My Jarvis using Zanzito (Skills Collection)
For those who never heard of Zanzito, it is an amazing Android app that bridge your phone (or any android devices except Android TV) to HA using MQTT. With this app, it is now possible to have voice command and have it feedback to you using any TTS engines (with any voice) that are available for Android. It also has always listening mode where it will wake up when it hears a certain keyword that set by you. That means, instead of "Alexa", "Hey Google", "Siri", "Mycroft", "Jasper" or "Cortana", you can named it anything you like such Jarvis. In other words, you can have your own Jarvis at home.
But what good is Jarvis if it doesn't do much? Well, here I gonna share some "skills" I have created for my Jarvis. I will keep adding new skills to this post from time to time. So bookmark this if you want to see more skills in the future.
Skill #1: Turn on/off anything in HA (method 1)
Command example: "Jarvis, turn on TV"
For this skill, you only need to create 2 activities in Zanzito and 1 automation in HA. Any smart devices that you want to control are added in the HA automation. IMHO, it is simpler and easier to manage. But the downsides are...
  1. Zanzito will only send the first guess as the payload. This reduce the accuracy by 5 times. However, this can be overcome by adding the similar sounding words in HA automation. A bit troublesome, but this is the best I can come up with at the moment.
  2. You can only say turn on this or turn on that which works exactly like Alexa emulated Hue component. If you want more natural command, such as "Jarvis, view Plex" or "Jarvis, disable light automation", see method 2 below.
Activities in Zanzito:
Activity #1:
Topic: %devicename%/switch/turn_on
Payload: [empty]
Retained: [uncheck]
Voice cmd: Turn on
Get payload from vocal command: [check]
Activity #2:
Topic: %devicename%/switch/turn_off
Payload: [empty]
Retained: [uncheck]
Voice cmd: Turn off
Automation in HA:
- alias: 'MQTT Switch'
    - platform: mqtt
      topic: tonystark/switch/#
    - platform: mqtt
      topic: office/switch/#
    - platform: mqtt
      topic: livingroom/switch/#
    - platform: mqtt
      topic: bedroom/switch/#
    - service_template: >
        homeassistant.{{ trigger.topic.split('/')[-1] }}
      data_template:
        entity_id: >-
          {% set payload = trigger.payload %}
          {% set devicename = trigger.topic.split('/')[-3] %}
          {%- if payload == "everything" -%}
            {%- if devicename == "office" -%}
              group.office_all_switches
            {%- elif devicename == "bedroom" -%}
              group.masterbedroom_all_switches
            {%- else -%}
              group.all_items
            {%- endif -%}
          {%- elif payload == "lights" -%}
              switch.office_downlights
              group.masterbedroom_all_lights
            {%- else -%}
              group.livingroom_lights
            {%- endif -%}
          {%- elif payload == "dining" -%}
            group.dining_lights_fan
          {%- elif payload == "kitchen lights" or payload == "kitchen light" -%}
            group.kitchen_lights
          {%- elif payload == "play room" or payload == "playroom" -%}
            group.playroom
          {%- elif payload == "living room lights" -%}
          {%- elif payload == "staircase lights" -%}
            group.staircase_1_lights
          {%- elif payload == "bedroom lights" -%}
          {%- elif payload == "bedroom" -%}
          {%- endif %}
    - service: mqtt.publish
      data_template:
        topic: >-
          zanzito/{{ trigger.topic.split('/')[-3] }}/notification
        payload: >-
          {%- if
            payload == "everything" or
            payload == "lights" or
            payload == "dining" or
            payload == "kitchen light" or
            payload == "playroom" or
            {% set responses = [
            "OK",
            "Sure",
            "If you insist",
            "Done",
            "Alright",
            "No worries",
            "I can do that",
            "Leave it to me",
            "Consider it done",
            "As you wish",
            "By your command",
            "Affirmative",
            "No Problem"
            {% set rindex =  (range(0, (responses | length - 1) )|random) -%}
            {{responses[rindex]}}
          {%- else -%}
            "I'm sorry. I cannot find the device named {{payload}} in the house."
