My HACS has amnesia
I have HACS installed on a Mac for Home Assistant in a virtual environment. Pretty well every time I restart Home Assistant and go the the HACS tab, it indicates:
  • HACS needs updating (You have 1.0.X, 1.3.3 is available). In the concole it shows I do have 1.3.3 on startup.
  • Every repository I have installed needs updating, including Ecowitt which is no longer installed. It reports currently installed versions are those that were current when I first installed them.
  • There are new repositories available - I have dismissed these many times but the same ones return, with newer ones added over time.
I have tried uninstalling and reinstalling HACS from the frontend and the backend files. I have uninstalled and reinstalled the repositories including deletion of the files in www. The problem persists and I’m starting to get buried in new repositories alerts!
Any ideas? Is the updater broken somehow??
