That is my entire process tree. So there is a lot missing, evidently. Total shutdown of the VM and starting again has the same problem persist.
❯ ping 10.0.0.16
PING 10.0.0.16 (10.0.0.16): 56 data bytes
64 bytes from 10.0.0.16: icmp_seq=0 ttl=64 time=1.392 ms
64 bytes from 10.0.0.16: icmp_seq=1 ttl=64 time=0.554 ms
^C
--- 10.0.0.16 ping statistics ---
2 packets transmitted, 2 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 0.554/0.973/1.392/0.419 ms
http://10.0.0.16:4357 responds with
Home Assistant observer
Supervisor: Connected
Supported: Supported
Healthy: Healthy
In dmesg I see this kind of thing:
[ 20.134940] Initializing XFRM netlink socket
[ 21.297825] hassio: port 1(veth9099e2c) entered blocking state
[ 21.297829] hassio: port 1(veth9099e2c) entered disabled state
[ 21.297907] device veth9099e2c entered promiscuous mode
[ 21.301791] hassio: port 1(veth9099e2c) entered blocking state
[ 21.301795] hassio: port 1(veth9099e2c) entered forwarding state
[ 21.301889] hassio: port 1(veth9099e2c) entered disabled state
[ 22.458885] eth0: renamed from veth665ea4c
[ 22.465346] IPv6: ADDRCONF(NETDEV_CHANGE): veth9099e2c: link becomes ready
[ 22.465380] hassio: port 1(veth9099e2c) entered blocking state
[ 22.465382] hassio: port 1(veth9099e2c) entered forwarding state
[ 22.465421] IPv6: ADDRCONF(NETDEV_CHANGE): hassio: link becomes ready
[ 24.107937] docker0: port 1(vethebbe827) entered blocking state
[ 24.107942] docker0: port 1(vethebbe827) entered disabled state
[ 24.107989] device vethebbe827 entered promiscuous mode
[ 24.304772] hassio: port 2(veth39cc53a) entered blocking state
[ 24.304777] hassio: port 2(veth39cc53a) entered disabled state
[ 24.304833] device veth39cc53a entered promiscuous mode
[ 24.304926] hassio: port 2(veth39cc53a) entered blocking state
[ 24.304928] hassio: port 2(veth39cc53a) entered forwarding state
[ 24.781621] eth0: renamed from veth590981c
[ 24.787519] hassio: port 2(veth39cc53a) entered disabled state
[ 24.787563] IPv6: ADDRCONF(NETDEV_CHANGE): vethebbe827: link becomes ready
[ 24.787579] docker0: port 1(vethebbe827) entered blocking state
[ 24.787581] docker0: port 1(vethebbe827) entered forwarding state
[ 24.787609] IPv6: ADDRCONF(NETDEV_CHANGE): docker0: link becomes ready
[ 24.898518] eth1: renamed from vethbd2fad2
[ 24.907239] IPv6: ADDRCONF(NETDEV_CHANGE): veth39cc53a: link becomes ready
[ 24.907264] hassio: port 2(veth39cc53a) entered blocking state
[ 24.907266] hassio: port 2(veth39cc53a) entered forwarding state
This is interesting:
[core-ssh config]$ cat home-assistant.log
2023-05-28 06:48:21.353 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration meross_lan which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-05-28 06:48:21.384 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration meross_cloud which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-05-28 06:48:21.417 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-05-28 06:48:21.440 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration kodak_smart_home which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-05-28 06:48:21.461 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration watchman which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-05-28 06:48:21.515 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration libratone_zipp which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-05-28 06:48:25.370 ERROR (MainThread) [homeassistant.config] Invalid config for [http]: [webhook] is an invalid option for [http]. Check: http->http->webhook. (See /config/configuration.yaml, line 5). Please check the docs at https://www.home-assistant.io/integrations/http
2023-05-28 06:48:25.475 ERROR (MainThread) [homeassistant.setup] Setup failed for http: Invalid config.