          {% endif %}
Skill #2: Turn on/off anything in HA (method 2).
Command example: "Jarvis, view Plex"
With this method, you can have more natural sounding command. So, instead of "Jarvis, turn on view Plex", you can say "Jarvis, view Plex". However, with this method, you need to create one activity in Zanzito for each switches/lights/scripts/etc... that you want to control. In other words, if you have 50 items that you want control you need to add 50 activities in your phone. Not so easy, if you ask me. So, I only use this for items that need more natural command. The rest I use method 1 above.
Activity #1:
Topic: %devicename%/switchentity/switch/view_plex
Payload: on
Retained: [uncheck]
Voice cmd: view Plex
Get payload from vocal command: [uncheck]
Automation in HA:
- alias: 'MQTT Switch Entity'
    platform: mqtt
    topic: benredminote4/switchentity/#
        homeassistant.turn_{{trigger.payload}}
      data_template:
        entity_id: >-
          {{ trigger.topic.split('/')[-2] }}.{{ trigger.topic.split('/')[-1] }}
      data_template:
        topic: >-
          zanzito/{{ trigger.topic.split('/')[-4] }}/notification
        payload: >-
          "OK",
          "Sure",
          "If you insist",
          "Done",
          "Alright",
          "No worries",
          "I can do that",
          "Leave it to me",
          "Consider it done",
          "As you wish",
          "By your command",
          "Affirmative",
          "No Problem"
Skill #3: Get Sensor States (weather report)
Command example: "Jarvis, how is the weather"
This skill is use to get reply of any sensor states. You need to create 1 activity for each sensor states.
Activity #1:
Topic: %devicename%/getstates/sensor
Payload: weather_condition
Retained: [uncheck]
Voice cmd: how is the weather
Automation in HA:
- alias: 'MQTT Get States - Sensors'
    platform: mqtt
    topic: +/getstates/sensor
    data_template:
      topic: >-
      payload: >-
        {{ states('sensor.' ~ trigger.payload ~ '') }}
Template sensor in HA:
  sensors:
    weather_condition:
      friendly_name: 'Weather Condition'
      value_template: "The weather condition is {{ states('sensor.dark_sky_summary') }} and {{ states('sensor.temp_feel_darksky') }} at {{ states('sensor.dark_sky_temperature') }}°C and the forecast is {{ states('sensor.dark_sky_hourly_summary') }} with temperature ranging from {{ states('sensor.dark_sky_daily_low_temperature') }}°C to {{ states('sensor.dark_sky_daily_high_temperature') }}°C"
      entity_id:
        - sensor.dark_sky_summary
        - sensor.temp_feel_darksky
        - sensor.dark_sky_temperature
        - sensor.dark_sky_hourly_summary
        - sensor.dark_sky_daily_low_temperature
        - sensor.dark_sky_daily_high_temperature
    temp_feel_darksky:
      friendly_name: 'Dark Sky Temperature Feel'
      value_template: >-
          {%- if states.sensor.dark_sky_temperature.state | float < 29 %}
              nice
          {%- elif states.sensor.dark_sky_temperature.state | float < 31 %}
              warm
          {%- elif states.sensor.dark_sky_temperature.state | float < 33 %}
              hot
          {% else %}
              baking
          {%- endif %}
      entity_id: sensor.dark_sky_temperature
Skill #4: Get Sensor States (time and date)
Command example: "Jarvis, what is the time"
This skill uses the same automation from Skill #3.
