My Home Assistant falls into a coma
I installed the Home Assistant OS on a 4GB SSD mounted PI4 and in the past week I haven’t been able to connect as locally as I did with DuckDNS. I noticed that my automation seems to have stopped, I suspected a bad pcu, but the PI leds work, and if I force a restart, everything returns to normal for 3-4 hours, sometimes more … I replaced the PSU anyway just in case, but that hasn’t changed anything … My temperature remains around 47 Celcius, and I don’t see anything abnormal in the log …
Ideas??
By the way I also use
For Raspberry Pi 4, X825 V1.5 2.5 inch SATA HDD/SSD Expansion Board – Geekworm and
Raspberry Pi 4B/3B+/3B X735 V2.5 Safe Shutdown Power Management & PWM – Geekworm
who are among my suspects …
4GB SSD? Sure?
Pi 4 4GB , SSD kingston 120 GB…
What type of sensors are you using? wireless, zigbee, z-wave? This might give indication that the problem is in the wireless or z-wave / zigbee controller. If you have z-wave or zigbee do you have a bad node? I have had failed light switches reek havoc on my system (alot of z-wave nodes).
I have 12 Zwave devices, no bad node, I also have some Zigbee, but I using the Philips Hue hub for the moment…
I also have 5-6 ESP32 and 8266 wifi on ESPHome
I will try to remove my hub to see if it make a change…
