I noticed that my hue bulbs have disappeared from HA. I recently renamed a couple lights via the Hue app. Not sure if that’s the cause.
I tried deleting phue.conf and restarting. I got the configurator and everything appears to have completed correctly. I see an entry in phue.conf with my hub’s correct IP address.
I’ve tried using discovery (I usually have it turned off) and also with a “platform: hue” entry in my YAML.
You know I’m really not sure what might be wrong, only think I can think to do is check the log by forcing info? Maybe then you can see what’s happening?
logger:
default: warning
logs:
homeassistant.components.hue: info
I’m not actually sure what the hue component should be written as could also be:
logger:
default: warning
logs:
homeassistant.components.light.hue: info
Hmm. No luck there, either. I only get some basic response from the Hue component
2017-10-20 08:56:55 INFO (Thread-7) [phue] Attempting to connect to the bridge...
2017-10-20 08:56:55 INFO (Thread-7) [phue] Using ip: 192.168.1.105
2017-10-20 08:56:55 INFO (Thread-7) [phue] Using username from config: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
OK. I’ve got them back now. I turned off the hub, turned it back on, then cycled each of my hue bulbs. At some point in that process, they reappeared. Weird.