Activity #1:
Payload: whatisthetime
Retained: [uncheck]
Voice cmd: what is the time
Automation in HA: Same with Skill #3.
  sensors:
    whatisthetime:
      friendly_name: 'The time'
      value_template: >-
          The time is {{ states('sensor.time') }} and today is {{ states('sensor.date') }}.
      entity_id:
        - sensor.time
        - sensor.date
Skill #5: Get Sensor States (health status)
Command example: "Jarvis, how are you"
Activity #1:
Payload: health_status
Retained: [uncheck]
Voice cmd: how are you
  sensors:
# System Health Status Report. Uses systemmonitor sensor platform
    health_status:
      friendly_name: 'System Health Status'
      value_template: "{% if states('sensor.cpu_use') | float > 50 or states('sensor.ram_use') | float > 50 or states('sensor.disk_use_') | float > 50 %}I am not feeling so good. {% else %}I am fine. {% endif %}My C.P.U. usage is {{ states('sensor.cpu_use') }}%, my memory usage is {{ states('sensor.ram_use') }}% and my storage usage is {{ states('sensor.disk_use_') }}%."
      entity_id:
        - sensor.cpu_use
        - sensor.ram_use
        - sensor.disk_use_
Skill #6: Get Sensor States (who is at home)
Command example: "Jarvis, who is at home"
Activity #1:
Payload: whoisathome
Retained: [uncheck]
Voice cmd: who is at home
  sensors:
    whoisathome:
      friendly_name: 'Who is at Home?'
      value_template: >-
        {% for entity in states.group.occupants.attributes.entity_id if is_state(entity, 'home') %}
          {%- if loop.first and loop.last %}
            {{ states[entity.split('.')[0]][entity.split('.')[1]].name }} is the only one at home
          {% elif loop.length == states.group.occupants.attributes.entity_id|length %}
            {{ "Everyone is at home" if loop.last }}
          {% else %}
            {%- if loop.first %}{% elif loop.last %} & {% else %}, {% endif -%}
            {{ states[entity.split('.')[0]][entity.split('.')[1]].name }}{{ " are at home" if loop.last }}
          {%- endif -%}
        {% else %}
          No one is at home
        {% endfor %}
      entity_id:
        - group.occupants
        - device_tracker.luke
        - device_tracker.obiwan
        - device_tracker.leia
        - device_tracker.hansolo
Group in HA:
occupants:
  entities:
Skill #7: Get Sensor States (who is away)
Command example: "Jarvis, who is away"
Activity #1:
Payload: whoisaway
Retained: [uncheck]
Voice cmd: who is away
  sensors:
    whoisaway:
      friendly_name: 'Who is away?'
      value_template: >-
        {% for entity in states.group.occupants.attributes.entity_id if not is_state(entity, 'home') %}
            {{ states[entity.split('.')[0]][entity.split('.')[1]].name }} is the only one away
            {{ "Everyone is away" if loop.last }}
          {% else %}
            {{ states[entity.split('.')[0]][entity.split('.')[1]].name }}{{ " are away" if loop.last }}
          {%- endif -%}
        {% else %}
          No one is away
        {% endfor %}
      entity_id:
        - group.occupants
Group in HA: Same with Skill #6
Skill #8: Get Sensor States (where is XXX)
Command example: "Jarvis, where is Luke"
Activity #1:
Payload: whereis_luke
Retained: [uncheck]
Voice cmd: where is Luke
  sensors:
    whereis_luke:
      friendly_name: 'Where is Luke'
      value_template: >-
          Luke is currently {% if (is_state('device_tracker.owntrack_luke', 'not_home')) %}not at home{% else %}at {{ states('device_tracker.owntrack_luke') }}{% endif %}
      entity_id:
        - device_tracker.owntrack_luke
Skill #9: Chit Chat (who are you)
Command example: "Jarvis, who are you"
This is a simple skill but equally important. Ask it a simple question and it will reply back with a predefined response. It acts like Alexa's easter eggs.
Activity #1:
Topic: %devicename%/chitchat
Payload: whoareyou
Retained: [uncheck]
Voice cmd: who are you
Automation in HA:
- alias: 'MQTT Chit Chat - Who Are You?'
    platform: mqtt
    topic: +/chitchat
    payload: "whoareyou"
    data_template:
      topic: >-
        zanzito/{{ trigger.topic.split('/')[-2] }}/notification
      payload: "This is Jarvis, the virtual butler of this house. My purpose is to serve the occupants of my house and makes their life better. I take care of the house when no one is around, check the traffic condition, appointments, holidays, weather, air quality, control the lights and many more. I am learning new skills everyday."
