I’m very green with home automation. Our IT guy we use at the office set up a virtual machine on my home server, he said using the Home Assistant guidelines. The issue is Home Assistant keeps restarting every few minutes. He is not familiar with Home Assistant so we are lost. I don’t understand the logs to know what is happening. Is there someone that can troubleshot for me remotely?
Sorry you are having troubles with your setup. Please see here for how to get help: How to help us help you - or How to ask a good question.
So, we need some basic information to help (see #10 & 13)
Don’t want to seem rude, but it seems like you need a new IT guy if he can’t help identify if the issue is host server or VM related. If it’s confirmed to be an HA issue then our community here can assist when you, as MaxK says, provide us some more specific information.
IT guy here, and no one said anything about not knowing if the issue was the host machine or the VM. It’s not the host machine. It’s the HA install that is restarting, no issues with the host.
The HA install has been having issues restarting randomly. Sometimes it happens every 1-3 minutes, sometimes it doesn’t do it for several hours.
We just shut down and booted the VM back up to start with a clean boot. Before I shut it down, I uninstalled the Samba and Zwave JS add-ons. When the HA booted back up, I installed the Samba add-on and made sure I could access the SMB shares. Then I tried to install the Zwave Integration, which installed the Zwave JS add-on. I started the Zwave JS add-on, and still no reboots. I went to install the Zwave Integration and it asked us to select the USB Zwave Adapter, which it saw correctly, and asked for keys that I left blank. It said it was connecting to the Zwave JS add-on, and a few seconds later, we get a notification showing that Home Assistant lost its connection, and the integrations all started back up. I’m not 100% this is an indication that HA restarted (I’m not an idiot, but I don’t know much about Home Assistant), but when Darold said that his HA keeps restarting, that’s what he was referring to.
Home Assistant is version Core 2025.1.3 using the HassOS Image. We downloaded the HA VMware Workstation VMDK and created a new VM using VMware Workstation Pro 17.6.2.
I will include the Home Asstant Core, Supervisor, and Zwave log files in 3 separate posts below just to keep them separated.
Home Assistant Log
[23:00:41] INFO: Home Assistant Core finish process exit code 0
[23:00:41] INFO: Home Assistant Core service shutdown
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun home-assistant (no readiness notification)
s6-rc: info: service legacy-services successfully started
2025-01-20 17:01:20.235 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-01-20 17:01:23.745 WARNING (MainThread) [denonavr.soundmode] Not able to match sound mode: 'DOLBY PLII MV', assuming 'DOLBY DIGITAL'.
2025-01-20 17:06:22.373 WARNING (MainThread) [denonavr.soundmode] Not able to match sound mode: 'DOLBY PLII MV', assuming 'DOLBY DIGITAL'.
2025-01-20 17:13:12.354 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /addons/core_zwave_js/stats - Container addon_core_zwave_js is not running
2025-01-20 17:13:15.956 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /addons/core_zwave_js/stats - Container addon_core_zwave_js is not running
2025-01-20 17:13:39.428 ERROR (MainThread) [homeassistant.components.zwave_js.config_flow] Failed to get Z-Wave JS add-on discovery info
