Since I set up Google Assistant (OK Google turn off the light) the voice output in the Home assistant no longer works. So when I enter the text and press “ENTER” google home says nothing. It makes a startup sound and a volume sound.
What can i do?
Mine worked for a while, then it stopped working, randomly started working again.
Switched things from Node-Red cast to HA cast.
Then it stopped working again.
I’ve kind of given up on it, Node-Red has been having weird issues as well.