Skill #10: Chit Chat (thank you)
Command example: "Thank you Jarvis"
Variant of random responses.
Activity #1:
Payload: thankyou
Retained: [uncheck]
Voice cmd: thank you
Automation in HA:
- alias: 'MQTT Chit Chat - thank you'
    platform: mqtt
    topic: +/chitchat
    payload: "thankyou"
    data_template:
      topic: >-
      payload: >-
        "You're welcome",
        "You got it",
        "Don't mention it",
        "No worries",
        "Not a problem",
        "It's my pleasure",
        "It was nothing",
        "I'm happy to help",
        "Not at all",
        "Sure",
        "That's okay",
        "That's alright",
        "Anytime"
Skill #11: Chit Chat (tell me a joke)
Command example: "Jarvis, tell me a joke"
Activity #1:
Payload: joke
Retained: [uncheck]
Voice cmd: tell me a joke
Automation in HA:
- alias: 'MQTT Chit Chat - tell me a joke'
    platform: mqtt
    topic: +/chitchat
    payload: "joke"
    data_template:
      topic: >-
      payload: >-
        "Joke 1",
        "Joke 2",
        "Joke 3"
Skill #12: Chit Chat (good morning)
Command example: "Good morning Jarvis"
In this example, you can include sensor values in the response
Activity #1:
Payload: greeting
Retained: [uncheck]
Voice cmd: good morning
Automation in HA:
- alias: 'MQTT Chit Chat - good morning'
    platform: mqtt
    topic: +/chitchat
    payload: "greeting"
    data_template:
      topic: >-
      payload: >-
        {% set day = now().strftime('%A') %}
        {{ states('sensor.greeting') }}. Today is {{ day }}{% if states('calendar.holidays') == 'on' %} and it is {{ states.calendar.holidays.attributes.message }}{% endif %}. {{ states('sensor.weather_condition') }}.
Skill #13: Chit Chat (where is my phone)
Command example: "Jarvis, where is my phone"
This is skill will help you find your phone. It requires multiple Zanzitos. First Zanzito is of course your phone. Second Zanzito will be another Android device such as a tablet on the wall.
In your wall tablet's Zanzito:
Activities:
Payload: whereismyphone
Retained: [uncheck]
Voice cmd: where is my phone
In your phone's Zanzito:
  • Take note of your Device name (e.g. myphone)
  • Preference > Play alarm
Play alarm: [check]
Alarm sound: [select any sound you prefer]
Override "silent" mode: [check]
Automation in HA:
- alias: 'MQTT Chit Chat - where is my phone?'
    platform: mqtt
    topic: +/chitchat
    payload: "whereismyphone"
        topic: zanzito/myphone/alarm/play
      data_template:
        topic: >-
        payload: >-
          Your phone is{% if states('device_tracker.owntrack_ironman') == 'not_home' %} not at home {% else %} at {{states('device_tracker.owntrack_ironman')}} {% endif %}. I have triggered the alarm so that you can find it. Good Luck!
Skill #14: Media player control
Command examples:
  • "Jarvis, play Plex"
  • "Jarvis, pause Plex"
  • "Jarvis, resume Plex"
  • "Jarvis, stop Plex"
This skill will let you have basic controls to any media players entity in HA. I am using this to control my Plex and Spotify with my voice.