2025-01-20 17:13:44.435 ERROR (MainThread) [homeassistant.components.zwave_js.config_flow] Failed to get Z-Wave JS add-on discovery info
2025-01-20 17:13:49.439 ERROR (MainThread) [homeassistant.components.zwave_js.config_flow] Failed to get Z-Wave JS add-on discovery info
2025-01-20 17:13:54.445 ERROR (MainThread) [homeassistant.components.zwave_js.config_flow] Failed to get Z-Wave JS add-on discovery info
2025-01-20 17:13:59.448 ERROR (MainThread) [homeassistant.components.zwave_js.config_flow] Failed to get Z-Wave JS add-on discovery info
2025-01-20 17:14:04.452 ERROR (MainThread) [homeassistant.components.zwave_js.config_flow] Failed to get Z-Wave JS add-on discovery info
2025-01-20 17:14:09.459 ERROR (MainThread) [homeassistant.components.zwave_js.config_flow] Failed to get Z-Wave JS add-on discovery info
2025-01-20 17:14:14.464 ERROR (MainThread) [homeassistant.components.zwave_js.config_flow] Failed to get Z-Wave JS add-on discovery info
2025-01-20 17:14:19.468 ERROR (MainThread) [homeassistant.components.zwave_js.config_flow] Failed to get Z-Wave JS add-on discovery info
2025-01-20 17:14:24.471 ERROR (MainThread) [homeassistant.components.zwave_js.config_flow] Failed to get Z-Wave JS add-on discovery info
2025-01-20 17:14:29.475 ERROR (MainThread) [homeassistant.components.zwave_js.config_flow] Failed to get Z-Wave JS add-on discovery info
2025-01-20 17:14:34.478 ERROR (MainThread) [homeassistant.components.zwave_js.config_flow] Failed to get Z-Wave JS add-on discovery info
2025-01-20 17:14:39.485 ERROR (MainThread) [homeassistant.components.zwave_js.config_flow] Failed to get Z-Wave JS add-on discovery info
2025-01-20 17:14:44.486 ERROR (MainThread) [homeassistant.components.zwave_js.config_flow] Failed to get Z-Wave JS add-on discovery info
2025-01-20 17:14:49.490 ERROR (MainThread) [homeassistant.components.zwave_js.config_flow] Failed to get Z-Wave JS add-on discovery info
2025-01-20 17:14:54.494 ERROR (MainThread) [homeassistant.components.zwave_js.config_flow] Failed to get Z-Wave JS add-on discovery info
2025-01-20 17:14:59.496 ERROR (MainThread) [homeassistant.components.zwave_js.config_flow] Failed to get Z-Wave JS add-on discovery info
2025-01-20 17:15:04.499 ERROR (MainThread) [homeassistant.components.zwave_js.config_flow] Failed to get Z-Wave JS add-on discovery info
2025-01-20 17:15:09.504 ERROR (MainThread) [homeassistant.components.zwave_js.config_flow] Failed to get Z-Wave JS add-on discovery info
2025-01-20 17:15:14.507 ERROR (MainThread) [homeassistant.components.zwave_js.config_flow] Failed to get Z-Wave JS add-on discovery info
2025-01-20 17:15:19.510 ERROR (MainThread) [homeassistant.components.zwave_js.config_flow] Failed to get Z-Wave JS add-on discovery info
[23:15:22] INFO: Home Assistant Core finish process exit code 256
[23:15:22] INFO: Home Assistant Core finish process received signal 9
s6-rc: info: service legacy-services: stopping
2025-01-20 17:15:27.015 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-01-20 17:15:27.556 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2025-01-20 17:15:27.570 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=438 from 2025-01-20 23:01:20.757522)
2025-01-20 17:15:30.367 WARNING (MainThread) [denonavr.soundmode] Not able to match sound mode: 'DOLBY PLII MV', assuming 'DOLBY DIGITAL'.
Supervisor Log
[23:00:37] INFO: Supervisor restart after closing
cont-init: info: running /etc/cont-init.d/udev.sh
[23:01:16] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
[23:01:16] INFO: Starting local supervisor watchdog...
