When i go to supervisor and hardware. I can’t see my devices, what can be wrong?
This is what i see:
"devices:
- name: event0
sysfs: ‘/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input0/event0’
dev_path: /dev/input/event0
subsystem: input
by_id: null
attributes:
DEVNAME: /dev/input/event0
DEVPATH: ‘/devices/LNXSYSTM:00/LNXPWRBN:00/input/input0/event0’
ID_INPUT: ‘1’
ID_INPUT_KEY: ‘1’
ID_PATH: ‘acpi-LNXPWRBN:00’
ID_PATH_TAG: acpi-LNXPWRBN_00
MAJOR: ‘13’
MINOR: ‘64’
SUBSYSTEM: input
TAGS: ‘:power-switch:’
USEC_INITIALIZED: ‘1858271’ - name: event1
sysfs: ‘/sys/devices/LNXSYSTM:00/LNXSLPBN:00/input/input1/event1’
dev_path: /dev/input/event1
subsystem: input
by_id: null
attributes:
DEVNAME: /dev/input/event1
DEVPATH: ‘/devices/LNXSYSTM:00/LNXSLPBN:00/input/input1/event1’
ID_INPUT: ‘1’
ID_INPUT_KEY: ‘1’
ID_PATH: ‘acpi-LNXSLPBN:00’
ID_PATH_TAG: acpi-LNXSLPBN_00
MAJOR: ‘13’
MINOR: ‘65’
SUBSYSTEM: input
USEC_INITIALIZED: ‘1860829’ - name: event2
sysfs: >-
/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/LNXVIDEO:00/input/input2/event2
dev_path: /dev/input/event2
subsystem: input
by_id: null
attributes:
DEVNAME: /dev/input/event2
DEVPATH: >-
ID_INPUT: ‘1’
ID_INPUT_KEY: ‘1’
ID_PATH: ‘acpi-LNXVIDEO:00’
ID_PATH_TAG: acpi-LNXVIDEO_00
MAJOR: ‘13’
MINOR: ‘66’
SUBSYSTEM: input
USEC_INITIALIZED: ‘1883624’ - name: sda
sysfs: >-
/sys/devices/pci0000:00/0000:00:01.1/ata1/host0/target0:0:0/0:0:0:0/block/sda
dev_path: /dev/sda
subsystem: block
by_id: /dev/disk/by-id/ata-VBOX_HARDDISK_VB0b0432c3-6bf5e9a0
attributes:
DEVLINKS: >-
/dev/disk/by-path/pci-0000:00:01.1-ata-1
/dev/disk/by-path/pci-0000:00:01.1-ata-1.0
DEVNAME: /dev/sda
DEVPATH: >-
DEVTYPE: disk
ID_ATA: ‘1’
ID_ATA_FEATURE_SET_PM: ‘1’
ID_ATA_FEATURE_SET_PM_ENABLED: ‘1’
ID_ATA_WRITE_CACHE: ‘1’
ID_ATA_WRITE_CACHE_ENABLED: ‘1’
ID_BUS: ata
ID_MODEL: VBOX_HARDDISK
ID_MODEL_ENC: >-
VBOX\x20HARDDISK\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20
ID_PART_TABLE_TYPE: gpt
ID_PART_TABLE_UUID: b1dbbf9d-6532-4f05-8deb-66185c236a60
ID_PATH: ‘pci-0000:00:01.1-ata-1.0’
ID_PATH_ATA_COMPAT: ‘pci-0000:00:01.1-ata-1’
ID_PATH_TAG: pci-0000_00_01_1-ata-1_0
ID_REVISION: ‘1.0’
ID_SERIAL: VBOX_HARDDISK_VB0b0432c3-6bf5e9a0
ID_SERIAL_SHORT: VB0b0432c3-6bf5e9a0
ID_TYPE: disk
MAJOR: ‘8’
MINOR: ‘0’
SUBSYSTEM: block
TAGS: ‘:systemd:’
USEC_INITIALIZED: ‘1946878’ - name: sda1
sysfs: >-
/sys/devices/pci0000:00/0000:00:01.1/ata1/host0/target0:0:0/0:0:0:0/block/sda/sda1
dev_path: /dev/sda1
subsystem: block
by_id: /dev/disk/by-id/ata-VBOX_HARDDISK_VB0b0432c3-6bf5e9a0-part1
attributes:
DEVLINKS: >-
/dev/disk/by-label/hassos-boot /dev/disk/by-partlabel/hassos-boot
/dev/disk/by-partuuid/b3dd0952-733c-4c88-8cba-cab9b8b4377f