Activity #1:
Topic: %devicename%/media_player/volume_mute
Payload: [empty]
Retained: [uncheck]
Voice cmd: mute
Activity #2:
Name: Media next rack
Topic: %devicename%/media_player/media_next_rack
Payload: [empty]
Retained: [uncheck]
Voice cmd: next rack
Activity #3:
Topic: %devicename%/media_player/media_pause
Payload: [empty]
Retained: [uncheck]
Voice cmd: pause
Activity #4:
Topic: %devicename%/media_player/media_play
Payload: [empty]
Retained: [uncheck]
Voice cmd: play
Activity #5:
Name: Media previous track
Topic: %devicename%/media_player/media_previous_track
Payload: [empty]
Retained: [uncheck]
Voice cmd: previous track
Activity #6:
Payload: [empty]
Retained: [uncheck]
Voice cmd: resume
Activity #7:
Topic: %devicename%/media_player/media_stop
Payload: [empty]
Retained: [uncheck]
Voice cmd: stop
Activity #8:
Name: Media volume down
Topic: %devicename%/media_player/volume_down
Payload: [empty]
Retained: [uncheck]
Voice cmd: volume down
Activity #9:
Name: Media volume up
Topic: %devicename%/media_player/volume_up
Payload: [empty]
Retained: [uncheck]
Voice cmd: volume up
Automation in HA:
- alias: 'Media Player Control'
    - platform: mqtt
      topic: tonystark/media_player/#
    - platform: mqtt
      topic: office/media_player/#
    - platform: mqtt
      topic: livingroom/media_player/#
    - platform: mqtt
      topic: bedroom/media_player/#
        media_player.{{ trigger.topic.split('/')[-1] }}
      data_template:
        entity_id: >-
          {%- if payload == "plex" or payload == "tv" -%}
            {%- if devicename == "bedroom" -%}
              media_player.plex_mi_box
            {%- else -%}
              media_player.plex_rasplexlr
            {%- endif -%}
          {%- elif payload == "living room plex" or payload == "living room tv" -%}
          {%- elif payload == "bedroom plex" or payload == "bedroom tv" -%}
          {%- elif payload == "alexa" or payload == "spotify" or payload == "bedroom alexa" or payload == "bedroom spotify" -%}
            media_player.spotify_master_bedroom
          {%- endif %}
      data_template:
        topic: >-
        payload: >-
          {%- if
            payload == "tv" or
            payload == "living room tv" or
            payload == "bedroom tv" or
            "OK",
            "Sure",
            "If you insist",
            "Done",
            "Alright",
            "No worries",
            "I can do that",
            "Leave it to me",
            "Consider it done",
            "As you wish",
            "By your command",
            "Affirmative",
            "No Problem"
          {%- else -%}
          {% endif %}
Skill #15: Volume set control
Command examples: "Jarvis, set Plex volume to 7"
This skill will let you set the volume of any media players entity in HA to any levels. So instead of saying "Jarvis, volume down Plex" for multiple times, I can simply say, "Jarvis set Plex volume to 7". You need 1 activity for each media player.
Activity #1:
Name: Volume set Plex living room
Topic: %devicename%/volume_set/plex_rasplexlr
Payload: [empty]
Retained: [uncheck]
Voice cmd: set Plex volume to
Automation in HA:
- alias: 'Volume set Control'
    - platform: mqtt
      topic: tonystark/volume_set/#
    - platform: mqtt
      topic: office/volume_set/#
    - platform: mqtt
      topic: livingroom/volume_set/#
    - platform: mqtt
      topic: bedroom/volume_set/#
        media_player.volume_set
      data_template:
        entity_id: media_player.{{trigger.topic.split('/')[-1]}}
        volume_level: >-
          {%- set payload = trigger.payload %}
          {%- if payload == 'one' %}{% set payload = 1 %}
          {%- elif payload == 'two' %}{% set payload = 2 %}
          {%- elif payload == 'three' %}{% set payload = 3 %}
          {%- elif payload == 'four' %}{% set payload = 4 %}
          {%- elif payload == 'five' %}{% set payload = 5 %}
          {%- elif payload == 'six' %}{% set payload = 6 %}
          {%- elif payload == 'seven' %}{% set payload = 7 %}
          {%- elif payload == 'eight' %}{% set payload = 8 %}
          {%- elif payload == 'nine' %}{% set payload = 9 %}
          {%- elif payload == 'ten' %}{% set payload = 10 %}
          {%- endif %}
          {%- if payload | int and payload | int > 0 and payload | int <= 10 %}{{ payload | int / 10 }}{% endif %}
      data_template:
        topic: >-
        payload: >-
          {%- endif %}
            "OK",
            "Sure",
            "If you insist",
            "Done",
            "Alright",
            "No worries",
            "I can do that",
            "Leave it to me",
            "Consider it done",
            "As you wish",
            "By your command",
            "Affirmative",
            "No Problem"
          {%- else -%}
            "I'm sorry. {{payload}} is not valid. Please use value from 1 to 10 only."
