Just randomly my hassbian on pi went down, can’t load front page. I can SSH into it.
Anyone see a issue?
Log file:
2018-01-07 21:04:59 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=134 from 2018-01-07 16:51:21.228030) 2018-01-07 21:05:00 ERROR (Thread-21) [homeassistant.components.octoprint] True 1 2018-01-07 21:05:00 ERROR (MainThread) [homeassistant.setup] Error during setup of component octoprint Traceback (most recent call last): File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py", line 193, in _async_setup_component component.setup, hass, processed_config) File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__ yield self # This tells Task to wait for completion. File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup future.result() File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result raise self._exception File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run result = self.fn(*self.args, **self.kwargs) File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/octoprint.py", line 45, in setup octoprint_api.get('printer') File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/octoprint.py", line 107, in get response.raise_for_status() File "/srv/homeassistant/lib/python3.5/site-packages/requests/models.py", line 935, in raise_for_status raise HTTPError(http_error_msg, response=self) requests.exceptions.HTTPError: 409 Client Error: CONFLICT for url: http://192.168.50.137/api/printer 2018-01-07 21:05:01 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of sensor.octoprint. Setup failed for dependencies: octoprint 2018-01-07 21:05:01 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform sensor.octoprint: Could not setup all dependencies. 2018-01-07 21:05:01 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on /tank/level/status3: 0 2018-01-07 21:05:01 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on /tank/level/status4: 0 2018-01-07 21:05:01 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on tank/sumptemp: 76.55 2018-01-07 21:05:01 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on tank/tanktemp: 76.44 2018-01-07 21:05:01 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on tank/status: Offline 2018-01-07 21:05:02 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on /tank/level/status1: 1 2018-01-07 21:05:02 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on /tank/level/status2: 0 2018-01-07 21:05:02 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on /tank/alift/status: 0 2018-01-07 21:05:02 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on /tank/12volt/status: 0 2018-01-07 21:05:02 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on /tank/aux1/status: 0 2018-01-07 21:05:02 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on /tank/light/status: 0 2018-01-07 21:05:02 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on /tank/air/status: 0 2018-01-07 21:05:02 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on /tank/pump/status: 0 2018-01-07 21:05:02 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on /tank/co2/status: 0 2018-01-07 21:05:02 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on /Stank/RGB: {"state":"ON","color":{"r":255,"g":255,"b":255},"brightness":90,"effect":"null"} 2018-01-07 21:05:02 WARNING (Thread-9) [homeassistant.components.emulated_hue] When targeting Google Home, listening port has to be port 80