2025-01-20 23:01:17.549 INFO (MainThread) [__main__] Initializing Supervisor setup
2025-01-20 17:01:17.578 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: qemux86-64
2025-01-20 17:01:17.580 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2024.12.3
2025-01-20 17:01:17.585 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
2025-01-20 17:01:17.586 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-01-20 17:01:17.586 INFO (MainThread) [__main__] Setting up Supervisor
2025-01-20 17:01:17.643 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
2025-01-20 17:01:17.667 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
2025-01-20 17:01:17.668 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
2025-01-20 17:01:17.668 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
2025-01-20 17:01:17.668 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
2025-01-20 17:01:17.668 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
2025-01-20 17:01:17.668 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
2025-01-20 17:01:17.668 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
2025-01-20 17:01:17.668 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
2025-01-20 17:01:17.668 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
2025-01-20 17:01:17.668 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
2025-01-20 17:01:17.723 INFO (MainThread) [supervisor.host.services] Updating service information
2025-01-20 17:01:17.725 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2025-01-20 17:01:17.726 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
2025-01-20 17:01:17.787 INFO (MainThread) [supervisor.host.network] Updating local network information
2025-01-20 17:01:17.819 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
2025-01-20 17:01:17.827 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
2025-01-20 17:01:17.827 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
2025-01-20 17:01:17.880 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2024.09.0
2025-01-20 17:01:17.884 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
2025-01-20 17:01:17.886 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning hassio_cli application
2025-01-20 17:01:18.063 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2024.09.0 - 172.30.32.5
2025-01-20 17:01:18.070 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2024.12.0
2025-01-20 17:01:18.079 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
2025-01-20 17:01:18.082 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning hassio_dns application
2025-01-20 17:01:18.247 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2024.12.0 - 172.30.32.3
2025-01-20 17:01:18.248 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
2025-01-20 17:01:18.253 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2023.12.0
2025-01-20 17:01:18.257 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
2025-01-20 17:01:18.261 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning hassio_audio application
2025-01-20 17:01:18.466 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2023.12.0 - 172.30.32.4
2025-01-20 17:01:18.469 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0
2025-01-20 17:01:18.477 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2024.03.0
2025-01-20 17:01:18.482 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
2025-01-20 17:01:18.484 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_multicast application
2025-01-20 17:01:18.582 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2024.03.0 - Host
2025-01-20 17:01:18.585 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 1 Home Assistant secrets
2025-01-20 17:01:18.590 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version 2025.1.3
2025-01-20 17:01:18.619 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 14.1 / BootSlot A
2025-01-20 17:01:18.762 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/d5369777 repository
2025-01-20 17:01:18.762 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
2025-01-20 17:01:18.762 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
2025-01-20 17:01:18.763 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
2025-01-20 17:01:18.763 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/cb646a50 repository
2025-01-20 17:01:18.880 INFO (MainThread) [supervisor.store] Loading add-ons from store: 81 all - 81 new - 0 remove
2025-01-20 17:01:18.890 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
2025-01-20 17:01:18.897 INFO (MainThread) [supervisor.backups.manager] Found 8 backup files
2025-01-20 17:01:18.902 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
2025-01-20 17:01:18.902 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
2025-01-20 17:01:18.902 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
2025-01-20 17:01:18.902 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_removed/addon
2025-01-20 17:01:18.902 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2025-01-20 17:01:18.902 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_missing/addon
2025-01-20 17:01:18.902 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2025-01-20 17:01:18.902 INFO (MainThread) [supervisor.resolution.check] System checks complete
2025-01-20 17:01:18.902 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2025-01-20 17:01:18.903 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-01-20 17:01:18.903 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
2025-01-20 17:01:18.903 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2025-01-20 17:01:18.903 INFO (MainThread) [__main__] Running Supervisor
2025-01-20 17:01:18.908 INFO (MainThread) [supervisor.os.manager] Rauc: slot A - activated slot kernel.0, marked slot kernel.0 as good
2025-01-20 17:01:18.912 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
2025-01-20 17:01:18.913 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-ons
2025-01-20 17:01:18.913 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 0 add-ons
2025-01-20 17:01:18.915 INFO (MainThread) [supervisor.core] Start Home Assistant Core
2025-01-20 17:01:18.922 INFO (SyncWorker_1) [supervisor.docker.manager] Starting homeassistant
2025-01-20 17:01:19.005 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
2025-01-20 17:01:20.796 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state startup
2025-01-20 17:01:20.796 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-01-20 17:01:24.062 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2025-01-20 17:01:24.064 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='NOT_RUNNING', offline_db_migration=False)
2025-01-20 17:01:29.087 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='RUNNING', offline_db_migration=False)
2025-01-20 17:01:29.087 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
2025-01-20 17:01:29.088 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 0 add-ons
2025-01-20 17:01:29.093 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
2025-01-20 17:01:29.093 INFO (MainThread) [supervisor.core] Supervisor is up and running
2025-01-20 17:01:29.095 INFO (MainThread) [supervisor.host.info] Updating local host information
2025-01-20 17:01:29.100 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2025-01-20 17:01:29.101 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2025-01-20 17:01:29.105 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2025-01-20 17:01:29.118 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2025-01-20 17:01:29.120 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2025-01-20 17:01:29.120 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2025-01-20 17:01:29.123 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2025-01-20 17:01:29.123 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2025-01-20 17:01:29.124 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2025-01-20 17:01:29.199 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
2025-01-20 17:01:29.201 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2025-01-20 17:01:29.201 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2025-01-20 17:01:29.216 INFO (MainThread) [supervisor.resolution.check] System checks complete
2025-01-20 17:01:29.217 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2025-01-20 17:01:29.226 INFO (MainThread) [supervisor.host.services] Updating service information
2025-01-20 17:01:29.242 INFO (MainThread) [supervisor.host.network] Updating local network information
2025-01-20 17:01:29.364 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2025-01-20 17:01:29.384 INFO (MainThread) [supervisor.host.manager] Host information reload completed
2025-01-20 17:01:29.400 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-01-20 17:01:29.400 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2025-01-20 17:01:29.401 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2025-01-20 17:05:33.599 INFO (MainThread) [supervisor.addons.addon] No core_samba addon Docker image homeassistant/amd64-addon-samba found
2025-01-20 17:05:33.602 INFO (MainThread) [supervisor.docker.interface] Downloading docker image homeassistant/amd64-addon-samba with tag 12.4.0.
