And both of them are susceptible to âcardgateâ which caused lots of custom cards to go down the day before yesterday.
simple-thermostat has an update on github, circle-sensor has an open PR to fix it.
Yes, just updated simple-thermostat and itâs working now⊠about circle-sensor i am waiting a reply from the author⊠I tried also without card-modder but unsuccesfullyâŠ
The yellow is because a geo-location event has gone from the list and is no longer available.
Refreshing doesnât seem to be helping⊠is there anything I can do to stop this happening?
Actually, the group still has that missing entity in itâs json - it hasnât dropped from there yet and so the sensor dropped off because it doesnât exist but the group thinks itâs still there.
Thanks. It seems to only refresh when a new entity is added - then the old ones go⊠but not sure of this. Or maybe it has some kind of fixed polling intervalâŠ
With the useful-markdown-card, can it be used to embed a javascript embed piece of code? It doesnât seem to be rendering anything. It just shows the code. Iâm wanting to embed a graph from another website.
Okay. So I got it working pretty much. Only set back is as you stated before with background stopping at bottom of last card, (havenât figured that out yet, but my fix is just fill up one entire column for now). Big plus for me, the select works awesome for both background and cards at the same time. Just made 2 different paths with same root name(the input_select) that are different pics. Will hafta play around with it a bit more, but thanks again this is very cool!!!
Iâm using slider-entity-row with covers. It works well.
Is there a way to format the % value shown. My cover position values are calculated based on the time of travel. This results in decimal values that look unsightly.
