My Lovelace Plugins
I checked - and double checked. The new debug version does however say “Bound to: NONE” - which is so strange, 'cos I have added the two hex-segments (id). And I have restarted. Cleared the cahce for files only. And restarted and checked if the id had changed. Still no binding is being made.
Could you post your player-config.js?
Do you get any errors in your browser log?
Yes! on my Chrome PC I’m getting 3 columns and on my iPhone only 1 so it’s working beautifully now!
Thanks so much.
Hi, this only error I get is still the attribute-error.
I have placed the two .js files under the “www” folder. And the .py file is placed under “custom_components/media_player” folder.
I am using Chrome browser, latest version.
This is the config file:
setTimeout(function() {
// Add your bindings here
// Example:
LovelacePlayer.bind(“media_player.kitchen_dashboard”, “0184f1f8-a59c01db”);
// Remove this line when you found your Device ID
// LovelacePlayer.debug();
}, 200);
And just to verify all I have done:
configuration.yaml:
media_player:
  - platform: floorplan_speaker
tts:
  - platform: google
In ui-lovelace.yaml i have entered the resources in the top of the file:
  - url: /local/lovelace-player.js
    type: js
  - url: /local/lovelace-player-config.js
    type: js
And in ui-lovelace.yaml i get the player up just fine by entering:`
 -  icon: mdi:theater
    title: theater
    cards:
    - type: media-control
      entity: media_player.my_lovelace_player
Do you think it might be that your media player is named media_player.my_lovelace_player but you are trying to bind your browser to media_player.kitched_dashboard?
How did you force the number of columns? I want to have 5 columns instead of the standard 4. column-card always displays only one column for me. I changed max-width in column-card.js. My config:
  - id: energy
    icon: mdi:power-plug
    title: 'Energia'
    cards:
      - type: custom:column-card
        cards:
          - type: entities
            title: 'Miesięczne zużycie energii'
            show_header_toggle: false
            entities:
              - sensor.light_bulbs_salon_energy
              - sensor.light_leds_salon_energy
          - type: history-graph
            title: 'Zużycie energii'
            hours_to_show: 48
            refresh: 60
            entities:
              - sensor.light_leds_salon_power
              - sensor.light_bulbs_salon_power
          - type: entities
            title: 'UPS'
            entities:
              - sensor.ups_status
              - sensor.ups_battery_charge
              - sensor.ups_battery_runtime
              - sensor.ups_load
              - sensor.ups_battery_voltage
              - sensor.ups_input_voltage
          - type: entities
            title: 'Baterie termostatów'
            entities:
              - sensor.battery_thermostat_salon
              - sensor.battery_thermostat_kuchnia
              - sensor.battery_thermostat_antresola
              - sensor.battery_thermostat_antek
              - sensor.battery_thermostat_sypialnia
              - sensor.battery_thermostat_lazienka
          - type: entities
            title: 'Baterie przełączników'
            entities:
              - sensor.battery_switch_light_salon_1
              - sensor.battery_switch_light_salon_2
              - sensor.battery_switch_light_antek
          - type: entities
            title: 'Baterie sensorów temperatury'
            entities:
              - sensor.battery_temp_humi_sensor_salon
              - sensor.battery_temp_humi_sensor_pracownia
              - sensor.battery_temp_humi_sensor_goscinny
              - sensor.battery_temp_humi_sensor_antresola
              - sensor.battery_temp_humi_sensor_gabinet
              - sensor.battery_temp_humi_sensor_antek
              - sensor.battery_temp_humi_sensor_sypialnia
              - sensor.battery_temp_humi_sensor_lazienka
              - sensor.battery_temp_humi_sensor_outdoor
          - type: entities
            title: 'Baterie sensorów ruchu'
            entities:
              - sensor.battery_body_sensor_przedpokoj
              - sensor.battery_body_sensor_salon_1
              - sensor.battery_body_sensor_salon_2
              - sensor.battery_body_sensor_schody
              - sensor.battery_body_sensor_antresola
              - sensor.battery_body_sensor_antek
              - sensor.battery_body_sensor_sypialnia
          - type: entities
            title: 'Baterie sensorów okien/drzwi'
            entities:
              - sensor.battery_window_sensor_kuchnia
              - sensor.battery_door_sensor_pracownia
              - sensor.battery_window_sensor_antresola
              - sensor.battery_door_sensor_sypialnia
And the effect:
Hi Thomas, was that an answer to me? I do not have this entity: “media_player.kitched_dashboard”
  - title: TV & Movies
    icon: mdi:kodi
    panel: true
    cards:
#     - type: horizontal-stack
        cards:
          - type: custom:upcoming-media-card
            service: deleted
            service: deleted
          - type: entities
            title: Newsgroups
            entities:
              - sensor.etc etc
Changed line 91 as per Thomas’ instructions in above post
But instead of the horizontal-stack I used custom column card as you see it commented.
I forgot about panel: true. Thanks.
Exactly, and yet…
Gee you are right. I’ll fix that When I get home. I am so sorry - don’t know why I didn’t see that.
It’s possible to combine “folding-group-entity-row” with “time-input-row”?
I have a group with some switches and some input_datetime and I want the input_datetime components to work like time-input-row…
Thinking that the time-input-row would be great to include in an alarm clock card. I might have to look into that! Great stuff!
I’ll definitely use it! Thanks!
Yes, see the example on github. Just put type: custom:time-input-row under config:.
It’s all entities of the group or none, though.
Hi Thomas,
It works like a charm now - thanks. It is so great!!!
I noted two things:
  1. When calling tts and calling tts again without having the first one being completed, hassio stalls, and I have to reboot hassio. I guess it is not that often it will be a problem.
  2. There is a typo in the installation instruction - bullet 2. floorplay_speaker.py. It should have been floorplan_speaker.py
BR
Martin
Glad to hear it!
And thanks for finding the typo. I’ve corrected it.
Thanks a lot @thomasloven, your lovelace generator works like a charm!
I just got an issue when i try to launch the script from shell_comand component, like it did not run in the correct env, with this error:
File "lovelace-gen.py", line 31, in <module>\n import yaml\nImportError: No module named \'yaml\'
No issue when running the script in venv with Home Assistant user.
I like to use HASS configurator, and it would be very great if I can trigger Lovelace rebuild from ui.
Help would be appreciated :hugs:
That’s correct. The script should be run in the same python environment as home-assistant (especially if you wish to use the states feature).
If you use a virtual env to run hass you can run the script with
<path to venv root>/bin/python3 <path to hass config>/lovelace-gen.py