2025-01-20 17:05:35.721 INFO (MainThread) [supervisor.addons.addon] Creating Home Assistant add-on data folder /data/addons/data/core_samba
2025-01-20 17:05:35.724 INFO (MainThread) [supervisor.docker.interface] Downloading docker image homeassistant/amd64-addon-samba with tag 12.4.0.
2025-01-20 17:05:36.264 INFO (MainThread) [supervisor.addons.manager] Add-on 'core_samba' successfully installed
2025-01-20 17:06:24.586 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-samba with version 12.4.0
2025-01-20 17:06:24.662 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from core_samba
2025-01-20 17:10:39.412 INFO (MainThread) [supervisor.addons.addon] No core_zwave_js addon Docker image homeassistant/amd64-addon-zwave_js found
2025-01-20 17:10:39.414 INFO (MainThread) [supervisor.docker.interface] Downloading docker image homeassistant/amd64-addon-zwave_js with tag 0.9.0.
2025-01-20 17:10:43.910 INFO (MainThread) [supervisor.addons.addon] Creating Home Assistant add-on data folder /data/addons/data/core_zwave_js
2025-01-20 17:10:43.912 INFO (MainThread) [supervisor.docker.interface] Downloading docker image homeassistant/amd64-addon-zwave_js with tag 0.9.0.
2025-01-20 17:10:44.613 INFO (MainThread) [supervisor.addons.manager] Add-on 'core_zwave_js' successfully installed
2025-01-20 17:11:12.092 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/bus/usb/002/004 - None
2025-01-20 17:11:12.098 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/gpiochip0 - None
2025-01-20 17:11:12.106 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/ttyUSB0 - /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_eeb327175585ed11b98bd09f9d1cc348-if00-port0
2025-01-20 17:12:37.762 INFO (SyncWorker_0) [supervisor.addons.addon] Creating Home Assistant add-on config folder /data/addon_configs/core_zwave_js
2025-01-20 17:12:38.986 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-zwave_js with version 0.9.0
2025-01-20 17:13:12.349 ERROR (SyncWorker_1) [supervisor.docker.manager] Container addon_core_zwave_js is not running
2025-01-20 17:13:15.954 ERROR (SyncWorker_5) [supervisor.docker.manager] Container addon_core_zwave_js is not running
2025-01-20 17:13:33.384 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning addon_core_zwave_js application
2025-01-20 17:13:34.414 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-zwave_js with version 0.9.0
2025-01-20 17:13:35.634 INFO (MainThread) [supervisor.api.middleware.security] /host/info access from core_zwave_js
2025-01-20 17:15:21.873 INFO (SyncWorker_5) [supervisor.docker.manager] Cleaning addon_core_zwave_js application
2025-01-20 17:15:22.635 WARNING (MainThread) [supervisor.homeassistant.websocket] Connection is closed
2025-01-20 17:15:22.738 ERROR (SyncWorker_3) [supervisor.docker.manager] Can't start addon_core_zwave_js: 500 Server Error for http+docker://localhost/v1.47/containers/8d94e0518b3b11bbeb956d01ee44098acded314205606b34360ff773f126352d/start: Internal Server Error ("failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: writing syncT "procResume": write init-p: broken pipe: unknown")
2025-01-20 17:15:25.755 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
2025-01-20 17:15:25.767 INFO (SyncWorker_2) [supervisor.docker.manager] Starting homeassistant
2025-01-20 17:15:25.816 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
2025-01-20 17:15:27.599 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2025-01-20 17:15:27.762 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-01-20 17:15:30.830 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='NOT_RUNNING', offline_db_migration=False)
2025-01-20 17:15:36.023 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='RUNNING', offline_db_migration=False)
2025-01-20 17:15:36.023 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
Z-Wave Log
2025-01-20T21:52:21.021Z DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗
2025-01-20T21:52:21.024Z DRIVER version 13.10.3
2025-01-20T21:52:21.025Z DRIVER
2025-01-20T21:52:21.025Z DRIVER starting driver...