          {% endif %}
Skill #16: Set timer
Command examples:
  • "Jarvis, set timer for 1 hour 15 minutes and 30 seconds"
  • "Jarvis, set timer for 3 minutes and 10 seconds"
  • "Jarvis, set timer for 3 minutes"
This skill will analyze your command and extract the required value. In this case hours, minutes and seconds. It will pass the value to a script to be used as a script delay. Once the delay is up, it will trigger the phone alarm.
Activity #1:
Topic: %devicename%/set_timer
Payload: [empty]
Retained: [uncheck]
Voice cmd: set timer for
Automation in HA:
- alias: 'Set Timer'
    - platform: mqtt
      topic: +/set_timer
    - service: script.reset_timer
      data_template:
        delay_seconds: >-
          {%- set words = trigger.payload.split(' ') -%}
          {%- for word in words -%}
            {%- if word == 'second' or word == 'seconds' -%}
              {%- set value = words[loop.index0|int-1] | int -%}
              {%- if value | int -%}{{ value }}
              {%- endif -%}
            {%- endif -%}
          {%- endfor -%}
        delay_minutes: >-
            {%- if word == 'minute' or word == 'minutes' -%}
              {%- endif -%}
            {%- endif -%}
          {%- endfor -%}
        delay_hours: >-
            {%- if word == 'hour' or word == 'hours' -%}
              {%- endif -%}
            {%- endif -%}
          {%- endfor -%}
        alarmtopic: >-
          zanzito/{{ trigger.topic.split('/')[-2] }}/alarm/play
      data_template:
        topic: >-
        payload: >-
          "OK. Timer set for {{trigger.payload}}"
The timer script in HA:
 reset_timer:
  alias: "Reset Timer"
  sequence:
    # Cancel ev. old timers
    - service: script.turn_off
         entity_id: script.start_timer
    # Set new timer
    - service: script.start_timer
      data_template:
        delay: '{{"%0.02d" | format(delay_hours|int)}}:{{"%0.02d" | format(delay_minutes|int)}}:{{"%0.02d" | format(delay_seconds|int)}}'
        alarmtopic: '{{alarmtopic}}'
start_timer:
  alias: "Start Timer"
  sequence:
    - delay: '{{delay}}'
      data_template:
        topic: >-
          {{alarmtopic}}
Skill #17: Cancel timer
Command examples: "Jarvis, cancel timer"
If you change your mind, you can cancel timer with this skill.
Activity #1:
Topic: %devicename%/cancel_timer
Payload: [empty]
Retained: [uncheck]
Voice cmd: cancel timer
Automation in HA:
- alias: 'Cancel Timer'
    - platform: mqtt
      topic: +/cancel_timer
      data_template:
        topic: >-
        payload: >-
          "OK. Timer cancelled."
Continue here.
I’ve been following the Zanzito thread and this is a really helpful guide to implementing it. Thanks for your contribution!
@MrMep
wish the developer can put multiple voice commands in one single activity
I would like this beeing second method (payload not from vocal command)
Let say you have 24 hours, 60 minutes and 60 seconds. That means you need to create 24 x 60 x 60 = 86400 activities. Good luck!
mmhh yeah, in this case you are right :stuck_out_tongue:
...continue
Skill #18: Send Message
Command examples: "Jarvis, message living room Luke it's time to go to bed"
Now, you can message to other Zanzitos (or other notification platform) using your voice and have your message read out loud. You need to create one activities per recipient.
