Thanks, it works but i have to move to the correct directory, otherwise lovelace directory will not be found.
shell_command:
generate_lovelace: 'cd /path/to/hass/config && /path/to/venv/bin/python /path/to/hass/config/lovelace-gen.py'
shell_command:
@thomasloven Hi. There is something wrong with the card margins in card-column. They are different than in the case of cards arranged one under the other. Take a look at screenshot. Is it possible to fix this somehow?
configuration
- id: home
icon: mdi:home
title: 'Test'
cards:
- type: entities
title: 'card 1'
show_header_toggle: false
entities:
- light.lamp_salon
- light.leds_przedpokoj
- type: entities
title: 'card 2'
entities:
- light.lamp_salon
- type: custom:column-card
cards:
- type: entities
title: 'card 1 in column-card'
entities:
- light.lamp_salon
- type: entities
title: 'card 2 in column-card'
entities:
- light.lamp_salon
Really neat, especially for display attributes without adding loads of redundant entities.
Is there any way to hide or display alternative text when an entity is null, e.g. when there is, currently, no next event in the calendar?
e.g. the right hand panel here could display āNo programmes scheduledā
Is it possible to center it?
my code:
How did you get sky data
Hi. The F1 page looks awasome, please share how you sourced the data?
@hfrancis @myle - the F1 / FE data is sourced from multiple sources, but all go via Google Calendar
The main calendars are .ics files from
F1 : https://www.f1calendar.com/
FE: http://www.rmotorsportscalendar.com/
For the āLive on TVā I have a script that parses the EPG Data from TVHeadend (Iām not able to watch Sky Sports F1 HD on that, so have a channel I canāt watch via TVHeadend but appears in the listings, but then watch on Now TV)ā¦ This script runs on my media centre and writes a ics file to my web space which is subscribed in Google Calendar.
Itās a bit of a naĆÆve script that needs tweaking every year when the channels change / wording is amended.
https://gist.github.com/kevjs1982/ce9075bd102225719f38f77c82dab5b9 has most of the code f1fe.php simply does a file_post_contents to a file based on the sport variable with a body of the ICS file generated.
Hi Thomas,
Great work on all your cards! IĀ“ve been missing a card that reads the entities of a group like the old UI. I think the group feature makes the UI more dynamic then specify them individually.
Would it be possible to add feature to this card to set folding as an option? This means that the card also could be a simple group entity card like the old UI.
Thanks!
Love the new cards! is there any way to change the color-glance card to a specific color rather than the primary colour of the theme? Which line(s) do I need to change in the .js file?
Line 6. Replace var(--primary-color)
with whatever you want.
Thanks for this. Strangely it isn;t changing the colour for me, and I also get a different colour on my iphone compared to every other device. Any ideas what might be causing this? I have cleared the cache a few times.
Hi there,
Just trying to do some styling using the card-modder and Iām running into a few problems.
I managed to mod some ācustom-buttonā cards, but it fails when i try to mod a āfolding-group-entity-rowā card.
The UI will load, but no cards display (just a blanc screen).
Any ideas?
This is amazing stuff!
Just tried the slider-entity-row on my Hue light group (so all the lights in one room, controlled with a slider, eg light.livingroom) and while it works great on my computer browser in Chrome, it does not show up on Android (using Samsung Internet default app). This is the error I see in the logs:
http://myip:8123/static/custom-elements-es5-adapter.js:13:615 Uncaught TypeError: Class constructor SliderEntityRow cannot be invoked without ānewā
I did test it on Chrome on my Android and it works just fine. Maybe something to do with Samsung Internet app? I do prefer that over Chrome so hopefully this is something that can be fixed?
My bad - formatting error!
Itās actually starting to look like a useable UI now! As Iāve said in other posts - Itās a shame you canāt just edit a CSS file. Itād cut out on loads of complication in the ui-lovelace.yaml At the moment each and every card has to have style applied. Itād be much better if this could be done on a block level in the way you would style a website!
Iāve had a play trying to do this by adding a CSS file via a .js file, but with no luck.