2025-01-20T21:52:21.025Z DRIVER opening serial port /dev/ttyUSB0
[21:52:21] INFO: Service restart after closing
[15:52:22] ERROR: Something went wrong contacting the API
[15:52:22] INFO: Successfully send discovery information to Home Assistant.
[21:52:22] INFO: Service restart after closing
[15:52:24] INFO: Successfully send discovery information to Home Assistant.
[21:52:24] INFO: Service restart after closing
[15:52:25] INFO: Successfully send discovery information to Home Assistant.
[21:52:26] INFO: Service restart after closing
[21:52:27] INFO: Service restart after closing
[15:52:28] INFO: Successfully send discovery information to Home Assistant.
[21:52:28] INFO: Service restart after closing
[15:52:30] INFO: Successfully send discovery information to Home Assistant.
[21:52:30] INFO: Service restart after closing
[15:52:32] INFO: Successfully send discovery information to Home Assistant.
[21:52:32] INFO: Service restart after closing
[15:52:33] INFO: Successfully send discovery information to Home Assistant.
[21:52:34] INFO: Service restart after closing
[15:52:35] INFO: Successfully send discovery information to Home Assistant.
[21:52:35] INFO: Service restart after closing
[15:52:37] INFO: Successfully send discovery information to Home Assistant.
[21:52:37] INFO: Service restart after closing
[15:52:38] INFO: Successfully send discovery information to Home Assistant.
[21:52:39] INFO: Service restart after closing
[15:52:40] INFO: Successfully send discovery information to Home Assistant.
[21:52:40] INFO: Service restart after closing
[15:52:41] INFO: Successfully send discovery information to Home Assistant.
[21:52:42] INFO: Service restart after closing
[15:52:43] INFO: Successfully send discovery information to Home Assistant.
[21:52:44] INFO: Service restart after closing
[21:52:45] INFO: Service restart after closing
[15:52:46] INFO: Successfully send discovery information to Home Assistant.
[15:52:47] INFO: Successfully send discovery information to Home Assistant.
[21:52:48] INFO: Service restart after closing
[15:52:49] INFO: Successfully send discovery information to Home Assistant.
[21:52:50] INFO: Service restart after closing
[15:52:51] INFO: Successfully send discovery information to Home Assistant.
[21:52:51] INFO: Service restart after closing
[21:52:53] INFO: Service restart after closing
[15:52:53] INFO: Successfully send discovery information to Home Assistant.
[21:52:54] INFO: Service restart after closing
[21:52:55] INFO: Service restart after closing
[15:52:55] INFO: Successfully send discovery information to Home Assistant.
[15:52:56] INFO: Successfully send discovery information to Home Assistant.
[21:52:57] INFO: Service restart after closing
[21:52:58] INFO: Service restart after closing
[15:52:58] INFO: Successfully send discovery information to Home Assistant.
[15:52:59] INFO: Successfully send discovery information to Home Assistant.
[21:53:00] INFO: Service restart after closing
[21:53:01] INFO: Service restart after closing
[15:53:01] INFO: Successfully send discovery information to Home Assistant.