2023-05-28 06:48:25.477 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of api. Setup failed for dependencies: http
2023-05-28 06:48:25.477 ERROR (MainThread) [homeassistant.setup] Setup failed for api: (DependencyError(...), 'Could not setup dependencies: http')
2023-05-28 06:48:25.478 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of auth. Setup failed for dependencies: http
2023-05-28 06:48:25.478 ERROR (MainThread) [homeassistant.setup] Setup failed for auth: (DependencyError(...), 'Could not setup dependencies: http')
2023-05-28 06:48:25.478 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of config. Setup failed for dependencies: http
2023-05-28 06:48:25.478 ERROR (MainThread) [homeassistant.setup] Setup failed for config: (DependencyError(...), 'Could not setup dependencies: http')
2023-05-28 06:48:25.479 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of diagnostics. Setup failed for dependencies: http
2023-05-28 06:48:25.479 ERROR (MainThread) [homeassistant.setup] Setup failed for diagnostics: (DependencyError(...), 'Could not setup dependencies: http')
2023-05-28 06:48:25.479 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of file_upload. Setup failed for dependencies: http
2023-05-28 06:48:25.479 ERROR (MainThread) [homeassistant.setup] Setup failed for file_upload: (DependencyError(...), 'Could not setup dependencies: http')
2023-05-28 06:48:25.480 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of repairs. Setup failed for dependencies: http
2023-05-28 06:48:25.481 ERROR (MainThread) [homeassistant.setup] Setup failed for repairs: (DependencyError(...), 'Could not setup dependencies: http')
2023-05-28 06:48:25.482 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of websocket_api. Setup failed for dependencies: http
2023-05-28 06:48:25.482 ERROR (MainThread) [homeassistant.setup] Setup failed for websocket_api: (DependencyError(...), 'Could not setup dependencies: http')
2023-05-28 06:48:25.483 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of image_upload. Setup failed for dependencies: http
2023-05-28 06:48:25.483 ERROR (MainThread) [homeassistant.setup] Setup failed for image_upload: (DependencyError(...), 'Could not setup dependencies: http')
2023-05-28 06:48:25.483 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of search. Setup failed for dependencies: websocket_api
2023-05-28 06:48:25.484 ERROR (MainThread) [homeassistant.setup] Setup failed for search: (DependencyError(...), 'Could not setup dependencies: websocket_api')
2023-05-28 06:48:25.484 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of analytics. Setup failed for dependencies: api, websocket_api
2023-05-28 06:48:25.486 ERROR (MainThread) [homeassistant.setup] Setup failed for analytics: (DependencyError(...), 'Could not setup dependencies: api, websocket_api')
2023-05-28 06:48:25.487 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of person. Setup failed for dependencies: image_upload
2023-05-28 06:48:25.487 ERROR (MainThread) [homeassistant.setup] Setup failed for person: (DependencyError(...), 'Could not setup dependencies: image_upload')
2023-05-28 06:48:25.488 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of onboarding. Setup failed for dependencies: analytics, auth, http, person
2023-05-28 06:48:25.488 ERROR (MainThread) [homeassistant.setup] Setup failed for onboarding: (DependencyError(...), 'Could not setup dependencies: analytics, auth, http, person')
2023-05-28 06:48:25.489 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of frontend. Setup failed for dependencies: api, auth, config, diagnostics, file_upload, http, onboarding, repairs, search, websocket_api
2023-05-28 06:48:25.489 ERROR (MainThread) [homeassistant.setup] Setup failed for frontend: (DependencyError(...), 'Could not setup dependencies: api, auth, config, diagnostics, file_upload, http, onboarding, repairs, search, websocket_api')
2023-05-28 06:48:28.868 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2023-05-28 06:48:29.001 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=106 from 2023-05-27 20:41:56.429763)
