My latest Lovelace Screens [Updated]
@tempaone please remove line under style this is what is causing the visibility issues for you
background-image: url("/local/lovelace/cardbackK.png")
still didnt work
Capture
Did you clear your browser cache?
Are you using any themes?
yeah loaded in incognito mode too…
theme copied your yaml…
Packages/Theme Control
Themes
frontend:
themes:
midnight:
Main colors
  primary-color: '#5294E2'                                                        # Header
  accent-color: '#E45E65'                                                         # Accent color
  dark-primary-color: 'var(--accent-color)'                                       # Hyperlinks
  light-primary-color: 'var(--accent-color)'                                      # Horizontal line in about
Text colors
  primary-text-color: '#FFFFFF'                                                   # Primary text colour, here is referencing dark-primary-color
  text-primary-color: 'var(--primary-text-color)'                                 # Primary text colour
  secondary-text-color: '#5294E2'                                                 # For secondary titles in more info boxes etc.
  disabled-text-color: '#7F848E'                                                  # Disabled text colour
  label-badge-border-color: 'green'                                               # Label badge border, just a reference value
Background colors
  primary-background-color: '#383C45'                                             # Settings background
  secondary-background-color: '#383C45'                                           # Main card UI background
  divider-color: 'rgba(0, 0, 0, .12)'                                             # Divider
Table rows
  table-row-background-color: '#353840'                                           # Table row
  table-row-alternative-background-color: '#3E424B'                               # Table row alternative
Nav Menu
  paper-listbox-color: 'var(--primary-color)'                                     # Navigation menu selection hoover
  paper-listbox-background-color: '#2E333A'                                       # Navigation menu background
  paper-grey-50: 'var(--primary-text-color)'
  paper-grey-200: '#414A59'                                                       # Navigation menu selection
Paper card
  paper-card-header-color: 'var(--accent-color)'                                  # Card header text colour
  paper-card-background-color: '#434954'                                          # Card background colour
  paper-dialog-background-color: '#434954'                                        # Card dialog background colour
  paper-item-icon-color: 'var(--primary-text-color)'                              # Icon color
  paper-item-icon-active-color: '#ffc107'                                         # Icon color active
  paper-item-icon_-_color: 'green'
  paper-item-selected_-_background-color: '#434954'                               # Popup item select
  paper-tabs-selection-bar-color: 'green'
Labels
  label-badge-red: 'var(--accent-color)'                                          # References the brand colour label badge border
  label-badge-text-color: 'var(--primary-text-color)'                             # Now same as label badge border but that's a matter of taste
  label-badge-background-color: '#2E333A'                                         # Same, but can also be set to transparent here
Switches
  paper-toggle-button-checked-button-color: 'var(--accent-color)'
  paper-toggle-button-checked-bar-color: 'var(--accent-color)'
  paper-toggle-button-checked-ink-color: 'var(--accent-color)'
  paper-toggle-button-unchecked-button-color: 'var(--disabled-text-color)'
  paper-toggle-button-unchecked-bar-color: 'var(--disabled-text-color)'
  paper-toggle-button-unchecked-ink-color: 'var(--disabled-text-color)'
Sliders
  paper-slider-knob-color: 'var(--accent-color)'
  paper-slider-knob-start-color: 'var(--accent-color)'
  paper-slider-pin-color: 'var(--accent-color)'
  paper-slider-active-color: 'var(--accent-color)'
  paper-slider-container-color: 'linear-gradient(var(--primary-background-color), var(--secondary-background-color)) no-repeat'
  paper-slider-secondary-color: 'var(--secondary-background-color)'
  paper-slider-disabled-active-color: 'var(--disabled-text-color)'
  paper-slider-disabled-secondary-color: 'var(--disabled-text-color)'
Google colors
  google-red-500: '#E45E65'
  google-green-500: '#39E949'
Automations
automation:
  • alias: ‘Set Theme to Midnight’
    • platform: homeassistant
      event: start
    • service: frontend.set_theme
Hello
After latest update on Hassio (from 0.84.1 to 0.84.6) this happend… the round edges on the picture was square again but not the cards corners.
Namnl%C3%B6s
My config:
- type: custom:card-modder
            card:
              type: picture-elements
              image: /local/lovelace/home/house.jpg
              elements:
                - type: state-icon
                  entity: binary_sensor.doorsensors_status
                  style: {color: white, left: 8%, top: 90%}
                - type: state-label
                  entity: sensor.qubino_zmnhadx_flush_1_relay_temperature
                  style: {color: white, left: 91%, top: 90%}
            style:
              border-radius: 20px
              border: solid 1px rgba(100,100,100,0.3)
              box-shadow: 3px 3px rgba(0,0,0,0.4)
I think maybe it has something to do with picture-elements changes on the 0.84.3 update, - [[ * Fix for picture element positioning (#2335) @iantrich ]] - but Im not sure what.
Help!
add this to your style
overflow: hidden
Worked! Thanks! :grinning:
Also dude -3.2c it’s like 34c here today
Up north in Sweden! Can get -35c here in the winter… :cold_face:
@jimpower we’re working on updating the Home Assistant demo on the website and would love to include parts of your config. Would you want to contribute the config of 2 or 3 tabs for the demo? Instructions how to contribute can be found here https://github.com/home-assistant/home-assistant-polymer/wiki/Contributing-a-Lovelace-config-for-the-demo
@balloob I’d be happy to contribute let me look at whats required do you have any preference as to which tabs?
Cool UI indeed!
Do you mind to share your themes.yaml (Cant find it in your repo), which specify your primary-color, accent-color, etc?
can you told me how you do that?
also like this?
איך סידרת ככה?
In international forums write in English.