[21:53:02] INFO: Service restart after closing
[21:53:03] INFO: Service restart after closing
[15:53:03] INFO: Successfully send discovery information to Home Assistant.
[21:53:04] INFO: Service restart after closing
[15:53:05] INFO: Successfully send discovery information to Home Assistant.
[21:53:06] INFO: Service restart after closing
[21:53:07] INFO: Service restart after closing
[21:53:08] INFO: Service restart after closing
[21:53:09] INFO: Service restart after closing
[21:53:10] INFO: Service restart after closing
[15:53:12] INFO: Successfully send discovery information to Home Assistant.
[21:53:12] INFO: Service restart after closing
[21:53:13] INFO: Service restart after closing
[15:53:13] INFO: Successfully send discovery information to Home Assistant.
[15:53:14] ERROR: Something went wrong contacting the API
[21:53:14] INFO: Service restart after closing
[21:53:15] INFO: Service restart after closing
[21:53:17] INFO: Service restart after closing
[21:53:18] INFO: Service restart after closing
[15:53:19] INFO: Successfully send discovery information to Home Assistant.
[21:53:19] INFO: Service restart after closing
[21:53:20] INFO: Service restart after closing
[15:53:20] INFO: Successfully send discovery information to Home Assistant.
[15:53:22] INFO: Successfully send discovery information to Home Assistant.
[21:53:22] INFO: Service restart after closing
[21:53:23] INFO: Service restart after closing
[15:53:24] INFO: Successfully send discovery information to Home Assistant.
[21:53:24] INFO: Service restart after closing
[21:53:26] INFO: Service restart after closing
[21:53:27] INFO: Service restart after closing
[21:53:28] INFO: Service restart after closing
[15:53:29] INFO: Successfully send discovery information to Home Assistant.
[21:53:30] INFO: Service restart after closing
[21:53:31] INFO: Service restart after closing
[15:53:31] INFO: Successfully send discovery information to Home Assistant.
[21:53:32] INFO: Service restart after closing
[15:53:33] INFO: Successfully send discovery information to Home Assistant.
[15:53:35] INFO: Successfully send discovery information to Home Assistant.
[21:53:35] INFO: Service restart after closing
[21:53:36] INFO: Service restart after closing
[15:53:36] INFO: Successfully send discovery information to Home Assistant.
[21:53:37] INFO: Service restart after closing
[21:53:39] INFO: Service restart after closing
[15:53:39] INFO: Successfully send discovery information to Home Assistant.
[15:53:40] INFO: Successfully send discovery information to Home Assistant.
[21:53:40] INFO: Service restart after closing
[21:53:41] INFO: Service restart after closing
[21:53:43] INFO: Service restart after closing
[21:53:44] INFO: Service restart after closing
[15:53:45] INFO: Successfully send discovery information to Home Assistant.
[21:53:46] INFO: Service restart after closing
[15:53:47] INFO: Successfully send discovery information to Home Assistant.
[21:53:48] INFO: Service restart after closing
[15:53:49] INFO: Successfully send discovery information to Home Assistant.
[21:53:49] INFO: Service restart after closing
[21:53:50] INFO: Service restart after closing
[15:53:50] INFO: Successfully send discovery information to Home Assistant.
[15:53:52] INFO: Successfully send discovery information to Home Assistant.
[21:53:53] INFO: Service restart after closing
[21:53:54] INFO: Service restart after closing
[15:53:55] INFO: Successfully send discovery information to Home Assistant.
[21:53:56] INFO: Service restart after closing
[21:53:57] INFO: Service restart after closing
[15:53:59] INFO: Successfully send discovery information to Home Assistant.
[21:54:00] INFO: Service restart after closing
[15:54:01] INFO: Successfully send discovery information to Home Assistant.
[21:54:01] INFO: Service restart after closing
[21:54:02] INFO: Service restart after closing
[21:54:03] INFO: Service restart after closing
[21:54:05] INFO: Service restart after closing
[15:54:05] INFO: Successfully send discovery information to Home Assistant.
[21:54:06] INFO: Service restart after closing
[15:54:07] INFO: Successfully send discovery information to Home Assistant.