Activity #1:
Name: Message Living Room
Topic: %devicename%/message/livingroom
Payload: [empty]
Retained: [uncheck]
Voice cmd: message living room
Automation in HA:
- alias: 'Message'
    - platform: mqtt
      topic: tonystark/message/+
    - platform: mqtt
      topic: office/message/+
    - platform: mqtt
      topic: livingroom/message/+
    - platform: mqtt
      topic: bedroom/message/+
    - service_template: >-
          notify.{{ trigger.topic.split('/')[-1] }}
      data_template:
        title: ""
        message: >-
          {% if devicename == 'tonystark' %}
            {% set from = 'Tony' %}
          {% elif devicename == 'livingroom' %}
            {% set from = 'living room' %}
          {% else %}
            {% set from = devicename %}
          {% endif %}
          Message from {{from}}, "{{trigger.payload}}"
      data_template:
        topic: >-
        payload: >-
          OK. Message, "{{trigger.payload}}" sent to {{ trigger.topic.split('/')[-1] }}
Skill #19: Show me living room
Command examples: "Jarvis, show me living room"
With this skill, you can ask Jarvis send you the snapshot from your camera! Just duplicate the activities and automation for each cameras that you want to see.
Activity #1:
Name: Show me Living Room
Topic: %devicename%/showme
Payload: livingroom
Retained: [uncheck]
Voice cmd: show me living room
Automation in HA:
- alias: 'Show me living room'
    - platform: mqtt
      topic: +/showme
      payload: "livingroom"
          notify.{{ trigger.topic.split('/')[-2] }}
        message: ""
          photo:
            - url: http://<cam snapshot URL>
              username: !secret cam_username
              password: !secret cam_password
that’s a nice skill.
I am trying to do everything in Italian, my language (also because in English I have good alternative with the Echo and Google Home, I love Zanzito because I can use Italian), with the weather unfortunately I get back the weather in english, spelled as if it was italian: a disaster.
Any way to get weather in other language?
I found this
https://darksky.net/dev/docs/forecast
and is possible to change the language, although I don’t know how to put that with Zanzito …
Solved:
do you know which is the IP address of an Android IP Webcam?
should be this
http://IP:8080/shot.jpg
but is not working, where should the photo go?
@MrMep
if I go on PHOTO GALLERY
is showing “Updating Pictures…” but not updating
When sent through Zanzito’s notifier component, and if everything related is enabled in Zanzito’s preferences, you get a notification when the pictures arrives. THEN, you find it also in the gallery, but only after it is received as notification. So, I guess, it’s the sending part that is not working…
You should first check the url with a browser, then you put it into a notification service call.
I’m using masterkenobi code. But username and password is in the URL.
It does work on a browser
Then use the URL (with username and password) and remove username and password variables from the code. That mean, just send the URL.
Yes I did that (removed lines with username and password) but where should the picture be visible? (In photo gallery is not)
It will send to your zanzito. You will see it in a notification
This I have in automation
 - alias: 'Foto soggiorno'
      - platform: mqtt
        topic: +/showme
        payload: "soggiorno"
          message: ""
            photo:
              - url: http://192.168.1.52:8080/shot.jpg
If I do
in browser I do ghet a photo (no user or password asigned in program android ip webcam)
I created a new activity
Topic %devicename%/showme
payload soggiorno
retained unchecked
voice cmd foto soggiorno
get payload from voice cmd uncheck
when I run the voice command (I see that is recognized, in outbound is mi5splus/showme soggiorno),
but where is the photo?
Have you created the notify.mydevice entity using zanzito notification custom component?
this?
notify:
  - name: claudio_zanzito
    platform: zanzito
    device-name: mi5splus
