Gets this error message on the new login screen,
It started with this error,
[supervisor.docker.interface] Can’t install ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2024.1.0: 500 Server Error for http+docker://localhost/v1.43/images/ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2024.1.0/json: Internal Server Error (“layer does not exist”)
and later it says,
ERROR (MainThread) [supervisor.docker.interface] Can’t install ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2024.1.1: 404 Client Error for http+docker://localhost/v1.43/images/ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2024.1.1/json: Not Found (“No such image: Package raspberrypi4-64-homeassistant · GitHub”)
I can see that my log is updating, first it said 2024.1.0 then 2024.1.1 as hear and now 2024.1.2…
Any ideas how to recover this?