2023-05-28 06:48:29.077 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of webhook. Setup failed for dependencies: http
2023-05-28 06:48:29.078 ERROR (MainThread) [homeassistant.setup] Setup failed for webhook: (DependencyError(...), 'Could not setup dependencies: http')
2023-05-28 06:48:29.078 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of hassio. Setup failed for dependencies: http
2023-05-28 06:48:29.078 ERROR (MainThread) [homeassistant.setup] Setup failed for hassio: (DependencyError(...), 'Could not setup dependencies: http')
2023-05-28 06:48:29.079 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of usb. Setup failed for dependencies: websocket_api
2023-05-28 06:48:29.079 ERROR (MainThread) [homeassistant.setup] Setup failed for usb: (DependencyError(...), 'Could not setup dependencies: websocket_api')
2023-05-28 06:48:29.079 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of network. Setup failed for dependencies: websocket_api
2023-05-28 06:48:29.080 ERROR (MainThread) [homeassistant.setup] Setup failed for network: (DependencyError(...), 'Could not setup dependencies: websocket_api')
2023-05-28 06:48:29.714 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of cloud. Setup failed for dependencies: http, webhook
2023-05-28 06:48:29.715 ERROR (MainThread) [homeassistant.setup] Setup failed for cloud: (DependencyError(...), 'Could not setup dependencies: http, webhook')
2023-05-28 06:48:29.716 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of zeroconf. Setup failed for dependencies: network, api
2023-05-28 06:48:29.716 ERROR (MainThread) [homeassistant.setup] Setup failed for zeroconf: (DependencyError(...), 'Could not setup dependencies: network, api')
2023-05-28 06:48:29.717 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of bluetooth. Setup failed for dependencies: usb
2023-05-28 06:48:29.717 ERROR (MainThread) [homeassistant.setup] Setup failed for bluetooth: (DependencyError(...), 'Could not setup dependencies: usb')
2023-05-28 06:48:29.718 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of ssdp. Setup failed for dependencies: network
2023-05-28 06:48:29.718 ERROR (MainThread) [homeassistant.setup] Setup failed for ssdp: (DependencyError(...), 'Could not setup dependencies: network')
2023-05-28 06:48:30.561 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of samsungtv. Setup failed for dependencies: ssdp
2023-05-28 06:48:30.562 ERROR (MainThread) [homeassistant.setup] Setup failed for samsungtv: (DependencyError(...), 'Could not setup dependencies: ssdp')
2023-05-28 06:48:30.562 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of system_health. Setup failed for dependencies: http
2023-05-28 06:48:30.563 ERROR (MainThread) [homeassistant.setup] Setup failed for system_health: (DependencyError(...), 'Could not setup dependencies: http')
2023-05-28 06:48:30.564 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of conversation. Setup failed for dependencies: http
2023-05-28 06:48:30.565 ERROR (MainThread) [homeassistant.setup] Setup failed for conversation: (DependencyError(...), 'Could not setup dependencies: http')
2023-05-28 06:48:30.565 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of map. Setup failed for dependencies: frontend
2023-05-28 06:48:30.565 ERROR (MainThread) [homeassistant.setup] Setup failed for map: (DependencyError(...), 'Could not setup dependencies: frontend')
2023-05-28 06:48:30.566 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of media_source. Setup failed for dependencies: http
2023-05-28 06:48:30.567 ERROR (MainThread) [homeassistant.setup] Setup failed for media_source: (DependencyError(...), 'Could not setup dependencies: http')
2023-05-28 06:48:30.567 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of stream. Setup failed for dependencies: http
2023-05-28 06:48:30.568 ERROR (MainThread) [homeassistant.setup] Setup failed for stream: (DependencyError(...), 'Could not setup dependencies: http')
2023-05-28 06:48:30.568 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of media_player. Setup failed for dependencies: http
2023-05-28 06:48:30.572 ERROR (MainThread) [homeassistant.setup] Setup failed for media_player: (DependencyError(...), 'Could not setup dependencies: http')