[21:54:07] INFO: Service restart after closing
[21:54:08] INFO: Service restart after closing
[21:54:09] INFO: Service restart after closing
[21:54:11] INFO: Service restart after closing
[15:54:11] INFO: Successfully send discovery information to Home Assistant.
[15:54:12] INFO: Successfully send discovery information to Home Assistant.
[21:54:12] INFO: Service restart after closing
[21:54:14] INFO: Service restart after closing
[21:54:15] INFO: Service restart after closing
[21:54:16] INFO: Service restart after closing
cont-init: info: running /etc/cont-init.d/config.sh
[17:12:39] INFO: No s0_legacy_key is set, generating one...
[17:12:39] INFO: No 'network_key' detected, setting it to 's0_legacy_key' for backwards compatibility
[17:12:39] INFO: No s2_access_control_key is set, generating one...
cont-init: info: /etc/cont-init.d/config.sh exited 137
cont-init: info: running /etc/cont-init.d/structure.sh
cont-init: info: /etc/cont-init.d/structure.sh exited 0
cont-init: warning: some scripts exited nonzero
s6-rc: warning: unable to start service legacy-cont-init: command exited 1
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
[17:13:34] INFO: Both 'network_key' and 's0_legacy_key' are set and match. All ok.
[17:13:34] INFO: No s2_authenticated_key is set, generating one...
[17:13:34] INFO: No s2_unauthenticated_key is set, generating one...
[17:13:35] INFO: No lr_s2_access_control_key is set, generating one...
[17:13:35] INFO: No lr_s2_authenticated_key is set, generating one...
[17:13:35] INFO: Flushing config to disk due to creation of new key(s)...
[17:13:35] INFO: Soft-reset set to automatic
[17:13:35] INFO: Virtual Machine detected, disabling soft-reset
Killed
Could you also provide CPU, Memory, and disk utilization - just to see if approaching any limits?
This is Darold again. I’m an early riser so I’ll be signing off this evening but I want to thank you in advance for any advice you can help us with. I’ve been able to create some simple dashboards for my wife and I to use but wanted to add some additional items like the Schlage Connect Zwave door locks. Again thank you so much for any advice.
3GB RAM (Started with 768MB), 2 Processors (2 Cores), 32GB Disk (11.5GB Current Size)
Good morning. I’m checking in to see if any of the information we provided helps with a solution?
How much RAM do you have assigned for HA? I’d say minimum is 4GB, all under that can cause random reboots, espacially when you add things (i have 8 GB assigned).
There are addons, known to be problematic, one of them is studio code server (advisable to be restarted regularly, say each night), then supervisor can increase memory consumption…
There are sensors for this (for memory percentage use), but they are disabled by default. Enable them and monitor which of them rises too high.
We have 3GB assigned currently but originally had 768MB like the instructions said for setting up a VM. I’ll delay this to my IT guy. Thank you!
Oh… 768MB assigned? I thought that this info was just ram currently consumed… 768M is waaaaay to low to run HA. Way to low. As said, monitor ram consumption and see how much do you need. For start total ha ram consumption will do (it’s in system monitor).
I don’t use z-wave
But I would assume zwave needs more ram or cpu then available
In the add-ons part could you please check how much cpu/ram zwave takes and make a screenshot like this
you could also stop z-wave here to check if the issue stops
(ofc z-wave will stop working)
Going from the 768MB to 3GB seems to have stopped the restarting for now. My VM maxed out at 3GB so I can’t go any higher. We have installed the monitors and it shows using about 3%. Thank you all VERY MUCH!!!
Some light reading to get you up-to-speed as a new user
: The Home Assistant Cookbook - Index.
I’m glad you solved it (for now). But i still recommend you to start thinking about upgrading RAM on machine where VM is running. In the future you’ll add new things and ram consumption will only increase.
Hi all,
My HA is running on 8GB Generic so I didnt not have a “restart” problem but it was using 6GB Ram. After I uninstalled VS Code Studio add-on now it is using onlu 1.5GB. Just fyi. Maybe this is the reason for you
Cheers
Vscode used to have memory leak. I can’t say if it’s still true, but i still have automation which reloads it every night to reset it’s memory use.
