I have an old USB Z-Wave+ stick from Homeseer, it’s labeled “SmartStick+” and was advertised as z-wave+ only. I just moved to Zwave JS and was looking at the config. It lists the device as:
HUSBZB-1
by Sigma Designs (Former Zensys)
Firmware: 4.32
From my understanding, this hardware supports ZWave+ and Zigbee. Is it simply limited by the firmware? Could this be flashed with another firmware to enable Zigbee?
Config also says:
Highest Security: None
Z-Wave Plus: No
Why is this saying I don’t have Z-Wave Plus?
EDIT to add: in my depreciated Zwave config, the device is listed as Sigma Designs UZB, which is a z-wave only device. Is this a case where the device is being mislabeled by Zwave JS?
Doubtful it even has a Zigbee radio. Do you have multiple device paths? One would be for z-wave, the other for zigbee. If only one path, it’s just z-wave. The product identifiers are generic (0x0000:0x0001:0x0001), I’d assume HomeSeer just didn’t bother to program it. Some devices are just relabeled by other manufacturers.
Because those properties don’t apply to USB controllers, only nodes added to the network.
So I noticed the same thing with the same HomeSeer SmartStick+. On the HomeSeer website it says it is a 700 series chip while the HUSBZB-1 (at least the Nortek version) is a 500 series chip. I assume the HomeSeer is 700 series but not sure how to verify this.
