Explained here wyze cam set up as this thread is for plugins.
The recent update of custom updater makes it show āupdate availableā at every ha restart, but there is no update available.
custom_updater version 4.2.15
Does someone else have that issue with this version?
Does anyone else have performance problems with useful-markdown-card in HA 0.88.1?
I was using it a lot but in recent HA it started getting pretty sluggish. When I open tab with useful-markdown-cards my browser slows down and only refreshing on other tab brings it to full speed. Is it some kind of memory leak? Am I alone?
EDIT: Now I can see there was a huge update of useful-markdown-card 12 days ago. I have tried older version and problem is solved. Kindaā¦ whatās wrong with the new one?
Thanks for letting me know.
Iāve pushed some new updates for useful-markdown-card and for card-tools that might fix this. Iām not entirely sure what the problem is though and havenāt noticed any problems myself, so itās pretty much hit or missā¦
Thatās a miss unfortunately. Going back to bac5502 and crossing my fingers. I would be very happy to share with you some data but donāt know where to start. Iām using most recent Chrome and itās happening both on the computer and on my android phone.
First step would be to check the browser log, and to absolutely without a doubt isolate the issue to useful-markdown-card, e.g. by having it happen in a view with only a UMC and nothing else.
For now I have isolated it to not happening with standard markdown card used in place of UMC. Also there are no errors in console log. But of course it may be happening because of other cards not working fine with UMC in one view (state-switch, card-modder, weather-card, custom-compact-header, layout-card). I will conduct a more in-depth analysis tomorrow.
Thanks! @thomasloven for the new popup config and the animation pointers.
Active borders for alarms, alerts, timers and notifications that display on all views and all devices viewing Lovelaceā¦
Thank you kind sir. Works like a charm. Anyway you know of resizing the window to certain width and height?
Not as far as I know, no.
So no one has this issue, that custom updated says update available when restarting ha?
This thread is about my lovelace plugins. Find or create a thread about custom_updater.
There is nothing in browser debug log. I have also isolated issue to UMC as you suggested. Without nothing else in view the problem is still there (when using Ā± >10 cards). I guess it may have something to do with refreshing many sensors in UMC or even whole UMC cards (I donāt know how you handle this). In older version I can see some slowness but not that striking and it vanishes after a moment when I change view to one not having UMC (like the memory is cleared?). Hope you will find solution because this is great card.
Btw. new layout-card messed my frontendā¦ also great card, but man, itās scary to update
Iāve tried using the popup card with the mini-graph-card (was hoping to make a pupup that is set to large). But this doesnt seem to work:
I made a global entry for my popup: (itās under the resources).
popup_cards:
sensor.hourly_gas_consumption:
title: lamp
card:
type: entities
entities:
- light.livingroom_lights_eettafel
And my card in my panel:
cards:
- animate: true
color_thresholds:
- color: '#f39c12'
value: 0.1
- color: '#d35400'
value: 0.2
- color: '#c0392b'
value: 0.5
entities:
- entity: sensor.hourly_gas_consumption
name: Gasverbruik per uur
height: 150
hour24: true
hours_to_show: 24
line_color: '#f39c12'
more_info: false
points_per_hour: 1
show:
graph: bar
type: 'custom:mini-graph-card'
But this sadly doesnāt work. It does work when i use it on a other entity that isnāt a entity in a mini graphp card.
Did you follow the suggested debugging actions in the readme and in the linked installation instructions?
layout-card has been updated!
Itās now possible to have columns with different widths:
And with combinations of layout-cards and stacks you can make really nice things:
Perhaps @teachingbirds could provide some more examples?
Iāve also released a companion card that works really well with layout-cardā¦
gap-card
An empty, invisible card that does nothing. It just wastes space. And itās potentially awesome!
Donāt worry. This thread hasnāt made me go crazy (yet). Just look at this:
And now the gap a bit larger, and with a nice background image, or perhaps in the center of a magic mirror setup?
Awesome! Now I donāt have to make up non-existent devices to display to adjust empty spaces Much appreciated! Thank you!
Example of how to build a left hand menu and also a gap card instead of alarm next to the clock on the second tab.
really nice!
How did you achieved that ?
