My Lovelace Plugins
I tried and just used the latest script. But having the same issue:
Fri Jan 11 2019 13:35:59 GMT+0200 (Eastern European Standard Time)
Error running command: python /config/python_scripts/lovelace-gen.py, return code: 1
NoneType: None
The latest version should never return 1.
What are you using to run it?
It’s not supposed to be in /config/python_scripts/ or to be run as a python_script.
… to be fair, that would make sense, though…
I can see that in your script there isn’t return value 1.
I am using:
shell_command:
  lovelace_gen: 'python /config/python_scripts/lovelace-gen.py'
Your script is in my created folder /python_scripts.
Ok. I managed to reproduce this on mobile.
I think I have fixed it in the latest card-tools update.
Excellent!! Thank you so much for these!!
I had the problem on Safari (Mac) and iOS (iPad and iPhone).
I installed the new version from GitHub and now it happens 1 out of 5 times (refreshing or reopening).
/local/card-tools.js?v=0.1.0:44:20 TypeError: null is not an object (near ā€˜ā€¦firstChild…’)
I then tried it in Chrome and there I’m always getting:
/local/card-tools.js?v=0.1.0:45:9 Uncaught TypeError: Cannot read property ā€˜dispatchEvent’ of null
I also tried:
javascript_version: es5, latest and auto. Nothing changed.
Not sure what I’m doing wrong but thanks for your help.
Ok. Try now.
Awesome!
As far as I can tell (in this short amount of time) it’s now working perfectly.
I will tell if it ever happens again.
Thank you a lot for helping :slight_smile:
@thomasloven, should the card-tools update be shown in the custom_updater?
browser-commander
Now here’s another one I’m really proud of, but it’s getting late over here, so for now I’ll just leave you with a link and a video showing the development version.
I’ll update this post when I’ve had some sleep.
Regarding the folding entity card…
I configure this thus:
          - type: entities
            title: Folding Groups
            show_header_toggle: false
            entities:
              - type: custom:fold-entity-row
                head: group.all_automations
                head: group.scenes
but then in Lovelace, (Storage Mode) after I paste this in raw config, it replaces it with this:
          - type: entities
            entities:
              - type: 'custom:fold-entity-row'
                items:
                  - automation.beta_update_available
                  - automation.close_garage_and_set_alarm
                  - automation.coffee_maker_off
                  - automation.coffee_maker_on
                  - automation.deactivate_alarm_and_open_garage
                  - automation.home_and_away_off
                  - automation.home_and_away_on
                  - automation.lights_off_failsafe
                  - automation.lights_on_failsafe
                  - automation.make_snapshot_copy_backups_to_dropbox
                  - automation.power_state_sonoff_on_ha_start_up
                  - automation.sonoff_firmware_installed
                  - automation.system_runtime
                  - automation.tasmota_initial_setup_all_devices
                  - automation.toothbrush_off
                  - automation.toothbrush_on
                  - automation.turn_lounge_light_on_elevation_25deg_after_4pm
                  - automation.update_available
                head: group.scenes
                items:
                  - scene.bedtime
                  - scene.dining_daylight
                  - scene.dining_normal
                  - scene.dining_warm
                  - scene.lounge_100
                  - scene.lounge_daylight
                  - scene.lounge_movie
                  - scene.lounge_normal
                  - scene.lounge_warm
                  - scene.office_all
                  - scene.office_daylight
                  - scene.office_main
                  - scene.office_warm
                  - scene.desk_daylight
                  - scene.desk_normal
                  - scene.desk_warm
in the raw editor… so what happens if I add new automations or scenes? Is the list supposed to refresh?
Interestingly, if I open up the .storage/lovelace file in an editor it looks like this:
                                    "entities": [
                                            "head": "group.all_automations",
                                            "type": "custom:fold-entity-row"
                                            "head": "group.scenes",
                                    "show_header_toggle": false,
                                    "title": "Folding Groups",
                                    "type": "entities"
If I use configureui it also shows all the individual entities.
I’m confused.
If I add a scene or automation, do I need to trigger Lovelace to refresh this card?
Having the same here. The custom_updater is not showing the latest version of the card-tools.
I manualy updated the card-tools and changed the version to 6ce5d0, which should be the latest version.
Now the updater shows an update to the old version number.
So i think everything with the updater is ok, but it gets the old version number.
After change in lovelace-gen.py in GitHub, that shows how to generate lovelace-gen.log. I found that my one of my lovelace.yaml has some kind of error. After not including that yaml file it works just perfect. I need to look what is wrong in that file.
Mine shows 0a97de for both but I see the latest version in github is what you said. Maybe the custom card tracker is getting the wrong version number? I only added the card yesterday… (I’ll check I really have the latest card tomorrow…)
YOU CAN BE!!
Awesome!
For those who watch the video:
Event type should be browser_command, not browser_cmd.
The custom_updater is working again, I’ve got an update of card-tools. No need to change anything.
Huh. I didn’t know the lovelace editor did that… neat I guess, but I should fix the plugin so that it doesn’t.
Expect an update soon.
Don’t worry, however. As long as head: is a group, whatever is in items: is actually ignored. It will always take what’s currently in the group. In fact, it will probably update the configuration too.
I just got a notice to update to 6ce5d0 so must have been a glitch yesterday…
@thomasloven i’m following your cards for a while. just wanted to say: awesome work you’re doing here. thanks a lot!
