I noticed a couple days ago my HA instance was not available and returns una couple minutes from a reboot.
I was seeing this every day in different times since then but when I check the logs only shows me the current (new) session. So I can not find the culprit.
hello! i change the power supply and the sd to a external SSD. Everything was fine and i notice right now the server is offline, i can’t do SSH to it or even the 4357 port. It’s like blocked, again, and when return online i have nothing on the logs to check whats going on.
The SSD have the lights On like “writing” and the ethernet port blinks too.