/dev/disk/by-path/pci-0000:00:01.1-ata-1-part1
/dev/disk/by-path/pci-0000:00:01.1-ata-1.0-part1
/dev/disk/by-uuid/B1A4-18FE
DEVNAME: /dev/sda1
DEVPATH: >-
DEVTYPE: partition
ID_ATA: ‘1’
ID_BUS: ata
ID_FS_LABEL: hassos-boot
ID_FS_LABEL_ENC: hassos-boot
ID_FS_TYPE: vfat
ID_FS_USAGE: filesystem
ID_FS_UUID: B1A4-18FE
ID_FS_UUID_ENC: B1A4-18FE
ID_FS_VERSION: FAT16
ID_MODEL_ENC: >-
ID_PART_ENTRY_DISK: ‘8:0’
ID_PART_ENTRY_NAME: hassos-boot
ID_PART_ENTRY_NUMBER: ‘1’
ID_PART_ENTRY_OFFSET: ‘2048’
ID_PART_ENTRY_SCHEME: gpt
ID_PART_ENTRY_SIZE: ‘65536’
ID_PART_ENTRY_TYPE: c12a7328-f81f-11d2-ba4b-00a0c93ec93b
ID_PART_ENTRY_UUID: b3dd0952-733c-4c88-8cba-cab9b8b4377f
ID_REVISION: ‘1.0’
ID_TYPE: disk
MAJOR: ‘8’
MINOR: ‘1’
PARTN: ‘1’
PARTNAME: hassos-boot
SUBSYSTEM: block
TAGS: ‘:systemd:’
USEC_INITIALIZED: ‘2032631’ - name: sda2
sysfs: >-
/sys/devices/pci0000:00/0000:00:01.1/ata1/host0/target0:0:0/0:0:0:0/block/sda/sda2
dev_path: /dev/sda2
subsystem: block
by_id: /dev/disk/by-id/ata-VBOX_HARDDISK_VB0b0432c3-6bf5e9a0-part2
attributes:
DEVLINKS: >-
/dev/disk/by-label/hassos-kernel /dev/disk/by-partlabel/hassos-kernel0
/dev/disk/by-partuuid/26700fc6-b0bc-4ccf-9837-ea1a4cba3e65
/dev/disk/by-path/pci-0000:00:01.1-ata-1-part2
/dev/disk/by-path/pci-0000:00:01.1-ata-1.0-part2
/dev/disk/by-uuid/f3ca48b1-d876-4c67-acdf-de82776e486d
DEVNAME: /dev/sda2
DEVPATH: >-
DEVTYPE: partition
ID_ATA: ‘1’
ID_BUS: ata
ID_FS_LABEL: hassos-kernel
ID_FS_LABEL_ENC: hassos-kernel
ID_FS_TYPE: ext4
ID_FS_UUID: f3ca48b1-d876-4c67-acdf-de82776e486d
ID_FS_UUID_ENC: f3ca48b1-d876-4c67-acdf-de82776e486d
ID_FS_VERSION: ‘1.0’
ID_MODEL_ENC: >-
ID_PART_ENTRY_NAME: hassos-kernel0
ID_PART_ENTRY_NUMBER: ‘2’
ID_PART_ENTRY_OFFSET: ‘67584’
ID_PART_ENTRY_SIZE: ‘49152’
ID_PART_ENTRY_TYPE: 0fc63daf-8483-4772-8e79-3d69d8477de4
ID_PART_ENTRY_UUID: 26700fc6-b0bc-4ccf-9837-ea1a4cba3e65
ID_REVISION: ‘1.0’
ID_TYPE: disk
MAJOR: ‘8’
MINOR: ‘2’
PARTN: ‘2’
PARTNAME: hassos-kernel0
SUBSYSTEM: block
TAGS: ‘:systemd:’
USEC_INITIALIZED: ‘2035468’ - name: sda3
sysfs: >-
/sys/devices/pci0000:00/0000:00:01.1/ata1/host0/target0:0:0/0:0:0:0/block/sda/sda3
dev_path: /dev/sda3
subsystem: block
by_id: /dev/disk/by-id/ata-VBOX_HARDDISK_VB0b0432c3-6bf5e9a0-part3
attributes:
DEVLINKS: >-
/dev/disk/by-partlabel/hassos-system0
/dev/disk/by-partuuid/8d3d53e3-6d49-4c38-8349-aff6859e82fd
/dev/disk/by-path/pci-0000:00:01.1-ata-1-part3
/dev/disk/by-path/pci-0000:00:01.1-ata-1.0-part3
DEVNAME: /dev/sda3
DEVPATH: >-
DEVTYPE: partition
ID_ATA: ‘1’
ID_BUS: ata
ID_FS_TYPE: squashfs
ID_FS_VERSION: ‘4.0’
ID_MODEL_ENC: >-
ID_PART_ENTRY_NAME: hassos-system0
ID_PART_ENTRY_NUMBER: ‘3’
ID_PART_ENTRY_OFFSET: ‘116736’
ID_PART_ENTRY_SIZE: ‘524288’
ID_PART_ENTRY_UUID: 8d3d53e3-6d49-4c38-8349-aff6859e82fd