2023-05-28 06:48:30.573 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of history. Setup failed for dependencies: http
2023-05-28 06:48:30.573 ERROR (MainThread) [homeassistant.setup] Setup failed for history: (DependencyError(...), 'Could not setup dependencies: http')
2023-05-28 06:48:30.574 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of stt. Setup failed for dependencies: http
2023-05-28 06:48:30.574 ERROR (MainThread) [homeassistant.setup] Setup failed for stt: (DependencyError(...), 'Could not setup dependencies: http')
2023-05-28 06:48:30.575 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of my. Setup failed for dependencies: frontend
2023-05-28 06:48:30.575 ERROR (MainThread) [homeassistant.setup] Setup failed for my: (DependencyError(...), 'Could not setup dependencies: frontend')
2023-05-28 06:48:30.576 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of logbook. Setup failed for dependencies: frontend, http
2023-05-28 06:48:30.576 ERROR (MainThread) [homeassistant.setup] Setup failed for logbook: (DependencyError(...), 'Could not setup dependencies: frontend, http')
2023-05-28 06:48:30.621 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of hacs. Setup failed for dependencies: http, websocket_api, frontend, repairs
2023-05-28 06:48:30.622 ERROR (MainThread) [homeassistant.setup] Setup failed for custom integration hacs: (DependencyError(...), 'Could not setup dependencies: http, websocket_api, frontend, repairs')
2023-05-28 06:48:30.622 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of plex. Setup failed for dependencies: http
2023-05-28 06:48:30.623 ERROR (MainThread) [homeassistant.setup] Setup failed for plex: (DependencyError(...), 'Could not setup dependencies: http')
2023-05-28 06:48:30.623 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of apple_tv. Setup failed for dependencies: zeroconf
2023-05-28 06:48:30.623 ERROR (MainThread) [homeassistant.setup] Setup failed for apple_tv: (DependencyError(...), 'Could not setup dependencies: zeroconf')
2023-05-28 06:48:30.624 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of thread. Setup failed for dependencies: zeroconf
2023-05-28 06:48:30.625 ERROR (MainThread) [homeassistant.setup] Setup failed for thread: (DependencyError(...), 'Could not setup dependencies: zeroconf')
2023-05-28 06:48:30.625 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of application_credentials. Setup failed for dependencies: auth, websocket_api
2023-05-28 06:48:30.625 ERROR (MainThread) [homeassistant.setup] Setup failed for application_credentials: (DependencyError(...), 'Could not setup dependencies: auth, websocket_api')
2023-05-28 06:48:30.661 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of energy. Setup failed for dependencies: websocket_api, history
2023-05-28 06:48:30.662 ERROR (MainThread) [homeassistant.setup] Setup failed for energy: (DependencyError(...), 'Could not setup dependencies: websocket_api, history')
2023-05-28 06:48:30.664 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of dlna_dmr. Setup failed for dependencies: ssdp
2023-05-28 06:48:30.664 ERROR (MainThread) [homeassistant.setup] Setup failed for dlna_dmr: (DependencyError(...), 'Could not setup dependencies: ssdp')
2023-05-28 06:48:30.665 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of camera. Setup failed for dependencies: http
2023-05-28 06:48:30.665 ERROR (MainThread) [homeassistant.setup] Setup failed for camera: (DependencyError(...), 'Could not setup dependencies: http')
2023-05-28 06:48:30.666 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of tts. Setup failed for dependencies: http
2023-05-28 06:48:30.666 ERROR (MainThread) [homeassistant.setup] Setup failed for tts: (DependencyError(...), 'Could not setup dependencies: http')
2023-05-28 06:48:30.830 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of assist_pipeline. Setup failed for dependencies: conversation, stt, tts
2023-05-28 06:48:30.830 ERROR (MainThread) [homeassistant.setup] Setup failed for assist_pipeline: (DependencyError(...), 'Could not setup dependencies: conversation, stt, tts')