My lovelace code:
title: My House
resources:
- url: /local/no-card.js
type: module
- url: /local/button-card.js
type: module
# - url: /local/monster-card.js
# type: js
- url: /local/guage-card.js
type: js
# - url: /local/styles.js
# type: js
# - url: /local/kiosk.js
# type: js
# - url: /local/group-card.js
# type: js
- url: /local/folding-group-entity-row.js
type: js
- url: /local/card-modder.js
type: js
- title: Home
icon: mdi:home
theme: midnight
background: center / cover no-repeat url("/local/bg3.jpg") fixed
cards:
- type: vertical-stack
cards:
- type: horizontal-stack
cards:
- type: custom:card-modder
card:
type: "custom:button-card"
entity: script.good_morning
icon: mdi:weather-sunset-up
show_state: false
style:
- text-transform: none
style:
"background": "#2b2d3199"
border-radius: 12px
color: white
height: 90px
card:
entity: script.home_mode__day
icon: mdi:weather-sunset-down
name: "Dusk Lighting"
show_state: false
style:
style:
border-radius: 12px
color: white
height: 90px
card:
entity: script.night_night
icon: mdi:bed-empty
show_state: false
style:
style:
border-radius: 12px
color: white
height: 90px
card:
entity: script.wifi_away_day_all_lights_off
icon: mdi:power
show_state: false
style:
style:
border-radius: 12px
color: white
height: 90px
cards:
card:
type: entities
entities:
- entity: group.upstairs
type: "custom:folding-group-entity-row"
style:
border-radius: 12px
color: white
card:
type: entities
entities:
- entity: group.downstairs
style:
border-radius: 12px
color: white
card:
type: entities
entities:
- entity: group.lounge
style:
border-radius: 12px
color: white
card:
type: entities
entities:
- entity: group.kitchen
style:
border-radius: 12px
color: white
cards:
cards:
card:
entity: switch.hall_downstairs_little_lamp
icon: mdi:cloud-question
show_state: false
style:
style:
border-radius: 12px
color: white
height: 90px
card:
show_state: false
style:
style:
border-radius: 12px
color: white
height: 90px
card:
show_state: false
style:
style:
border-radius: 12px
color: white
height: 90px
card:
show_state: false
style:
style:
border-radius: 12px
color: white
height: 90px
cards:
card:
type: entities
entities:
- entity: group.hall
style:
border-radius: 12px
color: white
card:
type: entities
entities:
- entity: group.outside
style:
border-radius: 12px
color: white
card:
type: entities
entities:
- entity: group.erins_bedroom
style:
border-radius: 12px
color: white
card:
type: entities
entities:
- entity: group.master_bedroom
style:
border-radius: 12px
color: white
- title: media
icon: mdi:headphones
cards:
- type: "custom:button-card"
show_state: false
style:
- border-radius: 12px
card:
show_state: false
style:
"background": "#2b2d313d"
border-radius: 12px
- type: media-control
entity: media_player.bedroom_apple_tv
entity: media_player.living_room_apple_tv
- title: Settings
theme: midnight
background: center / cover no-repeat url("/local/kitchen.jpg") fixed
icon: mdi:settings
cards:
- type: custom:gauge-card
title: Hall Temperature
entity: sensor.hall_temperature
min: -5
max: 50
scale: 60px
severity:
blue: 14
yellow: 18
amber: 22
red: 28
- type: custom:monster-card
card:
type: entities
title: Monster
filter:
include:
- domain: light
state: 'off'
- type: entities
title: hue
show_header_toggle: true
entities:
- sensor.hall_motion_sensor
- sensor.hall_temperature
- sensor.hall_light_level
- type: entities
entities:
- entity: group.all_scripts
type: custom:folding-group-entity-row
- type: entities
entities:
- entity: group.all_automations
- title: Weather
icon: mdi:weather-partlycloudy
theme: midnight
panel:
cards:
cards:
- type: weather-forecast
entity: weather.yweather
Can you share ābg_3.jpgā url please ?
And the theme used
thnaks
Hi, sorry the image is probably not to be shared! I have now replaced this with something else.
Just do a Google image search for hd background images. There are loads out there!
Also - the theme is midnight. - but heavily modded cards using the card-modder - see the start of this post.
I am getting this error when I load my page. If I click on to another hassio window, it goes away.
Any ideas?
Check the info log to make sure you are using the latest version of the frontend as some Lovelace cards might otherwise load incorrectly. Otherwise force that in configuration.yaml
frontend:
javascript_version: latest
Added that but nothing seems to have changed.