ID_REVISION: ‘1.0’
ID_TYPE: disk
MAJOR: ‘8’
MINOR: ‘3’
PARTN: ‘3’
PARTNAME: hassos-system0
SUBSYSTEM: block
TAGS: ‘:systemd:’
USEC_INITIALIZED: ‘2056106’ - name: sda4
sysfs: >-
/sys/devices/pci0000:00/0000:00:01.1/ata1/host0/target0:0:0/0:0:0:0/block/sda/sda4
dev_path: /dev/sda4
subsystem: block
by_id: /dev/disk/by-id/ata-VBOX_HARDDISK_VB0b0432c3-6bf5e9a0-part4
attributes:
DEVLINKS: >-
/dev/disk/by-partlabel/hassos-kernel1
/dev/disk/by-partuuid/fc02a4f0-5350-406f-93a2-56cbed636b5f
/dev/disk/by-path/pci-0000:00:01.1-ata-1-part4
/dev/disk/by-path/pci-0000:00:01.1-ata-1.0-part4
DEVNAME: /dev/sda4
DEVPATH: >-
DEVTYPE: partition
ID_ATA: ‘1’
ID_BUS: ata
ID_MODEL_ENC: >-
ID_PART_ENTRY_NAME: hassos-kernel1
ID_PART_ENTRY_NUMBER: ‘4’
ID_PART_ENTRY_OFFSET: ‘641024’
ID_PART_ENTRY_UUID: fc02a4f0-5350-406f-93a2-56cbed636b5f
ID_REVISION: ‘1.0’
ID_TYPE: disk
MAJOR: ‘8’
MINOR: ‘4’
PARTN: ‘4’
PARTNAME: hassos-kernel1
SUBSYSTEM: block
TAGS: ‘:systemd:’
USEC_INITIALIZED: ‘2032443’ - name: sda5
sysfs: >-
/sys/devices/pci0000:00/0000:00:01.1/ata1/host0/target0:0:0/0:0:0:0/block/sda/sda5
dev_path: /dev/sda5
subsystem: block
by_id: /dev/disk/by-id/ata-VBOX_HARDDISK_VB0b0432c3-6bf5e9a0-part5
attributes:
DEVLINKS: >-
/dev/disk/by-partlabel/hassos-system1
/dev/disk/by-partuuid/a3ec664e-32ce-4665-95ea-7ae90ce9aa20
/dev/disk/by-path/pci-0000:00:01.1-ata-1-part5
/dev/disk/by-path/pci-0000:00:01.1-ata-1.0-part5
DEVNAME: /dev/sda5
DEVPATH: >-
DEVTYPE: partition
ID_ATA: ‘1’
ID_BUS: ata
ID_MODEL_ENC: >-
ID_PART_ENTRY_NAME: hassos-system1
ID_PART_ENTRY_NUMBER: ‘5’
ID_PART_ENTRY_OFFSET: ‘690176’
ID_PART_ENTRY_UUID: a3ec664e-32ce-4665-95ea-7ae90ce9aa20
ID_REVISION: ‘1.0’
ID_TYPE: disk
MAJOR: ‘8’
MINOR: ‘5’
PARTN: ‘5’
PARTNAME: hassos-system1
SUBSYSTEM: block
TAGS: ‘:systemd:’
USEC_INITIALIZED: ‘2085796’ - name: sda6
sysfs: >-
/sys/devices/pci0000:00/0000:00:01.1/ata1/host0/target0:0:0/0:0:0:0/block/sda/sda6
dev_path: /dev/sda6
subsystem: block
by_id: /dev/disk/by-id/ata-VBOX_HARDDISK_VB0b0432c3-6bf5e9a0-part6
attributes:
DEVLINKS: >-
/dev/disk/by-partlabel/hassos-bootstate
/dev/disk/by-partuuid/33236519-7f32-4dff-8002-3390b62c309d
/dev/disk/by-path/pci-0000:00:01.1-ata-1-part6
/dev/disk/by-path/pci-0000:00:01.1-ata-1.0-part6
DEVNAME: /dev/sda6
DEVPATH: >-
DEVTYPE: partition
ID_ATA: ‘1’
ID_BUS: ata
ID_MODEL_ENC: >-
ID_PART_ENTRY_NAME: hassos-bootstate
ID_PART_ENTRY_NUMBER: ‘6’
ID_PART_ENTRY_OFFSET: ‘1214464’
ID_PART_ENTRY_SIZE: ‘16384’
ID_PART_ENTRY_UUID: 33236519-7f32-4dff-8002-3390b62c309d
ID_REVISION: ‘1.0’
ID_TYPE: disk
MAJOR: ‘8’
MINOR: ‘6’
PARTN: ‘6’
PARTNAME: hassos-bootstate
SUBSYSTEM: block
TAGS: ‘:systemd:’
USEC_INITIALIZED: ‘2026823’ - name: sda7
sysfs: >-