2023-05-28 06:48:30.990 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of mobile_app. Setup failed for dependencies: http, webhook, person, websocket_api
2023-05-28 06:48:30.990 ERROR (MainThread) [homeassistant.setup] Setup failed for mobile_app: (DependencyError(...), 'Could not setup dependencies: http, webhook, person, websocket_api')
2023-05-28 06:48:30.994 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of esphome. Setup failed for dependencies: assist_pipeline, bluetooth
2023-05-28 06:48:30.994 ERROR (MainThread) [homeassistant.setup] Setup failed for esphome: (DependencyError(...), 'Could not setup dependencies: assist_pipeline, bluetooth')
2023-05-28 06:48:31.827 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: application_credentials, assist_pipeline, bluetooth, cloud, conversation, energy, frontend, history, logbook, map, media_source, mobile_app, my, network, person, ssdp, stream, system_health, usb, webhook, zeroconf
2023-05-28 06:48:31.828 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: (DependencyError(...), 'Could not setup dependencies: application_credentials, assist_pipeline, bluetooth, cloud, conversation, energy, frontend, history, logbook, map, media_source, mobile_app, my, network, person, ssdp, stream, system_health, usb, webhook, zeroconf')
2023-05-28 06:48:41.110 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of homekit. Setup failed for dependencies: http, network
2023-05-28 06:48:41.111 ERROR (MainThread) [homeassistant.setup] Setup failed for homekit: (DependencyError(...), 'Could not setup dependencies: http, network')
2023-05-28 06:48:50.803 ERROR (SyncWorker_5) [homeassistant.util.package] Unable to install package python-kodaksmarthome==0.1.5b1: ERROR: Cannot install python-kodaksmarthome==0.1.5b1 because these package versions have conflicting dependencies.
ERROR: ResolutionImpossible: for help visit https://pip.pypa.io/en/latest/topics/dependency-resolution/#dealing-with-dependency-conflicts
[notice] A new release of pip is available: 23.1 -> 23.1.2
[notice] To update, run: pip install --upgrade pip
2023-05-28 06:48:54.277 ERROR (SyncWorker_5) [homeassistant.util.package] Unable to install package python-kodaksmarthome==0.1.5b1: ERROR: Cannot install python-kodaksmarthome==0.1.5b1 because these package versions have conflicting dependencies.
2023-05-28 06:48:57.873 ERROR (SyncWorker_5) [homeassistant.util.package] Unable to install package python-kodaksmarthome==0.1.5b1: ERROR: Cannot install python-kodaksmarthome==0.1.5b1 because these package versions have conflicting dependencies.
2023-05-28 06:48:57.875 ERROR (MainThread) [homeassistant.setup] Setup failed for custom integration kodak_smart_home: Requirements for kodak_smart_home not found: ['python-kodaksmarthome==0.1.5b1'].
2023-05-28 09:57:18.567 WARNING (MainThread) [custom_components.meross_lan] MerossMQTTConnection(1420176:mqtt-us-2.meross.com:443): device(Cherub Baby Machine) not registered for MQTT handling on this profile
2023-05-28 10:15:42.587 ERROR (MainThread) [homeassistant.components.sharkiq] Unexpected error updating SharkIQ. Attempting re-auth
File "/usr/src/homeassistant/homeassistant/components/sharkiq/update_coordinator.py", line 71, in _async_update_data
all_vacuums = await self.ayla_api.async_list_devices()
File "/usr/local/lib/python3.10/site-packages/sharkiq/ayla_api.py", line 208, in async_list_devices
devices = await resp.json()
File "/usr/src/homeassistant/homeassistant/helpers/aiohttp_client.py", line 72, in json
return await super().json(*args, loads=loads, **kwargs)
File "/usr/local/lib/python3.10/site-packages/aiohttp/client_reqrep.py", line 1104, in json
raise ContentTypeError(
aiohttp.client_exceptions.ContentTypeError: 0, message='Attempt to decode JSON with unexpected mimetype: text/html', url=URL('https://ads-field-39a9391a.aylanetworks.com/apiv1/devices.json')
2023-05-28 10:15:42.711 ERROR (MainThread) [homeassistant.components.sharkiq] Error fetching sharkiq data: 0, message='Attempt to decode JSON with unexpected mimetype: text/html', url=URL('https://ads-field-39a9391a.aylanetworks.com/apiv1/devices.json')
Any idea how to proceed?
