False
- platform: duty_time
name: Parking Light Duty Time
update_interval: 1s
lambda: "return id(closed_contact_sensor).state == false;"
restore: false
last_time:
name: Parking Light Last Turn-On Time
on_value_range:
above: 60
then:
- light.turn_off: parking_light_indicator
- platform: ultrasonic
trigger_pin: D1
echo_pin: D2
unit_of_measurement: "m"
accuracy_decimals: 1
update_interval: 1s
timeout: 4.0m
pulse_time: 10us
filters:
- delta: .02
on_value:
then:
- if:
condition:
and:
- binary_sensor.is_on: open_contact_sensor
- sensor.duty_time.is_running: parking_light_duty_time
then:
- if:
condition:
- lambda: |-
return id(red_trigger_level).state < id(parking_sensor).state;
- lambda: |-
return id(parking_light_duty_time).state < 60;
then:
light.turn_on:
effect: Slow Pulse
brightness: 100%
red: 100%
green: 0%
blue: 0%
- if:
condition:
- lambda: |-
return (id(green_trigger_level).state < id(parking_sensor).state && id(parking_sensor).state < id(red_trigger_level).state);
- lambda: |-
then:
light.turn_on:
effect: none
brightness: 100%
red: !lambda |-
return ((id(parking_sensor).state - id(green_trigger_level).state) / (id(red_trigger_level).state - id(green_trigger_level).state));
green: !lambda |-
return ((id(red_trigger_level).state - id(parking_sensor).state) / (id(red_trigger_level).state - id(green_trigger_level).state));
blue: 0%
- if:
condition:
- lambda: |-
return id(parking_sensor).state < id(green_trigger_level).state and id(parking_sensor).state < id(green_trigger_level).state - 0.2;
- lambda: |-
then:
- light.turn_on:
effect: Fast Pulse
brightness: 100%
red: 0%
green: 100%
blue: 0%
- delay : 1s
- light.dim_relative:
relative_brightness: 50%
transition_length: 5s
- if:
condition:
- lambda: |-
return id(parking_sensor).state < id(green_trigger_level).state - 0.2;
- lambda: |-
then:
- light.turn_on:
effect: none
brightness: 75%
red: 0%
green: 100%
blue: 0%
- platform: copy
source_id: parking_sensor
filters:
- delta: 0.05
- platform: homeassistant
name: "Red Trigger Level"
entity_id: input_number.red_trigger_level
name: "Yellow Trigger Level"
entity_id: input_number.yellow_trigger_level
name: "Green Trigger Level"
entity_id: input_number.green_trigger_level
switch:
- platform: gpio
pin: D7
name: "Garage Door Relay"
internal: False
# Toggle the relay with a 0.5s pulse simulating a manual button press
on_turn_on:
- delay : 500ms
- switch.turn_off: relay
time:
- platform: sntp
Thank you for your reply!
I end up implementing cover in ESPHome and works ok from HA and even from HomeKit. Only one issue is when I’m using wall switch, not updating state at all.
Any chances to implement this?
Im using 16 IN/OUT (esp32) module, so maybe I was thinking of using x2 spares inputs as a wall switch to integrate this.
Could you please support me?
Please see my yaml:
esphome:
esp32:
board: esp32dev
framework:
type: esp-idf
wifi:
ssid: xxx
password: xxx
captive_portal:
logger:
# Enable Home Assistant API
api:
encryption:
key: "xxx
ota:
- platform: esphome
password: xxx
uart:
- id: rs485
tx_pin: GPIO13
rx_pin: GPIO16
baud_rate: 9600
remote_receiver:
pin:
number: GPIO2
ignore_strapping_warning: true
remote_transmitter:
pin:
number: GPIO15
carrier_duty_percent: 100%
i2c:
sda: GPIO4
scl:
number: GPIO5
pcf8574:
- id: inputs_1_8
address: 0x22
- id: inputs_9_16
address: 0x21
- id: outputs_1_8
address: 0x24
- id: outputs_9_16
address: 0x25
- platform: adc
pin:
number: GPIO32
inverted: true
- platform: adc
pin:
number: GPIO33
inverted: true
- platform: adc
pin: GPIO36
- platform: adc
pin: GPIO34
- platform: adc
pin: GPIO35
- platform: adc
pin: GPIO39
binary_sensor:
- platform: gpio
pin:
pcf8574: inputs_1_8
number: 0
mode: INPUT
inverted: true
- platform: gpio
pin:
pcf8574: inputs_1_8
number: 1
mode: INPUT
inverted: true
- platform: gpio
pin:
pcf8574: inputs_1_8
number: 2
mode: INPUT
inverted: true
- platform: gpio
pin:
pcf8574: inputs_1_8
number: 3
mode: INPUT
inverted: true
- platform: gpio
pin:
pcf8574: inputs_1_8
number: 4
mode: INPUT
inverted: true
- platform: gpio
pin:
pcf8574: inputs_1_8
number: 5
mode: INPUT
inverted: true
- platform: gpio
pin:
pcf8574: inputs_1_8
number: 6
mode: INPUT
inverted: true
- platform: gpio
pin:
pcf8574: inputs_1_8
number: 7
mode: INPUT
inverted: true
- platform: gpio
pin:
pcf8574: inputs_9_16
number: 0
mode: INPUT
inverted: true
- platform: gpio
pin:
number: 1
mode: INPUT
inverted: true
- platform: gpio
pin:
number: 2
mode: INPUT
inverted: true
- platform: gpio
pin:
number: 3
mode: INPUT
inverted: true
- platform: gpio
pin:
number: 4
mode: INPUT
inverted: true
- platform: gpio
pin:
number: 5
mode: INPUT
inverted: true
- platform: gpio
pin:
number: 6
mode: INPUT
inverted: true
- platform: gpio
pin:
number: 7
mode: INPUT
inverted: true
switch:
- platform: gpio
pin:
pcf8574: outputs_1_8
number: 0
mode: OUTPUT
inverted: true
- platform: gpio
pin:
number: 1
mode: OUTPUT
inverted: true
on_turn_on:
- delay : 5s
- switch.turn_off: out_y02
- platform: gpio
pin:
number: 2
mode: OUTPUT
inverted: true
- platform: gpio
pin:
number: 3
mode: OUTPUT
inverted: true
- platform: gpio
pin:
number: 4
mode: OUTPUT
inverted: true
- platform: gpio
pin:
number: 5
mode: OUTPUT
inverted: true
- platform: gpio
pin:
number: 6
mode: OUTPUT
inverted: true
- platform: gpio
pin:
number: 7
mode: OUTPUT
inverted: true
- platform: gpio
pin:
pcf8574: outputs_9_16
number: 0
mode: OUTPUT
inverted: true
- platform: gpio
pin:
number: 1
mode: OUTPUT
inverted: true
- platform: gpio
pin:
number: 2
mode: OUTPUT
inverted: true
- platform: gpio
pin:
number: 3
mode: OUTPUT
inverted: true
- platform: gpio
pin:
number: 4
mode: OUTPUT
inverted: true
- platform: gpio
pin:
number: 5
mode: OUTPUT
inverted: true
- platform: gpio
pin:
number: 6
mode: OUTPUT
inverted: true
- platform: gpio
pin:
number: 7
mode: OUTPUT
inverted: true
cover:
- platform: endstop
open_action:
- switch.turn_on: out_y03
open_duration: 40sec
open_endstop: in_x01
close_action:
- switch.turn_on: out_y04
close_duration: 40sec
close_endstop: in_x02
stop_action:
- switch.turn_off: out_y03
- switch.turn_off: out_y04
type or paste code here
I’d like to but I’m not all that familiar with esp32. I’m just good at figuring things out when I have to but I really don’t have time right now to help. That said, have you had a look at this post?
